Locked
Generate sample PHP service from db could not set primary key
Sep 13, 2010 Sep 13, 2010
    Some information about my system:
OS :Windows 7 64 bit
Computer type: HP Pavilion dv6-3013cl laptop
Eclipse 3.5+Flash Builder 4 plugin
DB: MySQL 5.0 local server
Web Server: Apache 2.2+PHP 5.2.14
Zend Frame work 1.10.1 (installed by Flash Builder)
    I am trying to configure a PHP service in the Connect to Data/Service wizard. I clicked "click here to generate a sample" to generate a Sample PHP service. I selected Generate from database radio button and entered the db connection information in all fields. I am able to connect to my local database and select the table I want to create the service. But after I selected the primary key from the dropdown, the Ok button is still disabled and a warning note at the bottom of the screen still prompt for selecting the table's primary key. At this point, the log in eclipse metadata folder in the workspace has the following error:
!ENTRY org.eclipse.ui 4 0 2010-09-13 09:05:23.565
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NullPointerException
    at com.adobe.flexbuilder.services.PHPService.serverproto.ColumnModel.setType(ColumnModel.java:204)
    at com.adobe.flexbuilder.services.PHPService.serverproto.ColumnModel.buildFromColumn(ColumnModel.java:218)
    at com.adobe.flexbuilder.services.PHPService.PHPService.setPrimaryKeyColumn(PHPService.java:185)
    at com.adobe.flexbuilder.services.PHPService.serverproto.MySQLConfigurationDialog$4.widgetSelected(MySQLConfigurationDialog.java:419)
    at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:228)
    at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
    at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3880)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3473)
    at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
    at org.eclipse.jface.window.Window.open(Window.java:801)
    at com.adobe.flexbuilder.services.PHPService.PHPConfigurationPage$6.widgetSelected(PHPConfigurationPage.java:240)
    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
    at org.eclipse.swt.widgets.Link.wmNotifyChild(Link.java:1004)
    at org.eclipse.swt.widgets.Control.wmNotify(Control.java:4877)
    at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:1757)
    at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:4507)
    at org.eclipse.swt.widgets.Control.windowProc(Control.java:4000)
    at org.eclipse.swt.widgets.Display.windowProc(Display.java:4602)
    at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
    at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:2312)
    at org.eclipse.swt.widgets.Link.callWindowProc(Link.java:172)
    at org.eclipse.swt.widgets.Widget.wmLButtonUp(Widget.java:1917)
    at org.eclipse.swt.widgets.Control.WM_LBUTTONUP(Control.java:4301)
    at org.eclipse.swt.widgets.Link.WM_LBUTTONUP(Link.java:842)
    at org.eclipse.swt.widgets.Control.windowProc(Control.java:3982)
    at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
    at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2409)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3471)
    at com.adobe.flexbuilder.DCDService.ui.wizard.ServiceWizard.show(ServiceWizard.java:190)
    at com.adobe.flexbuilder.DCDService.ui.wizard.ServiceWizard.createService(ServiceWizard.java:152)
    at com.adobe.flexbuilder.dcrad.views.ServiceExplorerView$1.handleEvent(ServiceExplorerView.java:528)
    at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
    at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
    at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
    at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
    at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
    at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
    at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
    at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
I figured this explains why the OK button is not enabled. I could trick the screen by clicking the Generate from template radio button and back to clicking the Generate from database button which will enable the OK button. I clicked OK, and a Security Information warning about ricks of generating the service php file popped up asking if I want to continue. I clicked OK and back to the generate sample PHP service screen. After this, the process entered an endless Ok-warning-OK-warning-OK loop and could never proceed to actually generating the service file. In the Eclipse log file, I see more Unhandled event loop exception:
!ENTRY org.eclipse.ui 4 0 2010-09-13 11:11:30.482
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-09-13 11:12:07.460
!STACK 0
    at com.adobe.flexbuilder.services.PHPService.PHPService.fillUpModel(PHPService.java:221)
    at com.adobe.flexbuilder.services.PHPService.PHPService.createFlexService(PHPService.java:277)
    at com.adobe.flexbuilder.services.PHPService.serverproto.MySQLConfigurationDialog.okPressed(MySQLConfigurationDialog.java:948)
    at org.eclipse.jface.dialogs.Dialog.buttonPressed(Dialog.java:472)
    at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
!ENTRY org.eclipse.ui 4 0 2010-09-13 11:14:34.534
!STACK 0
I was able to do this on my old windows xp (Media Center OS) laptop. I wonder if this problem has anything to do with the Windows 7's system permission security feature. I 've stuck for 2 days now. Can someone help?! Thanks so much!
623
Sep 14, 2010 Sep 14, 2010
Thanks to Jason (San Jose) suggestion, I have filed a bug in the bug tracking system. The number is FB-27507.
Issue resolved by enabling php_pdo.dll and php_pdo_mysql.dll. Thank godness.
I suggested in the bug report that Flash Builder should warn users to enable php_pdo.dll and php_pdo_mysql.dll
extensions instead of throwing all these errors.
Guest
Sep 16, 2010 Sep 16, 2010
Thanks for reporting the bug.
I have filed another bug on, FB not validating PHP installation before generating sample https://bugs.adobe.com/jira/browse/FB-27522 .
https://bugs.adobe.com/jira/browse/FB-27522Please vote/comment for the issue.
Radhakrishna
