Captivate 5 crashes almost immediately when recording
Sep 22, 2010 Sep 22, 2010
I've been using Captivate since version 1. I recently installed Captivate 5 and find that it crashes with a runtime error usually after the second screenshot. I have yet to make a successful recording.
Here is the error that comes up.
When I click to see more information I get these two.
I have the .txt file that is referred to in the image above and could send it if it's helpful. I'd really like to start using this product, so I'm hoping to find an answer.
I should also not that I have Captivate 3 and 4 still installed on this computer because I am a trainer and support multiple versions.
Recording
4.2K
Guest
Hi there,
- Could you provide your system details.
- What application are you trying to record on. Does Captivate crash with any application you record on?
- Does this issue come up on another machine as well?
-Manish
blogs.adobe.com/captivate
Sep 23, 2010 Sep 23, 2010
Thanks for your response. I have an HP Compaq DC7900 with Intel Core 2. I'm  running XP. It crashes when I try to record anything, even just the desktop. I  know that we have two other successful installs here, so it seems to be my  machine.
>>> M_Anand <forums@adobe.com> 9/23/2010 12:50 AM >>>
Hi there,
-Manish
Hi BlueShift
Sorry to hear that you are not able to make a successful recording.
Please share the .txt file. It may have some useful info.
I hope you have admin privileges in your WinNT machine and you are running Captivate as admin.
Can you please try recording in a Win7 or XP machine, if possible?
Also, can you please confirm the following?
1. Recording ALLWAYS crashes on second screenshot.
a)Start recording in demo mode. End recording immediately. Ideally a project with one slide will be created. Let us know what happened.
b)Start recording in demo mode. Click once. A snapshot sound will be heard. End recording immediately. Ideally a project with 2 slides will be created. Let us know what happened.
c)Start recording in demo mode. Click once. A snapshot sound will be heard. Wait for some time (say 10 seconds). Click again. Ideally snapshot will be heard again. If you end recording immediately, ideally a project with 3 slides will be created. Let us know what happened.
2. Does recording crash if you run manual mode also?
a) Start recording in manual mode. End recording immediately. Ideally a project with one slide will be created. Let us know what happened.
b) Start recording in manual mode. Take a manual screen shot (using the hotkey, which is normally printscreen key). End recording immediately. Ideally a project with 2 slides will be created. Let us know what happened.
c) Start recording in manual mode. Take two manual screen shots (using the hotkey twice, which is normally printscreen key). End recording immediately. Ideally a project with 3 slides will be created. Let us know what happened.
Cheers
Siva
Hello, thanks for responding. I am currently running on an XP machine and I do have admin access in as much as I have no restrictions for installing software. I've been able to successfully use previous versions, up through 4, on this machine.
I tried your tests and found that it will crash as soon as I end the recording regardless of if I have taken a screenshot manually or automatically. If I do not end the recording first, then it always crashes on the second click or second manual screenshot.
Here is the information from the .txt file. It's very long. I'm not sure if there is better way to share it, so I just pasted it below.
Thank you for your help.
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="AdobeCaptivate.exe" FILTER="GRABMI_FILTER_PRIVACY">
    <MATCHING_FILE NAME="ACE.dll" SIZE="1005024" CHECKSUM="0x6DF234DC" BIN_FILE_VERSION="2.16.29.7272" BIN_PRODUCT_VERSION="2.16.0.1" PRODUCT_VERSION="61.418258" FILE_DESCRIPTION="Adobe Color Engine" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="ACE 2010/01/26-18:07:03" FILE_VERSION="2.16.29.7272" ORIGINAL_FILENAME="ACE.dll" INTERNAL_NAME="ACE" LEGAL_COPYRIGHT="© 1999-2009 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF8BDF" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.16.29.7272" UPTO_BIN_PRODUCT_VERSION="2.16.0.1" LINK_DATE="01/27/2010 04:04:42" UPTO_LINK_DATE="01/27/2010 04:04:42" VER_LANGUAGE="English (United States) [0x800]" />
    <MATCHING_FILE NAME="adbeape.dll" SIZE="30176" CHECKSUM="0xD5D23E45" BIN_FILE_VERSION="3.1.65.7508" BIN_PRODUCT_VERSION="3.1.65.7508" PRODUCT_VERSION="61.421986" FILE_DESCRIPTION="Adobe APE(32 bit)" COMPANY_NAME="Adobe Systems, Incorporated " PRODUCT_NAME="Adobe APE 2010/02/23-12:40:58" FILE_VERSION="3.1.65.7508" ORIGINAL_FILENAME="adbeape.dll" INTERNAL_NAME="Adobe APE" LEGAL_COPYRIGHT="© 2006-2010 Adobe Systems Incorporated. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1557B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.1.65.7508" UPTO_BIN_PRODUCT_VERSION="3.1.65.7508" LINK_DATE="02/23/2010 21:25:25" UPTO_LINK_DATE="02/23/2010 21:25:25" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="AdobeCaptivate.exe" SIZE="329168" CHECKSUM="0xB9504BF7" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="AdobeCaptivate.exe" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5A929" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:17:42" UPTO_LINK_DATE="05/21/2010 20:17:42" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="AdobeLinguistic.dll" SIZE="4174800" CHECKSUM="0x2559F9A9" BIN_FILE_VERSION="5.0.0.9556" BIN_PRODUCT_VERSION="5.0.32.1" PRODUCT_VERSION="5.0.0" FILE_DESCRIPTION="Linguistic Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe Linguisitc Library" FILE_VERSION="5.0.0.9556" ORIGINAL_FILENAME="AdobeLinguistic.dll" INTERNAL_NAME="Lilo" LEGAL_COPYRIGHT="Copyright 1999-2009 Adobe Systems Incorporated. All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3FDAAE" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.9556" UPTO_BIN_PRODUCT_VERSION="5.0.32.1" LINK_DATE="04/17/2009 13:25:34" UPTO_LINK_DATE="04/17/2009 13:25:34" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="AdobeOwl.dll" SIZE="1371536" CHECKSUM="0x7FA78468" BIN_FILE_VERSION="3.0.71.0" BIN_PRODUCT_VERSION="3.0.71.0" PRODUCT_VERSION="3.0.71" FILE_DESCRIPTION="Adobe Owl(32 bit)" COMPANY_NAME="Adobe Systems, Incorporated " PRODUCT_NAME="Adobe Owl 2009/11/12-18:06:30" FILE_VERSION="3.0.71" ORIGINAL_FILENAME="AdobeOwl.dll" INTERNAL_NAME="Adobe Owl" LEGAL_COPYRIGHT="Copyright © 2006-2009 Adobe Systems Incorporated. All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x14EF55" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.0.71.0" UPTO_BIN_PRODUCT_VERSION="3.0.71.0" LINK_DATE="11/13/2009 03:06:58" UPTO_LINK_DATE="11/13/2009 03:06:58" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="AdobePDFL.dll" SIZE="6229984" CHECKSUM="0xA728F253" BIN_FILE_VERSION="9.9.0.7272" BIN_PRODUCT_VERSION="9.9.0.7272" PRODUCT_VERSION="61.276366" FILE_DESCRIPTION="Adobe PDF Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="PDFL 2010/01/26-18:07:03" FILE_VERSION="9.9.0.7272" ORIGINAL_FILENAME="AdobePDFL.dll" INTERNAL_NAME="PDFL" LEGAL_COPYRIGHT="© 1987-2009 Adobe Systems Incorporated.
