In RH7, I use tags such as ZZZ in the topics so I can easily search, find, and edit items. To find those items, I use the Multi-Find Replace functionality. However, whenever I select a file and click on Edit in the Multi-Find Replace, it either brings up FrontPage, Word, etc. or something that the HTM file is associated with. I changed the association so it will open in RH, however, however, RH doesn't open HTML-files outside of a project. Even though I have the project open, clicking Edit does not open the file in my opened RH project
I can only edit a file by opening the file in the RH project, not through Multi-Find Replace.
Is this by design? Has it changed in RH8?
Shawn
See Snippet 88 on my site for the reason. However, as RoboHelp can no longer be used to open a single topic, I don't think it will be much help.
Peter:
Thank you.
Shawn
