Show 2 replies
1. Re: PSE9 Printing - update to an earlier post ... and a BUG
saurabh288 Sep 27, 2010 3:31 AM (in response to Dennis Smith)The reduction is size is due to the limitation posed by the printer. If you try it with other softwares, then also the size is reduced. In case you don't want this, check the option for borderless printing. This streches a image a bit, so that borders do not remain when we print the image.
2. Re: PSE9 Printing - update to an earlier post ... and a BUG
Dennis Smith Sep 27, 2010 4:30 AM (in response to saurabh288)I understand that the initial size reduction is due to the printer size -- its the continual size reduction every time
I print that is my real issue. Since it reduced more for each of 10 invocations of print, I have to assume that will continue, and its that which I consider a "bug".