All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5F70CD" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="9.9.0.7272" UPTO_BIN_PRODUCT_VERSION="9.9.0.7272" LINK_DATE="01/27/2010 04:55:58" UPTO_LINK_DATE="01/27/2010 04:55:58" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="AdobePIP.dll" SIZE="581488" CHECKSUM="0x3048A14F" BIN_FILE_VERSION="5.0.0.559" BIN_PRODUCT_VERSION="5.0.0.559" PRODUCT_VERSION="5.0.0.559" FILE_DESCRIPTION="Adobe Product Improvement Program" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="Adobe Product Improvement Program" FILE_VERSION="5.0.0.559" ORIGINAL_FILENAME="AdobePIP.dll" INTERNAL_NAME="AdobePIP" LEGAL_COPYRIGHT="Copyright (C) 2008 Adobe Systems, Inc. All rights reserved" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x9D43A" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.559" UPTO_BIN_PRODUCT_VERSION="5.0.0.559" LINK_DATE="11/26/2009 11:07:31" UPTO_LINK_DATE="11/26/2009 11:07:31" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="AdobePSL.dll" SIZE="12304864" CHECKSUM="0x79C0F6E" BIN_FILE_VERSION="12.0.0.7524" BIN_PRODUCT_VERSION="12.0.0.7524" PRODUCT_VERSION="61.654535_12.654498" FILE_DESCRIPTION="AdobePSL" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AdobePSL" FILE_VERSION="12.0.0.7524" ORIGINAL_FILENAME="AdobePSL.dll" INTERNAL_NAME="AdobePSL" LEGAL_COPYRIGHT="© 1984-2009 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xBC06D2" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="12.0.0.7524" UPTO_BIN_PRODUCT_VERSION="12.0.0.7524" LINK_DATE="02/26/2010 23:06:49" UPTO_LINK_DATE="02/26/2010 23:06:49" VER_LANGUAGE="English (United States) [0x800]" />
    <MATCHING_FILE NAME="AdobeSWFL.dll" SIZE="8555488" CHECKSUM="0x488254CE" BIN_FILE_VERSION="2.0.0.7489" BIN_PRODUCT_VERSION="2.0.0.7489" PRODUCT_VERSION="2.0.0.7489" FILE_DESCRIPTION="Adobe SWFL library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AdobeSWFL" FILE_VERSION="2.0.0.7489" ORIGINAL_FILENAME="AdobeSWFL.dll" INTERNAL_NAME="AdobeSWFL.dll" LEGAL_COPYRIGHT="© 2007-2010 Adobe Systems Incorporated. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x833F30" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.0.7489" UPTO_BIN_PRODUCT_VERSION="2.0.0.7489" LINK_DATE="02/19/2010 23:07:42" UPTO_LINK_DATE="02/19/2010 23:07:42" VER_LANGUAGE="English (United States) [0x800]" />
    <MATCHING_FILE NAME="AdobeXMP.dll" SIZE="303072" CHECKSUM="0x79A3DBCF" BIN_FILE_VERSION="5.0.0.60" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0" FILE_DESCRIPTION="Adobe XMP Core, 5.0-c060" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe XMP Core" FILE_VERSION="5.0-c060, 61.134503, 2010/01/24-18:06:58" ORIGINAL_FILENAME="AdobeXMP.dll" INTERNAL_NAME="AdobeXMPCore" LEGAL_COPYRIGHT="Copyright 2002-2009, Adobe Systems Incorporated. All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x514EB" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.60" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="01/25/2010 05:36:55" UPTO_LINK_DATE="01/25/2010 05:36:55" VER_LANGUAGE="English (United States) [0x800]" />
    <MATCHING_FILE NAME="adobe_caps.dll" SIZE="423872" CHECKSUM="0xBC827D51" BIN_FILE_VERSION="3.0.116.0" BIN_PRODUCT_VERSION="3.0.116.0" PRODUCT_VERSION="3,0,116,0" FILE_DESCRIPTION="Adobe CAPS DLL" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe CAPS" FILE_VERSION="3,0,116,0" ORIGINAL_FILENAME="adobe_caps.dll" INTERNAL_NAME="adobe_caps.dll" LEGAL_COPYRIGHT="© 2005-2010 Adobe Systems Incorporated. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x75805" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.0.116.0" UPTO_BIN_PRODUCT_VERSION="3.0.116.0" LINK_DATE="01/22/2010 19:34:22" UPTO_LINK_DATE="01/22/2010 19:34:22" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="Adobe_OOBE_Launcher.dll" SIZE="233400" CHECKSUM="0xCDF69285" BIN_FILE_VERSION="1.0.0.64" BIN_PRODUCT_VERSION="1.0.0.64" PRODUCT_VERSION="1.0.0.64 (BuildVersion: 1.0; BuildDate: Mon Jan 26 2010 21:49:00)" FILE_DESCRIPTION="Adobe OOBE launcher Utility" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="Adobe OOBE Launcher" FILE_VERSION="1.0.0.64" ORIGINAL_FILENAME="Adobe_OOBE_Launcher.dll" INTERNAL_NAME="Adobe OOBE Launcher" LEGAL_COPYRIGHT="Copyright 2009 Adobe Systems Incorporated. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x47FA8" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.64" UPTO_BIN_PRODUCT_VERSION="1.0.0.64" LINK_DATE="01/27/2010 09:27:15" UPTO_LINK_DATE="01/27/2010 09:27:15" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="AFL.dll" SIZE="153040" CHECKSUM="0xCF6329B3" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0" FILE_DESCRIPTION="Adobe File Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME=" AFL" FILE_VERSION="1.0.0" ORIGINAL_FILENAME="AFL.dll" INTERNAL_NAME="AFL" LEGAL_COPYRIGHT="Copyright 2000-2006 Adobe Systems Incorporated." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2C9B5" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="11/22/2008 04:23:30" UPTO_LINK_DATE="11/22/2008 04:23:30" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="aflamingo.dll" SIZE="2047456" CHECKSUM="0xDD03E2DC" BIN_FILE_VERSION="2.0.402.7511" BIN_PRODUCT_VERSION="2.0.0.1" PRODUCT_VERSION="61.421978" FILE_DESCRIPTION="Adobe Flamingo" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AFlamingo 2010/02/23-17:27:33" FILE_VERSION="2.0.402.7511" ORIGINAL_FILENAME="AFlamingo.dll" INTERNAL_NAME="AFlamingo" LEGAL_COPYRIGHT="© 2009-2010 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1FB29B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.402.7511" UPTO_BIN_PRODUCT_VERSION="2.0.0.1" LINK_DATE="02/24/2010 04:55:32" UPTO_LINK_DATE="02/24/2010 04:55:32" VER_LANGUAGE="English (United States) [0x800]" />
    <MATCHING_FILE NAME="Aggregator.exe" SIZE="103376" CHECKSUM="0x725EDCA5" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="Aggregator.exe" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1DEB0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:17:24" UPTO_LINK_DATE="05/21/2010 20:17:24" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="aggregatorUI.dll" SIZE="751568" CHECKSUM="0xCE708DF0" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="aggregatorUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xC755E" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:16:52" UPTO_LINK_DATE="05/21/2010 20:16:52" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="AGM.dll" SIZE="5670880" CHECKSUM="0xB5438B02" BIN_FILE_VERSION="4.20.67.7272" BIN_PRODUCT_VERSION="4.20.0.1" PRODUCT_VERSION="61.418258" FILE_DESCRIPTION="Adobe Graphics Manager" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AGM 2010/01/26-18:07:03" FILE_VERSION="4.20.67.7272" ORIGINAL_FILENAME="AGM.dll" INTERNAL_NAME="AGM" LEGAL_COPYRIGHT="© 1984-2009 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x56E547" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.20.67.7272" UPTO_BIN_PRODUCT_VERSION="4.20.0.1" LINK_DATE="01/27/2010 04:09:10" UPTO_LINK_DATE="01/27/2010 04:09:10" VER_LANGUAGE="English (United States) [0x800]" />
