update add to column
Guest
May 22, 2006 May 22, 2006
hi i have a number column called "man" i also have a update query which i need to add to this column
set Man = '100'
this changes the value to 100
what i need is to add 100 to the number already in the column
not sure how to do this ?
Advanced techniques
263
Participant ,
<CFSET Man = 100>
get the value of 'man' first:
<CFQUERY NAME="getValueofMan" DATASOURCE="#theDSN#">
SELECT man FROM theTable WHERE id = #theUniqueID#
</CFQUERY>
<CFIF getValueofMan.recordcount NEQ 0>
<CFSET Man = Man + getValueofMan.man>
</CFIF>
<CFQUERY NAME="updateValueofMan" DATASOURCE="#theDSN#">
UPDATE theTable set man = #Man# WHERE id = #theUniqueID#
</CFQUERY>
Jam
This is the easiest way and will work as long as man is not null to start with.
update thetable
set man = man + 100
where whatever
If you want to treat nulls as zero, and your db supports this syntax, this should work
update thetable
set man = coalesce(man, 0) + 100
where whatever
Documentation
