FMLE 3.1 Crashes when "start" is clicked - attempting live stream
Video@SouthpointCCC Sep 16, 2010 10:46 AMHello,
I am attempting to follow the tutorials found on the Flash Media Developement Center website titled "Beginner's guide to (blah, blah) Flash Media Server 3.5"
Specifically, I am attempting to set up a live video stream using FMLE 3.1, Flash Media Developement Server 4 and Flash Professional cs5 as outlined here.
I have followed the entire tutorial including building the HTML and SWF files in Flash. I can connect to the localhost server via FMLE and monitor the server via the administrator console. My camera input and output show up in FMLE but every time I click on the green "Start" button at the bottom FMLE crashes to the desktop. Also, when I open the html (in IE8-32bit) I get a blank white window.
System: Win 7 Home Premium 64 bit, IE8 32 bit, Blackmagic Multibridge Pro capture card, 12Gb matched ram, intel x980 (non-overclocked) all drivers current.
note: running all applications as administrator (r-click, run as admin)
Thank you in advance for any help you can provide.
Most recent Log File:
File: C:\Program Files (x86)\Adobe\Flash Media Live Encoder 3.1\FlashMediaLiveEncoder.exe
Description: Adobe® Flash® Media Live Encoder
Copyright: © 2009 - 10 Adobe Systems Incorporated. All Rights Reserved. Adobe, the Adobe logo, and Flash are either registered trademarks or trademarks of Adobe Systems Incorporated in the United States and/or other countries. All other trademarks are the property of their respective owners. <AdobeIP#0000716>
Version: 3.1.0.8703
Thu Sep 16 2010 13:33:03 : Selected video input device: Decklink Video Capture
Thu Sep 16 2010 13:33:03 : Selected audio input device: Decklink Audio Capture
Thu Sep 16 2010 13:33:04 : Audio source does not support the selected sample rate and/or channels. Re-sampling the audio to desired setting.
Thu Sep 16 2010 13:33:04 : The selected audio device "Decklink Audio Capture" doesn't allow setting volume intensity. Disabling the volume slider control.
Thu Sep 16 2010 13:33:21 : Resample Required.
Thu Sep 16 2010 13:33:22 : Primary - Connected to FMS/4,0,0,1121
Thu Sep 16 2010 13:33:22 : Primary - Network Command: onBWDone
Thu Sep 16 2010 13:33:22 : Primary - Stream[livestream] Status: Success
Thu Sep 16 2010 13:33:22 : Primary - Network Command: onFCPublish
Thu Sep 16 2010 13:33:22 : Primary - Stream[livestream] Status: NetStream.Publish.Start
<?xml version="1.0" encoding="UTF-16"?>
<flashmedialiveencoder_profile>
<preset>
<name>Custom</name>
<description></description>
</preset>
<capture>
<video>
<device>Decklink Video Capture</device>
<crossbar_input>0</crossbar_input>
<frame_rate>59.94</frame_rate>
<size>
<width>1280</width>
<height>720</height>
</size>
</video>
<audio>
<device>Decklink Audio Capture</device>
<sample_rate>22050</sample_rate>
<channels>1</channels>
<input_volume>75</input_volume>
</audio>
</capture>
<process>
<video>
<preserve_aspect></preserve_aspect>
</video>
</process>
<encode>
<video>
<format>VP6</format>
<datarate>350;</datarate>
<outputsize>1280x720;</outputsize>
<advanced>
<keyframe_frequency>5 Seconds</keyframe_frequency>
<quality>Good Quality - Good Framerate</quality>
