0 Replies Latest reply: Sep 23, 2010 6:15 AM by IowaBoy9 RSS
    clarify issue of hyperlinks in xml (CS 3)
    IowaBoy9 Community Member
      I have the following xml code in an xml document I am importing into an InDesign CS 3 document. The code shows up in the Structure pane but it does not produce an active hyperlink. Am I doing something wrong? If the import xml feature in CS 3 doesn't handle hyperlinks, does it work in CS 4 or 5?
      snippet:
      <Hyperlink><a href="ref_doc.html">click_here</a></Hyperlink>
      Follow-up question. Is it possible to script the solution once the Hyperlinks are imported into InDesign via xml? If so, can someone point me to a basic script?
      Terry
