Lock Fields
Avatar
Level 2
How do you lock a field to prevent user data input and after form submission unlock it for data entry by a specific user?
Avatar
Former Community Member
Hi
Im not sure I fully understand but i think I would use the following example to prevent data entry
TextField1.access = "protected"
then to unlock have a checkbox which in turn on the change function have a popup box requesting the password.
then a simple if statement to say if password if correct TextField1.access = "open"
If i didn't understand correcly let me know.
There is probably other ways but this is the way I would probably do it.
Regards
Graham
Avatar
Level 2
Thanks, I will test and let you know.
Avatar
paul is that possible to code it into the submission button (e.g. submit to email button, submit as:PDF)?
Avatar
Hi
I am not sure  I understand.
Are you looking to lock fields prior to submission?
Graham
Avatar
i mean for example when clicking an email submission button can we assign it
to lock automatically the form fields?
Avatar
Yes this is possible
I would suggest you create a fake email button by adding a standard button to your form and have this lock the fields then execute the email button.
e.g.
- make your current email button hidden
- Add a new standard button on top of your email button
- Have the standard button lock the form or specific form fields
- last line of code of the standard button will execute the click command of the hidden email button (e.g. form1.emailButton1.execEvent("click"))
That would be my way of doing it.
Hope this helps
Graham