    <MATCHING_FILE NAME="ahclient.dll" SIZE="112072" CHECKSUM="0x1FCA9C64" BIN_FILE_VERSION="1.5.0.30" BIN_PRODUCT_VERSION="1.5.0.30" PRODUCT_VERSION="1,5,0,30" FILE_DESCRIPTION="Adobe Help Client Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME=" AdobeHelp Dynamic Link Library" FILE_VERSION="1,5,0,30" ORIGINAL_FILENAME="ahclient.dll" INTERNAL_NAME="AdobeHelp" LEGAL_COPYRIGHT="Copyright (C) 2008 Adobe Systems Inc." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x24282" LINKER_VERSION="0x10000" UPTO_BIN_FILE_VERSION="1.5.0.30" UPTO_BIN_PRODUCT_VERSION="1.5.0.30" LINK_DATE="12/10/2009 08:23:45" UPTO_LINK_DATE="12/10/2009 08:23:45" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="AIDE.dll" SIZE="673248" CHECKSUM="0x8D4AFD96" BIN_FILE_VERSION="1.0.0.7631" BIN_PRODUCT_VERSION="1.0.0.7631" PRODUCT_VERSION="61.424422" FILE_DESCRIPTION="Adobe Image Decode Encode Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AIDE 2010/03/17-08:41:20" FILE_VERSION="1.0.0.7631" ORIGINAL_FILENAME="AIDE.dll" INTERNAL_NAME="AIDE" LEGAL_COPYRIGHT="Copyright 2009 Adobe Systems Incorporated. All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xA7561" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.7631" UPTO_BIN_PRODUCT_VERSION="1.0.0.7631" LINK_DATE="03/17/2010 16:33:21" UPTO_LINK_DATE="03/17/2010 16:33:21" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="AlcidDLL.dll" SIZE="86992" CHECKSUM="0xFE260FAC" MODULE_TYPE="WIN32" PE_CHECKSUM="0x21846" LINKER_VERSION="0x0" LINK_DATE="01/20/2010 10:22:39" UPTO_LINK_DATE="01/20/2010 10:22:39" />
    <MATCHING_FILE NAME="amefoundation.dll" SIZE="255952" CHECKSUM="0xEC120AB" MODULE_TYPE="WIN32" PE_CHECKSUM="0x48C3A" LINKER_VERSION="0x0" LINK_DATE="01/22/2010 16:03:42" UPTO_LINK_DATE="01/22/2010 16:03:42" />
    <MATCHING_FILE NAME="ameproperties.dll" SIZE="206800" CHECKSUM="0x6295DF5" MODULE_TYPE="WIN32" PE_CHECKSUM="0x38B83" LINKER_VERSION="0x0" LINK_DATE="01/22/2010 16:06:51" UPTO_LINK_DATE="01/22/2010 16:06:51" />
    <MATCHING_FILE NAME="amtlib.dll" SIZE="911800" CHECKSUM="0xF0A8F93B" BIN_FILE_VERSION="3.0.0.64" BIN_PRODUCT_VERSION="3.0.0.64" PRODUCT_VERSION="3.0.0.64 (BuildVersion: 3.0; BuildDate:  Mon Jan 26 2010 21:49:00)" FILE_DESCRIPTION="AMT Licensing" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="AMTLib" FILE_VERSION="3.0.0.64" ORIGINAL_FILENAME="amtlib.dll" INTERNAL_NAME="amtlib" LEGAL_COPYRIGHT="Copyright 2006-2010 Adobe Systems Incorporated. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xE4B09" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.0.0.64" UPTO_BIN_PRODUCT_VERSION="3.0.0.64" LINK_DATE="01/27/2010 09:29:37" UPTO_LINK_DATE="01/27/2010 09:29:37" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="amtservices.dll" SIZE="1101240" CHECKSUM="0xA574FA8F" BIN_FILE_VERSION="3.0.0.64" BIN_PRODUCT_VERSION="3.0.0.64" PRODUCT_VERSION="3.0.0.64 (BuildVersion: 3.0; BuildDate:  Mon Jan 26 2010 21:49:00)" FILE_DESCRIPTION="AMT Services" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="AMTServices" FILE_VERSION="3.0.0.64" ORIGINAL_FILENAME="amtservices.dll" INTERNAL_NAME="amtservices" LEGAL_COPYRIGHT="Copyright 2006-2010 Adobe Systems Incorporated. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x10E92F" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.0.0.64" UPTO_BIN_PRODUCT_VERSION="3.0.0.64" LINK_DATE="01/27/2010 09:28:50" UPTO_LINK_DATE="01/27/2010 09:28:50" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="ApplicationUICore.dll" SIZE="780752" CHECKSUM="0xBF8A318E" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="ApplicationUICore.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xC678B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:12:53" UPTO_LINK_DATE="05/21/2010 20:12:53" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="arh.exe" SIZE="75064" CHECKSUM="0xF8D6FB39" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1CA35" LINKER_VERSION="0x0" LINK_DATE="06/17/2009 02:51:06" UPTO_LINK_DATE="06/17/2009 02:51:06" />
    <MATCHING_FILE NAME="ASLFoundation.dll" SIZE="363984" CHECKSUM="0x1C0963FC" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5, 0, 0, 0" FILE_DESCRIPTION="Adobe Media Encoder Support Library" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="Adobe Media Encoder CS5" FILE_VERSION="5, 0, 0, 0" ORIGINAL_FILENAME="ASLFoundation.dll" LEGAL_COPYRIGHT="Copyright © 1991-2009 Adobe Systems, Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x62065" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="01/22/2010 16:04:06" UPTO_LINK_DATE="01/22/2010 16:04:06" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="asneu.dll" SIZE="149944" CHECKSUM="0xAC693B3D" BIN_FILE_VERSION="1.7.0.1" BIN_PRODUCT_VERSION="1.7.0.1" PRODUCT_VERSION="1, 7, 0, 1" FILE_DESCRIPTION="AsnEndUser Dynamic Link Library" COMPANY_NAME="Adobe Systems Inc." PRODUCT_NAME=" AsnEndUser Dynamic Link Library" FILE_VERSION="1, 7, 0, 1" ORIGINAL_FILENAME="asneu.dll" INTERNAL_NAME="AsnEndUser" LEGAL_COPYRIGHT="Copyright © 2002 - 2006 Adobe Systems Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x31027" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.7.0.1" UPTO_BIN_PRODUCT_VERSION="1.7.0.1" LINK_DATE="06/23/2009 23:32:17" UPTO_LINK_DATE="06/23/2009 23:32:17" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="authplay.dll" SIZE="4813776" CHECKSUM="0x277E34D8" BIN_FILE_VERSION="10.0.12.29" BIN_PRODUCT_VERSION="10.0.12.29" PRODUCT_VERSION="10,0,12,29" FILE_DESCRIPTION="Adobe Flash Player 10.0 r12" COMPANY_NAME="Adobe Systems, Inc." PRODUCT_NAME="Shockwave Flash" FILE_VERSION="10,0,12,29" ORIGINAL_FILENAME="authplay.dll" INTERNAL_NAME="Adobe Flash Player 10.0" LEGAL_COPYRIGHT="Adobe® Flash® Player. Copyright © 1996-2008 Adobe Systems Incorporated. All Rights Reserved. Protected by U.S. Patent 6,879,327; Patents Pending in the United States and other countries. Adobe and Flash are either trademarks or registered trademarks in the United States and/or other countries." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x49CA8B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="10.0.12.29" UPTO_BIN_PRODUCT_VERSION="10.0.12.29" LINK_DATE="09/30/2008 02:12:27" UPTO_LINK_DATE="09/30/2008 02:12:27" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="AXE8SharedExpat.dll" SIZE="174560" CHECKSUM="0x9FF5D3E5" BIN_FILE_VERSION="3.5.101.7282" BIN_PRODUCT_VERSION="3.5.0.1" PRODUCT_VERSION="61.418555" FILE_DESCRIPTION="AXE Shared EXPAT (UTF-8 native)" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AXE8SharedExpat 2010/01/27-18:07:17" FILE_VERSION="3.5.101.7282" ORIGINAL_FILENAME="AXE8SharedExpat.dll" INTERNAL_NAME="AXE8SharedExpat" LEGAL_COPYRIGHT="© 2003-2010 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3903D" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.5.101.7282" UPTO_BIN_PRODUCT_VERSION="3.5.0.1" LINK_DATE="01/28/2010 05:31:53" UPTO_LINK_DATE="01/28/2010 05:31:53" VER_LANGUAGE="English (United States) [0x800]" />
