Hi Everyone:
I'm using RoboHelp HTML, ver 8.0.2.208, with other users in a version controlled environment.
I have created a .chm file but the glossary and glossary tab do not appear in the file. I do have the glossary populated with terms and info but when I generate the .chm, there's no glossary tab and hence no glossary info.
I do have a glossary listed in the HTML Help Options-Microsoft HTML Help window before I generate but no luck with it appearing in the resulting .chm.
Any ideas? Thank you so much for any help/input. I really don't know what I would do without this forum -- it's been a lifesaver!
Hi there
First, check to ensure your Window definition has the Glossary enabled. Assuming it is, the next step is to try creating a new Window definition. Then configure the SSL to point at the new definition. If that still doesn't coax it to show, try creating a new layout. Just right-click in the SSL pod and choose to create a new layout.
Don't copy the layout as it would be like cloning a cow with a birth defect. You would likely bring the birth defect right into the clone! Best practice is to create it from scratch.
Keep us updated on your progress... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 moments from now - $24.95! |
1. Please forgive the stupid question: But how do I configure the SSL to point at the new definition?
I appreciate the help, thank you!
Hello again
See if the brief video linked below helps.
Cheers... Rick
It worked!! Thank you, thank you for all of the help. I now have two projects with two glossaries, life is good.
Now, if I can just figure out why I have topics that keep disappearing...but for now I'm basking in the glow of having glossaries. 🙂
Hi, Rick,
I, too, cannot generate a glossary in my .chm file, even though I have terms defined, and I *think* the glossary is enabled (can generate a glossary if I choose WebHelp, anyway). I am not sure where to go once I right-click Windows and then select New Window. I don't know what to select in the Window Properties dialog, so under the Properties section, I selected all the check boxes, and saved it. I went right-clicked Microsoft HTML Help, selected Generate, and I could not select my new window. My only choice was <default>. Any assistance would be much appreciated!
- Not Richard
Update: figured it out. I had not right-clicked Microsoft HTML Help and selected Set as Primary Layout. Everything made sense from there on out, and my glossary displays!
Message was edited by: Richards_Daddy
