I am trying to make clients to connect FMS4 server over RTMFP for my video conferencing application.
It is basically a client-server media relay application in which clients with webcam/mic connect the server and the server relays video/audio data to other clients. This application is working perfectly with FMS 3.0 but it was RTMP rather than RTMFP - I simply replaced 'RTMP' with 'RTMFP' in netConnetion and tried to test in Flash Media Development Server 4.0, but it is failed to make a connection from a client - it was working after replacing it back with 'RTMP' of course.
I believe server-client media relay is possibe using RTMFP in FMS4 because Adobe said:
"Although RTMFP is often used for peer-assisted networking applications, you can use RTMFP in unicast, broadcast, and multi-point publishing applications as well. Simply replace the RTMP protocol in the NetConnection.connect() call with the RTMFP protocol:" in
Do you think RTMFP is only for peer-to-peer/multicasting application rather than traditional applications using client-server relay?
Please give any advices.
Michael
after re-reading the comments in Adaptor.xml for ...HostPort, you need to say something like
<HostPort public="68.64.123.123:19350-65535">:19350-65535</HostPort>
I've been able to do RTMFP unicast without any problem.
Firewall issue perhaps? According to the docs, unless you've reconfigured the RTMFP port range FMS will redirect the connection to a port in the 19350-65535 range.
and remember, RTMFP uses UDP. by default, ports 1935 and 19350-65535.
and if your FMS is behind a NAT, you will need to manually configure information about the translation in .../fms/conf/_defaultRoot_/Adaptor.xml in the Adaptor.RTMFP.Core.HostPortList area.
Thanks for your reply, Michael.
As you suggested I modified the file:
<!-- If a core listens on host1:1005, its publicly advertised address -->
<!-- will be host2:4005. -->
<HostPort>68.64.123.123:19350-65535</HostPort>
</HostPortList>
</Core>
</RTMFP>
</Adaptor>
I added the server's public IP before colon and restart FMS, but no luck.
Before doing this, I got "172.40.100.12:19351" in NetLimiter which can capture my network traffic to the FMS server.
172.40.100.12 is the private IP Address that I got when I did ipconfig on the FMS server.
Please help...
are you sure 68.64.123.123 is the correct public (outside NAT) address? i can't connect to that address with RTMP or RTMFP.
Hi Michael,
Oh... those IPs are fake ones. I modified them for security. BTW, Is it right position in the Adaptor.xml?
Michael,
You saved my day! Thanks a lot!