    <MATCHING_FILE NAME="AXEDOMCore.dll" SIZE="661984" CHECKSUM="0xB1DAE24" BIN_FILE_VERSION="3.5.101.7282" BIN_PRODUCT_VERSION="3.5.0.1" PRODUCT_VERSION="61.418555" FILE_DESCRIPTION="Adobe XML Engine: DOM Core" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AXEDOMCore 2010/01/27-18:07:17" FILE_VERSION="3.5.101.7282" ORIGINAL_FILENAME="AXEDOMCore.dll" INTERNAL_NAME="AXEDOMCore" LEGAL_COPYRIGHT="© 2001-2010 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xAA703" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.5.101.7282" UPTO_BIN_PRODUCT_VERSION="3.5.0.1" LINK_DATE="01/28/2010 05:29:13" UPTO_LINK_DATE="01/28/2010 05:29:13" VER_LANGUAGE="English (United States) [0x800]" />
    <MATCHING_FILE NAME="BIB.dll" SIZE="284640" CHECKSUM="0xA06ABDAE" BIN_FILE_VERSION="1.2.2.7272" BIN_PRODUCT_VERSION="1.2.0.1" PRODUCT_VERSION="61.418258" FILE_DESCRIPTION="Bravo Interface Binder" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="BIB 2010/01/26-18:07:03" FILE_VERSION="1.2.02.7272" ORIGINAL_FILENAME="BIB.dll" INTERNAL_NAME="BIB" LEGAL_COPYRIGHT="© 1995-2009 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x53799" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.2.2.7272" UPTO_BIN_PRODUCT_VERSION="1.2.0.1" LINK_DATE="01/27/2010 03:59:51" UPTO_LINK_DATE="01/27/2010 03:59:51" VER_LANGUAGE="English (United States) [0x800]" />
    <MATCHING_FILE NAME="BIBUtils.dll" SIZE="248288" CHECKSUM="0xA0B71B17" BIN_FILE_VERSION="1.1.1.1" BIN_PRODUCT_VERSION="1.1.0.1" PRODUCT_VERSION="61.418258" FILE_DESCRIPTION="Bravo Interface Binder Utilities" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="BIBUtils 2010/01/26-18:07:03" FILE_VERSION="1.1.01.7272" ORIGINAL_FILENAME="BIBUtils.dll" INTERNAL_NAME="BIBUtils" LEGAL_COPYRIGHT="© 1993-2009 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3F2F3" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.1.1.1" UPTO_BIN_PRODUCT_VERSION="1.1.0.1" LINK_DATE="01/27/2010 04:03:37" UPTO_LINK_DATE="01/27/2010 04:03:37" VER_LANGUAGE="English (United States) [0x800]" />
    <MATCHING_FILE NAME="boost_date_time.dll" SIZE="58832" CHECKSUM="0xEFC8F9A7" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_date_time.dll" INTERNAL_NAME="boost_date_time" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1BDE0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="02/03/2010 08:19:45" UPTO_LINK_DATE="02/03/2010 08:19:45" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="boost_filesystem.dll" SIZE="81360" CHECKSUM="0x8ED6D83C" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_filesystem.dll" INTERNAL_NAME="boost_filesystem" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x21351" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="02/03/2010 08:20:39" UPTO_LINK_DATE="02/03/2010 08:20:39" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="boost_iostreams.dll" SIZE="31184" CHECKSUM="0xA1F7AC21" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_iostreams.dll" INTERNAL_NAME="boost_iostreams" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0xA6E3" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="02/03/2010 08:19:47" UPTO_LINK_DATE="02/03/2010 08:19:47" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="boost_regex.dll" SIZE="614352" CHECKSUM="0x536EFF00" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_regex.dll" INTERNAL_NAME="boost_regex" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0xA0343" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="02/03/2010 08:20:11" UPTO_LINK_DATE="02/03/2010 08:20:11" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="boost_signals.dll" SIZE="71632" CHECKSUM="0x8934DBC0" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_signals.dll" INTERNAL_NAME="boost_signals" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x12145" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="02/03/2010 08:20:16" UPTO_LINK_DATE="02/03/2010 08:20:16" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="boost_system.dll" SIZE="20432" CHECKSUM="0xACD44439" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_system.dll" INTERNAL_NAME="boost_system" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0xEAA4" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="02/03/2010 08:19:44" UPTO_LINK_DATE="02/03/2010 08:19:44" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="boost_threads.dll" SIZE="51152" CHECKSUM="0x2FAD52BF" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_threads.dll" INTERNAL_NAME="boost_threads" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x125D7" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="02/03/2010 08:20:16" UPTO_LINK_DATE="02/03/2010 08:20:16" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CaptivateUI.dll" SIZE="5705680" CHECKSUM="0x23FCC32F" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CaptivateUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x57D8DC" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:12:32" UPTO_LINK_DATE="05/21/2010 20:12:32" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CaptivateUICore.dll" SIZE="2617808" CHECKSUM="0x88AF218" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CaptivateUICore.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x28A0F9" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:50:22" UPTO_LINK_DATE="05/21/2010 19:50:22" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="Capture.dll" SIZE="639952" CHECKSUM="0xBA2BD841" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="Capture.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xA6A46" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:01:59" UPTO_LINK_DATE="05/21/2010 20:01:59" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CaptureUI.dll" SIZE="545744" CHECKSUM="0xE7F85374" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CaptureUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x8BA80" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:06:07" UPTO_LINK_DATE="05/21/2010 20:06:07" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CoolType.dll" SIZE="3041248" CHECKSUM="0xE2C071D7" BIN_FILE_VERSION="5.7.82.7272" BIN_PRODUCT_VERSION="5.7.0.1" PRODUCT_VERSION="61.418258" FILE_DESCRIPTION="CoolType Typography Engine" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="CoolType 2010/01/26-18:07:03" FILE_VERSION="5.07.82.7272" ORIGINAL_FILENAME="CoolType.dll" INTERNAL_NAME="CoolType" LEGAL_COPYRIGHT="© 1984-2009 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2F355A" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.7.82.7272" UPTO_BIN_PRODUCT_VERSION="5.7.0.1" LINK_DATE="01/27/2010 04:24:02" UPTO_LINK_DATE="01/27/2010 04:24:02" VER_LANGUAGE="English (United States) [0x800]" />
