4 Replies Latest reply: Apr 3, 2013 11:07 PM by felicagonza RSS
    Configurator cs4 panel vertical resize limit
    Reillet Community Member
      Maybe this has been mentionned before but when I try to make a custom panel for photoshop Cs4,
      the panel appears to have a vertical limit when resizing which is much larger than the one I've initially created.
      For example this one has been created at 71 x 94 and cannot be resized vertically anymore than the screenshot .
      Docked or not is the same thing
      I have  also tried other sizes for the original panel.
      Anyone has an idea?
      Marc
        • 1. Re: Configurator cs4 panel vertical resize limit
          cromaline Community Member
          Never seen something like this.
          The maximum panel Height is 800 pixels and the minimum is 10
          The maximum panel width  is 1000 pixels and the minimum is 10
          when you drag objects in your panel Configurator   it doesn't let you insert a value  that cannot contain all the objects ( and shows a red box line as shown below)
          Your problem sounds strange to me.
          I could suggest you to reset  photoshop preferences or
          uninstall  Configurator and try a fresh install, may be something is wrong with the swf generated
          • 2. Re: Configurator cs4 panel vertical resize limit
            zhpingw Community Member
            There's a "resize" bug in Configurator 1.0.
            When you export a panel, and open it first time, Panel will resize to the width and height you assigned as cromaline say, after first time, panel will not resize, since photoshop will remember last size of your panel.
            But if you resize it to a larger size exceed photoshop's default size (220*220), when next time start photoshop
            , Photoshop will remember this size, then you can't resize it smaller.
            There's a workaround
            on Windows system go to folder  C :\Documents and Settings\
            search file "PanelSizeStore.sol" and delete it.
            Then restart photoshop, you can see the panel resize to your initial size.
            • 3. Re: Configurator cs4 panel vertical resize limit
              Thanks for the help,
              Zhpingw, your workaround was successful!
              Marc
              • 4. Re: Configurator cs4 panel vertical resize limit
                felicagonza Community Member
                Hi all, Please help me..
                when i can download adobe configuration 1.0 ( for cs4)?.
                b'cause i cant download from adobe.com
                thanks before,
                but, if you want to help me. you can send an email to mya.luphyu@yahoo.co.id
