I tried to configure PHP to access a mySQL DB. After installing the Zend Framework (on a QNAP 659 device) I had to update php.ini to find the path. Now I get one step further, but the message above message appears.
I am using FlashBuilder 4 and used the wizard "Connect to Data/Service...".
The php looks like:
<?php
class EmployeeService {
public function getEmployees() {
$connection = mysqli_connect ("localhost", "root", "root", "test", 8888) or die(mysqli_connect_error());
$sql = "SELECT * FROM employees";
$result = mysqli_query ($connection, $sql) or die('Query failed: ' . mysqli_error($connection));
$rows = array();
while ($row = mysqli_fetch_object ($result)) {
$rows[] = $row;
return $rows;
The SQL-DB is accessable via phpMyAdmin. All seems to look fine.
Can someone give me a hint where to search?
Thanks Wolfram
Did you check the amf_config.ini file? It says to set the production value to false instead of true. There is also a zend_path setting in there, make sure that is pointing to the library folder inside your Zend folder.
