Can not get onClick syntax to work correctly. Help is much appreciated.
<cfform action="nexpage.cfm" target="_self" method="post" enctype="application/x-www-form-urlencoded" name="frm1" format="flash" width="900" height="700" skin="haloblue">
<cfformgroup type="horizontal">
<cfformitem type="text" width="300" enabled="yes">How did you learn of our online process?</cfformitem>
<cfinput type="radio" name="lead" label="Newspaper" value="1" onClick="document.frm1.newspaper.disabled=false" />
<cfselect disabled="true" visible="yes" name="newspaper" id="newspaper" multiple="no" width="250" >
<option value="">Select one</option>
<option value="1">option 1</option>
<option value="2">option 2</option>
<option value="3">option 3</option>
</cfselect>
</cfformgroup>
<cfformitem type="spacer" width="300" enabled="yes" />
<cfinput type="radio" name="lead" label="Job Center" value="2" onClick="document.frm1.JCenter.disabled=false" />
<cfselect disabled="true" visible="yes" name="JCenter" id="JCenter" multiple="no" width="250" >
<option value="3">option3</option>
</cfselect>
</cfformgroup>
</cfform>
It looks like you are using javascript. Flash forms use actionscript. It is a totally different beast.
UPDATE:
Never mind. My previous suggestion will not work because the radio fields have the same name. I am sure there are better ways.
But you could call a function onClick. One that changes the state of the select lists..
<cfformitem type="script">
function setListState() {
newspaper.enabled = (lead.selectedData == 1);
UPDATE:
JCenter.enabled = (lead.selectedData == 2);
</cfformitem>
<cfinput type="radio" name="lead" label="Newspaper" value="1" onClick="setListState()">
<cfinput type="radio" name="lead" label="Job Center" value="2" onClick="setListState()">
Message was edited by: -==cfSearching==-
I always use the same name for a group of radio buttons.
The selects are all different names as those are distinct. Radio buttons are part of same 'grouping'
Of course, and that makes sense. I simply meant the first technique I described would not work here, because it is designed to work with a different type of object (radiobutton versus radiobuttongroup). Anyway, take a look at the suggested alternative in my edited post.
Is the onClick doing anything at all?
Yes, it works if you use actionscript instead of javascript.
