I'm looking for a way to get the Query Multipe to return the XML with the correct XML standard convention for nulls from the datastore.
Query Multiple currently returns:
<FacilityList>
<Facility>
<Id>1111</Id>
<Name>Auto Fac Name 2 20100901</Name>
<Alias>AFN</Alias>
<PhysicalAssetBusinessNumber/> <--blank in database. XML fine.
<PhoneNumber>null</PhoneNumber> <--null in database but this is wrong for XML
</Facility>
</FacilityList>
Should be:
<FacilityList>
<Facility>
<Id>1111</Id>
<Alias>AFN</Alias>
</PhoneNumber xsi:nil="true">
</Facility>
</FacilityList>
Any suggestions or explanations as to why this is the case?
Solved! Go to Solution.
Total Likes
In the case of MySQL, if the column allows nulls and the value is null, the XML result set will include 'null'. It probably varies by database and JDBC driver.
You will have to use XSLT to manage the transformation to xsi:nil="true".
Steve
Total Likes
Steve
Total Likes
Okay that's what I thought. What I don't understand is why. The standard is pretty clear. What's the reasoning behind not returning nulls correctly represented?
Also, do you have an XSLT example somewhere handy?
Total Likes