    <MATCHING_FILE NAME="CPAdditionalUI.dll" SIZE="132560" CHECKSUM="0x5FCD2D89" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPAdditionalUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x24A26" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:58:41" UPTO_LINK_DATE="05/21/2010 19:58:41" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPAnimationUtils.dll" SIZE="208336" CHECKSUM="0x49FE2A34" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPAnimationUtils.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x388D7" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:40:08" UPTO_LINK_DATE="05/21/2010 19:40:08" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPApplicationCore.dll" SIZE="663504" CHECKSUM="0x3BC57DEC" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPApplicationCore.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xABF54" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:40:12" UPTO_LINK_DATE="05/21/2010 19:40:12" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPAS3Compile.dll" SIZE="18384" CHECKSUM="0x30A92477" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPAS3Compile.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x146CA" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:38:23" UPTO_LINK_DATE="05/21/2010 19:38:23" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPAudio.dll" SIZE="235472" CHECKSUM="0xDB7BD04B" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPAudio.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3BD17" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:40:50" UPTO_LINK_DATE="05/21/2010 19:40:50" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPAudioCore.dll" SIZE="2188240" CHECKSUM="0x6130F58E" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPAudioCore.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x21A892" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:40:25" UPTO_LINK_DATE="05/21/2010 19:40:25" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPAudioUI.dll" SIZE="1254864" CHECKSUM="0x2877ADCB" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPAudioUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1377FC" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:59:14" UPTO_LINK_DATE="05/21/2010 19:59:14" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPBranchingUI.dll" SIZE="697296" CHECKSUM="0x4ABF1F4F" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPBranchingUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xAEEA4" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:13:25" UPTO_LINK_DATE="05/21/2010 20:13:25" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPBridge.dll" SIZE="330704" CHECKSUM="0xD02C527C" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPBridge.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5BF30" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:56:36" UPTO_LINK_DATE="05/21/2010 19:56:36" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPBridgeUI.dll" SIZE="31696" CHECKSUM="0xB0B914E2" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPBridgeUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xB0FD" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:17:08" UPTO_LINK_DATE="05/21/2010 20:17:08" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPCaptionExporter.dll" SIZE="93136" CHECKSUM="0x2045D48D" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPCaptionExporter.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1C649" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:13:43" UPTO_LINK_DATE="05/21/2010 20:13:43" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPCaptionImporter.dll" SIZE="119760" CHECKSUM="0x75FFE651" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPCaptionImporter.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1EC88" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:55:39" UPTO_LINK_DATE="05/21/2010 19:55:39" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPClipboard.dll" SIZE="262608" CHECKSUM="0x9A6A953F" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPClipboard.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x41F95" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:40:04" UPTO_LINK_DATE="05/21/2010 19:40:04" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPCSXSUI.dll" SIZE="68048" CHECKSUM="0xFEAABCA8" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPCSXSUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x17E09" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:16:14" UPTO_LINK_DATE="05/21/2010 20:16:14" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPDatabase.dll" SIZE="217552" CHECKSUM="0x739DDBB1" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPDatabase.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x39CE6" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:38:11" UPTO_LINK_DATE="05/21/2010 19:38:11" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPExportImportUI.dll" SIZE="67024" CHECKSUM="0xD2CFEA8C" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPExportImportUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x17C9D" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:16:13" UPTO_LINK_DATE="05/21/2010 20:16:13" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPF4VFLVEncoder.dll" SIZE="65488" CHECKSUM="0x5545154C" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPF4VFLVEncoder.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1B20A" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:55:41" UPTO_LINK_DATE="05/21/2010 19:55:41" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPFlashUtils.dll" SIZE="62416" CHECKSUM="0xEB3C7841" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPFlashUtils.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x14399" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:57:38" UPTO_LINK_DATE="05/21/2010 19:57:38" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPFLVPublish.dll" SIZE="194512" CHECKSUM="0xE5C7B04C" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPFLVPublish.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3B8D7" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:55:49" UPTO_LINK_DATE="05/21/2010 19:55:49" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPFMREdit.dll" SIZE="116688" CHECKSUM="0x2C8B6437" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPFMREdit.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1FDD2" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:44:21" UPTO_LINK_DATE="05/21/2010 19:44:21" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPJavaBridge.dll" SIZE="21968" CHECKSUM="0xAB221B4E" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPJavaBridge.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x7DA7" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:38:18" UPTO_LINK_DATE="05/21/2010 19:38:18" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPObjects.dll" SIZE="3966928" CHECKSUM="0x5B3D1121" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPObjects.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3CA863" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:48:45" UPTO_LINK_DATE="05/21/2010 19:48:45" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPObjectStylesUI.dll" SIZE="720848" CHECKSUM="0x87212BDC" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPObjectStylesUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xBA41F" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:03:36" UPTO_LINK_DATE="05/21/2010 20:03:36" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPOtherUI.dll" SIZE="379856" CHECKSUM="0x1C0E3514" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPOtherUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5E5F8" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:06:01" UPTO_LINK_DATE="05/21/2010 20:06:01" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPPainters.dll" SIZE="636880" CHECKSUM="0x9C5234C" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPPainters.