Hi Folks,
Four of us work remotely in my company. It is not uncommon for us to all remote desktop into a system reserved for our use and three of us be using CFEclipse at the same time. We recently installed ColdFusion Builder on this system and found that it would only allow one instance of ColdFusion Builder to run. When attempting to start a second instance CFBuilder would show the flash screen and then nothing more.
Is anyone aware of workarounds or other changes that will enable us to run multiple instances of CFBuilder on the same system?
Thanks in advance,
Thomas Woestman
Will look into this issue.
But for now as a workaround, whenever you want to launch CF Builder if there is .bolt file please delete the .bolt it from
C:\Program Files\Adobe\Adobe ColdFusion Builder\ . And you will be able to launch it even while other has kept it open.
Krishna
Are all of you sharing the same workspace/project location?
Krishna
Was reviewing this and found your reply - it looks like this will work.
Tom
