Lisa,
No, I'm not suggesting a change in the DHTML > Java Applet
> Pure HTML setting. That's what I use.
I don't know much about generating with WebHelp Pro. There
have been some posts here saying that you should not use this
option unless you have installed a RoboHelp add -on on the server.
RIck and Peter, I think, have some advice on their sites.
The first thing to check is whether you have folders called
whdata, whgdata and whxdata in the WebHelp directory. TOC and Index
listings, and the Search database, are provided in different
formats for various browsers's capabilities.
Safari shows (for me, at least) the entire Index as a list of
words with reference numbers linked to topics, rather than a list
that gives you a topic menu popup.
The TOC looks a little different.
The Search list has the same format as the Index. There is no
fill-in field for key words. You have to scroll the list to find
the term you would have entered.
Not great, but better than nothing.
If you have those folders in the WebHelp output, and still no
TOC, post back again. I can suggest some patches in RH that could
make the TOC compatible with Safari in your environment.
Harvey