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xAA94B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:54:58" UPTO_LINK_DATE="05/21/2010 19:54:58" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPPPTEditUI.dll" SIZE="138704" CHECKSUM="0xDECA7F8E" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPPPTEditUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2C5C1" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:17:05" UPTO_LINK_DATE="05/21/2010 20:17:05" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPPPTImport.dll" SIZE="230352" CHECKSUM="0x3AEDB877" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPPPTImport.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x42134" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:03:39" UPTO_LINK_DATE="05/21/2010 20:03:39" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPPPTImportUI.dll" SIZE="78800" CHECKSUM="0x9A4B88C6" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPPPTImportUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x16F0E" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:04:08" UPTO_LINK_DATE="05/21/2010 20:04:08" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPPreferencesUI.dll" SIZE="730576" CHECKSUM="0x927DBDB7" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPPreferencesUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xB728A" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:05:40" UPTO_LINK_DATE="05/21/2010 20:05:40" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPProjectNSlides.dll" SIZE="3760592" CHECKSUM="0x68D4FA75" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPProjectNSlides.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x398F6B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:43:26" UPTO_LINK_DATE="05/21/2010 19:43:26" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPPSDImport.dll" SIZE="195024" CHECKSUM="0xFA843971" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPPSDImport.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x30918" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:56:33" UPTO_LINK_DATE="05/21/2010 19:56:33" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPPSDImportUI.dll" SIZE="189392" CHECKSUM="0xE0A0C6A8" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPPSDImportUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3B7B8" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:13:04" UPTO_LINK_DATE="05/21/2010 20:13:04" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPPublic.dll" SIZE="594896" CHECKSUM="0xF6B64871" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPPublic.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x9A1E8" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:38:08" UPTO_LINK_DATE="05/21/2010 19:38:08" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPPublish.dll" SIZE="1599440" CHECKSUM="0xCB369DA" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPPublish.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x18A4F6" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:56:16" UPTO_LINK_DATE="05/21/2010 19:56:16" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPPublishUI.dll" SIZE="2627536" CHECKSUM="0xCA0F5692" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPPublishUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x28C9EF" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:14:23" UPTO_LINK_DATE="05/21/2010 20:14:23" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPQuizzing.dll" SIZE="3094992" CHECKSUM="0x97CEE49" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPQuizzing.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2FBFAA" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:54:36" UPTO_LINK_DATE="05/21/2010 19:54:36" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPQuizzingPainters.dll" SIZE="302032" CHECKSUM="0x912B7EA0" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPQuizzingPainters.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x4E160" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:13:46" UPTO_LINK_DATE="05/21/2010 20:13:46" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPQuizzingUI.dll" SIZE="1050064" CHECKSUM="0x6F14B913" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPQuizzingUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x100B92" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:16:10" UPTO_LINK_DATE="05/21/2010 20:16:10" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPSWFCommentingUI.dll" SIZE="255952" CHECKSUM="0x7A38CD1A" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPSWFCommentingUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x42607" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:16:41" UPTO_LINK_DATE="05/21/2010 20:16:41" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPSWFGenerator.dll" SIZE="973776" CHECKSUM="0xC0118E9B" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPSWFGenerator.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF9CBE" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:55:36" UPTO_LINK_DATE="05/21/2010 19:55:36" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPSWFParser.dll" SIZE="521680" CHECKSUM="0x363A2B31" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPSWFParser.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x8184D" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:40:01" UPTO_LINK_DATE="05/21/2010 19:40:01" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPTextModel.dll" SIZE="3053008" CHECKSUM="0xD530D72B" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPTextModel.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2EC045" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:39:38" UPTO_LINK_DATE="05/21/2010 19:39:38" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPThumbnails.dll" SIZE="387536" CHECKSUM="0x16979DAD" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPThumbnails.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x62D9B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:04:47" UPTO_LINK_DATE="05/21/2010 20:04:47" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPUIUtils.dll" SIZE="1612240" CHECKSUM="0x2E404BD4" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPUIUtils.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x195515" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:57:35" UPTO_LINK_DATE="05/21/2010 19:57:35" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPUnitTesting.dll" SIZE="1204176" CHECKSUM="0x9FE7054C" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPUnitTesting.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x12F631" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:15:06" UPTO_LINK_DATE="05/21/2010 20:15:06" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPVariablesNScriptingUI.dll" SIZE="305104" CHECKSUM="0x11F61B33" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPVariablesNScriptingUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x50B7E" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:17:36" UPTO_LINK_DATE="05/21/2010 20:17:36" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPVideo.dll" SIZE="371664" CHECKSUM="0xCB09952" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPVideo.