3 Replies Latest reply: Nov 9, 2010 10:37 AM by BKBK RSS
    Is a gateway what I need?
    tclaremont Community Member
      I am using CF8 in a windows environment.
      I have a magentic stripe reader on the network at IP xxx.xx.xxx.174:1070
      When a badge is scanned, I want that information to automatically log in my SQL database. I think a Socket Gateway is what I want, so it will listen to the address in question, and allow me to capture and store the information upon a scan, but I cant find much information on the net as to how to go about this. I have gone through the exanples but apparently I am not smart enough to "get it". Can anyone point me in the right direction?
        • 1. Re: Is a gateway what I need?
          I set up a gateway, and it says it is running, but through all of my testing I get no in or out transactions recorded.
          I used the SMS test system provided and it works, and records both in and out transactions, so something must be set up right.
          I have my gateway set up to launch a CFC that sends me an email, as a test. It never gets activated. I dont think the CFC is even getting triggered.
          I know the badge scanner is working correctly because it logs scans through a simple telnet connection and writes the scan to a text file.
          Am I on the wrong track here?
          • 2. Re: Is a gateway what I need?
            After further research, I find the following in the socket-gateway log:
            Error attempting to listen on socket: java.net.socketException: socket closed
            This is a strange one, because the socket is clearly open when I look at it through Windows administration tools.
            I am using port 1070, and because it is over port 1000, I should not need any special permissions.
            In the CF administrator it shows the gateway instance as running, but no in and out entries get registered.
            I have stopped and restarted the gateway hundreds of times. No effect. Always the message shown above in the socket-gateway log.
            Is there a bug that I need to know about?
            CF8 on a windows environment.
            Web searches turn up nothing, so apparently nobody is using the socket gateway. Even the Adobe documentation is barely existant. Not really sure why I am posting this here, since it is obvious that nobody reads, much less responds to, queries in the Gateway section!
            • 3. Re: Is a gateway what I need?
              BKBK Community Member
              Only just seen this one. It should be straightforward. Is the setting in the configuration(cfg file) of your socket-gateway instance port=1070?