<noise_reduction>None</noise_reduction>
<datarate_window>Medium</datarate_window>
<cpu_usage>Dedicated</cpu_usage>
</advanced>
<autoadjust>
<enable>true</enable>
<maxbuffersize>1</maxbuffersize>
<dropframes>
</dropframes>
<degradequality>
<enable>false</enable>
<minvideobitrate></minvideobitrate>
<preservepfq>false</preservepfq>
</degradequality>
</autoadjust>
</video>
<audio>
<format>MP3</format>
<datarate>48</datarate>
</audio>
</encode>
<restartinterval>
<days></days>
<hours></hours>
<minutes></minutes>
</restartinterval>
<reconnectinterval>
<attempts></attempts>
<interval></interval>
</reconnectinterval>
<output>
<rtmp>
<url>rtmp://localhost/live</url>
<backup_url></backup_url>
<stream>livestream</stream>
</rtmp>
</output>
<metadata>
<entry>
<key>author</key>
<value></value>
</entry>
<entry>
<key>copyright</key>
<value></value>
</entry>
<entry>
<key>description</key>
<value></value>
</entry>
<entry>
<key>keywords</key>
<value></value>
</entry>
<entry>
<key>rating</key>
<value></value>
</entry>
<entry>
<key>title</key>
<value></value>
</entry>
</metadata>
<log>
<level>100</level>
<directory>C:\Users\SCCC Video\Videos</directory>
</log>
</flashmedialiveencoder_profile>
DumpGraph [0097B6A8]
Filter [0309B4B4] Output Video Renderer
Pin [0309B88C] Input [Input] Connected to pin [02BAFE10]
Filter [0309A66C] Input Video Renderer
Pin [0309AA44] Input [Input] Connected to pin [02BFA988]
Filter [03099514] Meter Render
Pin [030998EC] Input [Input] Connected to pin [02BA85C8]
Filter [02BA6650] Mux
Pin [02BA66B0] FLV4 [Input] Connected to pin [02BAF070]
Pin [02BA6ED0] MP3 [Input] Connected to pin [02B9D258]
Pin [02BA7148] out [ Output] This pin is not Connected
Filter [02BAF6C0] VP62_FL8 Compressor
Pin [02BAF6E0] Input [Input] Connected to pin [02BAEF10]
Pin [02BAFE10] Preview [Output] Connected to pin [0309B88C]
Pin [02BAF070] Output1 [Output] Connected to pin [02BA66B0]
Pin [02BAF168] Output2 [ Output] This pin is not Connected
Filter [02BFA880] Input RGB
Pin [02BFA898] Input [Input] Connected to pin [02B9CB30]
Pin [02BFA988] Output [Output] Connected to pin [0309AA44]
Filter [02B9D0F0] Audio Encoder Tee
Pin [02B9D100] Input [Input] Connected to pin [02BA54C0]
Pin [02B9D258] Output1 [Output] Connected to pin [02BA6ED0]
Pin [02B9D3C0] Output2 [ Output] This pin is not Connected
Filter [02B9B900] Audio Monitor
Pin [02B9B978] Input [Input] Connected to pin [03061BE4]
Pin [02BA85C8] Channel 0 [Output] Connected to pin [030998EC]
Filter [02BAE790] FPS Controller Encoder
Pin [02BAE7A0] Input [Input] Connected to pin [02BADEF8]
Pin [02BAEF10] Output [Output] Connected to pin [02BAF6E0]
Filter [02B9C470] YV12
Pin [02B9C488] Input [Input] Connected to pin [03098754]
Pin [02B9CB30] Output [Output] Connected to pin [02BFA898]
Filter [02BA4FB8] Audio Encoder
Pin [02BA4FC0] PCM [Input] Connected to pin [0097B89C]
Pin [02BA54C0] MP3 [Output] Connected to pin [02B9D100]
Filter [02BADDF0] Resize
Pin [02BADE08] Input [Input] Connected to pin [02BADC98]
Pin [02BADEF8] Output [Output] Connected to pin [02BAE7A0]
Filter [03098534] AVI Decompressor
Pin [0309866C] XForm In [Input] Connected to pin [0097C9AC]
Pin [03098754] XForm Out [Output] Connected to pin [02B9C488]
Filter [0097C5FC] Audio Tee