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5E3B5" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:50:33" UPTO_LINK_DATE="05/21/2010 19:50:33" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPVideoUI.dll" SIZE="881104" CHECKSUM="0xFAEF5998" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPVideoUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xE48EE" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:14:08" UPTO_LINK_DATE="05/21/2010 20:14:08" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPWidgetUI.dll" SIZE="182736" CHECKSUM="0xD7DCBF46" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPWidgetUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x31F3B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:16:18" UPTO_LINK_DATE="05/21/2010 20:16:18" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPWinWordUtils.dll" SIZE="347600" CHECKSUM="0x340E054A" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPWinWordUtils.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x56752" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:55:10" UPTO_LINK_DATE="05/21/2010 19:55:10" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPWordPublish.dll" SIZE="240592" CHECKSUM="0xAC77EC72" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPWordPublish.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x43A3F" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:55:46" UPTO_LINK_DATE="05/21/2010 19:55:46" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPWordPublishData.dll" SIZE="36304" CHECKSUM="0x98F684D9" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPWordPublishData.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xD914" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:54:48" UPTO_LINK_DATE="05/21/2010 19:54:48" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPXFLExport.dll" SIZE="649680" CHECKSUM="0x82C427E8" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPXFLExport.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xA9A09" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:59:28" UPTO_LINK_DATE="05/21/2010 19:59:28" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPXFLExportUI.dll" SIZE="64976" CHECKSUM="0x78294F8" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPXFLExportUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1146A" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:17:00" UPTO_LINK_DATE="05/21/2010 20:17:00" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPXMLImportExport.dll" SIZE="203728" CHECKSUM="0x4E3170FE" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPXMLImportExport.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x37785" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:55:45" UPTO_LINK_DATE="05/21/2010 19:55:45" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPXMLParser.dll" SIZE="53200" CHECKSUM="0x7D4843DB" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPXMLParser.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1800B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:39:46" UPTO_LINK_DATE="05/21/2010 19:39:46" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPXMLWriter.dll" SIZE="177104" CHECKSUM="0xF6554735" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPXMLWriter.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3712D" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:39:04" UPTO_LINK_DATE="05/21/2010 19:39:04" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="CPZipUtils.dll" SIZE="316368" CHECKSUM="0xF695404F" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPZipUtils.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x58112" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:39:51" UPTO_LINK_DATE="05/21/2010 19:39:51" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="dvaadameve.dll" SIZE="3475408" CHECKSUM="0x49F880F1" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="dvaadameve.dll" INTERNAL_NAME="dvaadameve" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x35BF80" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="04/15/2010 12:29:58" UPTO_LINK_DATE="04/15/2010 12:29:58" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="dvacore.dll" SIZE="1629648" CHECKSUM="0xC9F0FC3E" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="dvacore.dll" INTERNAL_NAME="dvacore" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x18EDEC" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="02/03/2010 08:21:26" UPTO_LINK_DATE="02/03/2010 08:21:26" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="dvamediatypes.dll" SIZE="134608" CHECKSUM="0x28082DDF" BIN_FILE_VERSION="5.0.0.15826" BIN_PRODUCT_VERSION="5.0.0.15826" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="Adobe Media Encoder CS5" FILE_VERSION="5.0.0.212434" ORIGINAL_FILENAME="dvamediatypes.dll" INTERNAL_NAME="dvamediatypes" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x29761" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.15826" UPTO_BIN_PRODUCT_VERSION="5.0.0.15826" LINK_DATE="01/22/2010 16:03:14" UPTO_LINK_DATE="01/22/2010 16:03:14" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="dvaui.dll" SIZE="4059600" CHECKSUM="0x1D915028" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="dvaui.dll" INTERNAL_NAME="dvaui" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3E033F" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="04/30/2010 08:05:12" UPTO_LINK_DATE="04/30/2010 08:05:12" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="dvaworkspace.dll" SIZE="1093072" CHECKSUM="0xDE8176D5" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="dvaworkspace.dll" INTERNAL_NAME="dvaworkspace" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1145AA" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="02/03/2010 08:33:22" UPTO_LINK_DATE="02/03/2010 08:33:22" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="Effects.dll" SIZE="531920" CHECKSUM="0xF0216540" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="Effects.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x83850" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:54:46" UPTO_LINK_DATE="05/21/2010 19:54:46" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="EffectsUI.dll" SIZE="681424" CHECKSUM="0x687A3B9A" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="EffectsUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xAB72C" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:13:38" UPTO_LINK_DATE="05/21/2010 20:13:38" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="ExtendScript.dll" SIZE="669960" CHECKSUM="0x9E665D2C" BIN_FILE_VERSION="4.1.21.6863" BIN_PRODUCT_VERSION="4.1.21.6863" PRODUCT_VERSION="1.416121" FILE_DESCRIPTION="Adobe ExtendScript scripting engine (32 bit)" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="ExtendScript 2009/12/17-03:06:41" FILE_VERSION="4.1.21.6863" ORIGINAL_FILENAME="AdobeExtendScript.dll" INTERNAL_NAME="AdobeExtendScript" LEGAL_COPYRIGHT="© 1998-2009 Adobe Systems Incorporated. All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xB365B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.1.21.6863" UPTO_BIN_PRODUCT_VERSION="4.1.21.6863" LINK_DATE="12/17/2009 13:59:05" UPTO_LINK_DATE="12/17/2009 13:59:05" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="FakeFlash.exe" SIZE="15312" CHECKSUM="0xD663B678" MODULE_TYPE="WIN32" PE_CHECKSUM="0x76C8" LINKER_VERSION="0x0" LINK_DATE="08/21/2009 06:51:29" UPTO_LINK_DATE="08/21/2009 06:51:29" />
