this is my server virsion URL of the project
i cant fix the error message i had
it is going OK when i tested the gateway.php
but when i browse to the project i got that error message
Class "ShoppingcartarchiveService" does not exist: Plugin by name 'ShoppingcartarchiveService' was not found in the registry; used paths:
: \***\public_html\###\isOrderSys\reporter/isordersys_reports-debug/services/
#0 /home1/***/public_html/###/isordersys/reporter/isordersys_reports-debug/Zend/Amf/Server.php(550): Zend_Amf_Server->_dispatch('getAllShopping_...', Array, 'Shoppingcartarc...')
#1 /home1/***/public_html/###/isordersys/reporter/isordersys_reports-debug/Zend/Amf/Server.php(626): Zend_Amf_Server->_handle(Object(Zend_Amf_Request_Http))
#2 /home1/***/public_html/###/isordersys/reporter/isordersys_reports-debug/gateway.php(69): Zend_Amf_Server->handle()
#3 {main}
anyone can help?
After some playing in the amf_config.ini seems that i did the right path
but now the error is
Channel disconnected
Channel disconnected before an acknowledgement was received
so what is that means?
This can happen when there is an error in the php function. Can you use Test operation in Flash Builder Data/Services view to get the exact error?
-Sunil
Did you ever resolve this?
I'm having problems with the same error but these boards (as nice as I'm sure the posters are) have been no help. I guess we'll need to try to help each other.
What data configuration are you using (e.g. PHP/MySQL, CF/MSSQL)? Are you hosting yourself or do you have a hosting company? Apparently these kind of channel disconnected errors are rampant; the usual response is "there's an error in your PHP code" but when the code works fine locally that's kind of hard to swallow. Sometimes, I gather, Zend can be behind it.
As I say, it looks like we'll have to rely on the community of users for help.
I've got the problem as you said,like this:
but I haven't find a appropriate solution ,so I'am wondering if you can figure it out?
Is ShoppingcartarchiveService declared in the Declarations area?
Do you need to include a namespace?
Dan Pride