Pin [0097C664] Input [Input] Connected to pin [02BFA608]
Pin [0097B89C] Output1 [Output] Connected to pin [02BA4FC0]
Pin [03061BE4] Output2 [Output] Connected to pin [02B9B978]
Pin [0097C774] Output3 [ Output] This pin is not Connected
Filter [02BAD5D8] YV12 0004
Pin [02BAD5F0] Input [Input] Connected to pin [02BACF08]
Pin [02BADC98] Output [Output] Connected to pin [02BADE08]
Filter [02BF9EC8] Audio Resampler
Pin [02BF9ED0] In [Input] Connected to pin [02B9C230]
Pin [02BFA608] PCM [Output] Connected to pin [0097C664]
Filter [02BAC788] FPS Controller Resize
Pin [02BAC798] Input [Input] Connected to pin [03098AE4]
Pin [02BACF08] Output [Output] Connected to pin [02BAD5F0]
Filter [02B9BB08] Audio Filler
Pin [02B9BB10] In [Input] Connected to pin [02EAC9A4]
Pin [02B9C230] Output [Output] Connected to pin [02BF9ED0]
Filter [030988C4] AVI Decompressor 0003
Pin [030989FC] XForm In [Input] Connected to pin [03098804]
Pin [03098AE4] XForm Out [Output] Connected to pin [02BAC798]
Filter [02EAC454] AUDIO SOURCE
Pin [02EAC9A4] Capture [Output] Connected to pin [02B9BB10]
Filter [0097C834] Video Tee
Pin [0097C89C] Input [Input] Connected to pin [03098234]
Pin [0097C9AC] Output1 [Output] Connected to pin [0309866C]
Pin [03098804] Output2 [Output] Connected to pin [030989FC]
Pin [03098B94] Output3 [ Output] This pin is not Connected
Filter [0309808C] Smart Tee
Pin [030980F4] Input [Input] Connected to pin [02EA8F0C]
Pin [03098234] Capture [Output] Connected to pin [0097C89C]
Pin [03098354] Preview [ Output] This pin is not Connected
Filter [02EA7154] SOURCE
Pin [02EA8F0C] Capture [Output] Connected to pin [030980F4]
Pin [02EA9154] ~VANC [ Output] This pin is not Connected
Pin [02EA9374] ~Timecode [ Output] This pin is not Connected
Major type {73646976-0000-0010-8000-00AA00389B71} MEDIATYPE_Video
Sub type {E436EB7E-524F-11CE-9F53-0020AF0BA770} MEDIASUBTYPE_RGB32
Not temporally compressed
Sample size 3686400
Source rectangle ( Left 0 Top 0 Right 0 Bottom 0)
Target rectangle ( Left 0 Top 0 Right 0 Bottom 0)
Size of BITMAPINFO structure 40
1280 x 720, 32 bpp c:0
Image size 3686400
Planes 1
Pels per metre (0, 0)
Colours used 0
AvgTimePerFrame 166833, 59.9402 fps
Sub type {E436EB7D-524F-11CE-9F53-0020AF0BA770} MEDIASUBTYPE_RGB24
Sample size 2764800
1280 x 720, 24 bpp c:0
Image size 2764800
Planes 1
Colours used 0
Sample size 27648
96 x 96, 24 bpp c:0
Image size 27648
Planes 1
Colours used 0
AvgTimePerFrame 0, 0 fps
Sub type {34564C46-0000-0010-8000-00AA00389B71} Unknown GUID Name
Temporally compressed
Variable size samples
1280 x 720, 12 bpp c:34564c46
Image size 1382400
Planes 1
Colours used 0
Major type {73647561-0000-0010-8000-00AA00389B71} MEDIATYPE_Audio
Sub type {00000055-0000-0010-8000-00AA00389B71} Unknown GUID Name
Sample size 0
Format type FORMAT_WaveFormatEx
Subtype Unknown GUID Name
wFormatTag 85
nChannels 1
nSamplesPerSec 22050
nAvgBytesPerSec 6000
nBlockAlign 1
wBitsPerSample 0
cbSize 12
Sub type {32315659-0000-0010-8000-00AA00389B71} MEDIASUBTYPE_YV12
Sample size 1382400
1280 x 720, 12 bpp c:32315659
Image size 1382400
Planes 1
Colours used 0
Sample size 3686400
Image size 3686400
Planes 1
Colours used 0
Image size 1382400
Planes 1
Colours used 0
Sample size 1382400
Image size 1382400
Planes 1
Colours used 0
Sample size 2764800
Image size 2764800
Planes 1
Colours used 0
Sample size 1
wFormatTag 85
nChannels 1
nBlockAlign 1
wBitsPerSample 0
cbSize 12
Sample size 1
wFormatTag 85
nChannels 1
nBlockAlign 1
wBitsPerSample 0
cbSize 12
Sub type {00000001-0000-0010-8000-00AA00389B71} MEDIASUBTYPE_PCM
Sample size 2
Subtype MEDIASUBTYPE_PCM
wFormatTag 1
nChannels 1
nAvgBytesPerSec 44100
nBlockAlign 2
wBitsPerSample 16
cbSize 0
Sample size 27648
96 x 96, 24 bpp c:0
Image size 27648
Planes 1
Colours used 0
Sample size 1382400
Image size 1382400
Planes 1
Colours used 0
Sample size 1382400
Image size 1382400
Planes 1
Colours used 0
Sub type {59565955-0000-0010-8000-00AA00389B71} MEDIASUBTYPE_UYVY
Sample size 1843200
1280 x 720, 16 bpp c:59565955
Image size 1843200
Planes 1
Colours used 0
Sample size 1382400
Image size 1382400
Planes 1
Colours used 0
Sample size 2
wFormatTag 1
nChannels 1
nBlockAlign 2
wBitsPerSample 16
cbSize 0
Sample size 1
wFormatTag 85
nChannels 1
nBlockAlign 1
wBitsPerSample 0
cbSize 12
Sample size 1382400
Image size 1382400
Planes 1
Colours used 0
Sample size 1382400
Image size 1382400
Planes 1
Colours used 0
Sub type {43594448-0000-0010-8000-00AA00389B71} Unknown GUID Name
Sample size 1843200
1280 x 720, 16 bpp c:43594448
Image size 1843200
Planes 1
Colours used 0
Sample size 1843200
Image size 1843200
Planes 1
Colours used 0
Sample size 2
wFormatTag 1
nChannels 1
nBlockAlign 2
wBitsPerSample 16
cbSize 0
Sample size 2
wFormatTag 1
nChannels 1
nBlockAlign 2
wBitsPerSample 16
cbSize 0
Sample size 2
wFormatTag 1
nChannels 1
nBlockAlign 2
wBitsPerSample 16
cbSize 0
Sample size 1843200
Image size 1843200
Planes 1
Colours used 0
Sample size 1382400
Image size 1382400
Planes 1
Colours used 0
Sample size 2
wFormatTag 1
nChannels 1
nSamplesPerSec 48000
nAvgBytesPerSec 96000
nBlockAlign 2
wBitsPerSample 16
cbSize 0
Sample size 2
wFormatTag 1
nChannels 1
nBlockAlign 2
wBitsPerSample 16
cbSize 0
Sample size 1843200
Image size 1843200
Planes 1
Colours used 0
Sample size 1843200
Image size 1843200
Planes 1
Colours used 0
Sample size 2
wFormatTag 1
nChannels 1
nBlockAlign 2
wBitsPerSample 16
cbSize 0
Sample size 2
wFormatTag 1
nChannels 1
nBlockAlign 2
wBitsPerSample 16
cbSize 0
Sample size 1843200
Image size 1843200
Planes 1
Colours used 0
Sample size 1843200
Image size 1843200
Planes 1
Colours used 0
Sample size 2
wFormatTag 1
nChannels 1
nBlockAlign 2
wBitsPerSample 16
cbSize 0
Sample size 1843200
Image size 1843200
Planes 1
Colours used 0
Sample size 1843200
Image size 1843200
Planes 1
Colours used 0
Sample size 1843200
Image size 1843200
Planes 1
Colours used 0
Sample size 1843200
Image size 1843200
Planes 1
Colours used 0
Sample size 1843200
Image size 1843200
Planes 1
Colours used 0
Sample size 1843200
Image size 1843200
Planes 1
Colours used 0
Thu Sep 16 2010 13:33:22 : Session Started
Flash Media Live Encoder has experienced an unrecoverable exception. The details here may help to locate the problem. If the module listed is a third party driver, try updating or using a different driver. For reproducible problems within Flash Media Live Encoder itself, send this file to support@adobe.com with a description of what you were doing when the exception occurred.