    <MATCHING_FILE NAME="Fireworks Library.dll" SIZE="7969232" CHECKSUM="0x83C487E9" BIN_FILE_VERSION="11.0.0.352" BIN_PRODUCT_VERSION="11.0.0.352" PRODUCT_VERSION="11.0.0.352" FILE_DESCRIPTION="Fireworks Resources" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Fireworks" FILE_VERSION="11.0.0.352" ORIGINAL_FILENAME="Fireworks_Library_Resources.dll" INTERNAL_NAME="Fireworks Resources" LEGAL_COPYRIGHT="Copyright © 1998-2009 Adobe Systems Incorporated. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x79D7E6" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="11.0.0.352" UPTO_BIN_PRODUCT_VERSION="11.0.0.352" LINK_DATE="03/13/2010 15:28:47" UPTO_LINK_DATE="03/13/2010 15:28:47" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="FullmotionRecorder.dll" SIZE="437712" CHECKSUM="0x53A788EF" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="FullmotionRecorder.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x6BBA4" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:59:33" UPTO_LINK_DATE="05/21/2010 19:59:33" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="icucnv36.dll" SIZE="664576" CHECKSUM="0xC2B7B4DF" BIN_FILE_VERSION="3.6.0.0" BIN_PRODUCT_VERSION="3.6.0.0" PRODUCT_VERSION=" Build gtlib_main.9345" FILE_DESCRIPTION="IBM ICU Common DLL" COMPANY_NAME="IBM Corporation and others" PRODUCT_NAME="International Components for Unicode 2009/01/04-11:11:10" FILE_VERSION="3, 6, 0, 1004" ORIGINAL_FILENAME="icuuc36.dll" LEGAL_COPYRIGHT=" Copyright (C) 2005, International Business Machines Corporation and others. All Rights Reserved. " VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xAA5BB" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.6.0.0" UPTO_BIN_PRODUCT_VERSION="3.6.0.0" LINK_DATE="04/01/2009 06:00:51" UPTO_LINK_DATE="04/01/2009 06:00:51" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="icudt36.dll" SIZE="10159616" CHECKSUM="0xEE351ED2" BIN_FILE_VERSION="3.6.0.0" BIN_PRODUCT_VERSION="3.6.0.0" PRODUCT_VERSION=" Build gtlib_main.9345" FILE_DESCRIPTION="ICU Data DLL" COMPANY_NAME="IBM Corporation and others" PRODUCT_NAME="International Components for Unicode 2009/01/04-11:11:10" FILE_VERSION="3, 6, 0, 1004" ORIGINAL_FILENAME="icudt36.dll" LEGAL_COPYRIGHT=" Copyright (C) 2005, International Business Machines Corporation and others. All Rights Reserved. " VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.6.0.0" UPTO_BIN_PRODUCT_VERSION="3.6.0.0" LINK_DATE="04/01/2009 06:05:14" UPTO_LINK_DATE="04/01/2009 06:05:14" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="icuin36.dll" SIZE="963072" CHECKSUM="0x89B67341" BIN_FILE_VERSION="3.6.0.0" BIN_PRODUCT_VERSION="3.6.0.0" PRODUCT_VERSION=" Build gtlib_main.9345" FILE_DESCRIPTION="IBM ICU I18N DLL" COMPANY_NAME="IBM Corporation and others" PRODUCT_NAME="International Components for Unicode 2009/01/04-11:11:10" FILE_VERSION="3, 6, 0, 1004" ORIGINAL_FILENAME="icuin36.dll" LEGAL_COPYRIGHT=" Copyright (C) 2005, International Business Machines Corporation and others. All Rights Reserved. " VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF5359" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.6.0.0" UPTO_BIN_PRODUCT_VERSION="3.6.0.0" LINK_DATE="04/01/2009 06:01:45" UPTO_LINK_DATE="04/01/2009 06:01:45" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="icuuc36.dll" SIZE="1053136" CHECKSUM="0x30302752" BIN_FILE_VERSION="3.6.0.0" BIN_PRODUCT_VERSION="3.6.0.0" PRODUCT_VERSION=" Build gtlib_main.9345" FILE_DESCRIPTION="IBM ICU Common DLL" COMPANY_NAME="IBM Corporation and others" PRODUCT_NAME="International Components for Unicode 2009/01/04-11:11:10" FILE_VERSION="3, 6, 0, 1004" ORIGINAL_FILENAME="icuuc36.dll" LEGAL_COPYRIGHT=" Copyright (C) 2005, International Business Machines Corporation and others. All Rights Reserved. " VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1052FE" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.6.0.0" UPTO_BIN_PRODUCT_VERSION="3.6.0.0" LINK_DATE="04/01/2009 06:00:51" UPTO_LINK_DATE="04/01/2009 06:00:51" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="IESpy.dll" SIZE="31232" CHECKSUM="0x6DA35061" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="IESpy.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xB7F3" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:00:19" UPTO_LINK_DATE="05/21/2010 20:00:19" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="ImageRenderer.dll" SIZE="934864" CHECKSUM="0x61679DF" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5, 0, 0, 0" FILE_DESCRIPTION="Adobe Media Encoder Support Library" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="Adobe Media Encoder CS5" FILE_VERSION="5, 0, 0, 0" ORIGINAL_FILENAME="ImageRenderer.dll" LEGAL_COPYRIGHT="Copyright © 1991-2009 Adobe Systems, Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF2F60" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="01/22/2010 16:06:15" UPTO_LINK_DATE="01/22/2010 16:06:15" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="ImageUtils.dll" SIZE="306640" CHECKSUM="0xB31CB011" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="ImageUtils.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x51B3A" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:38:21" UPTO_LINK_DATE="05/21/2010 19:38:21" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JP2KLib.dll" SIZE="675808" CHECKSUM="0x58BF0636" BIN_FILE_VERSION="2.0.0.7282" BIN_PRODUCT_VERSION="2.0.0.7282" PRODUCT_VERSION="61.129282" FILE_DESCRIPTION="Adobe JPEG2000 Core Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="JP2KLib 2010/01/27-18:07:17" FILE_VERSION="2.0.0.7282" ORIGINAL_FILENAME="JP2KLib.dll" INTERNAL_NAME="JP2KLib" LEGAL_COPYRIGHT="© 2009 Adobe Systems Incorporated.
All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xABD07" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.0.7282" UPTO_BIN_PRODUCT_VERSION="2.0.0.7282" LINK_DATE="01/28/2010 05:34:15" UPTO_LINK_DATE="01/28/2010 05:34:15" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="libguide40.dll" SIZE="200704" CHECKSUM="0xD90AF7DF" BIN_FILE_VERSION="4.0.2006.1212" BIN_PRODUCT_VERSION="4.0.2006.1212" PRODUCT_VERSION="4, 0, 2006, 1212" FILE_DESCRIPTION="Guide Runtime Library" COMPANY_NAME="Intel Corporation" PRODUCT_NAME="Guide Run-time Library" FILE_VERSION="4, 0, 2006, 1212" ORIGINAL_FILENAME="Windows_NT.rc" INTERNAL_NAME="libguide40" LEGAL_COPYRIGHT="Copyright © 2006" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x40000" UPTO_BIN_FILE_VERSION="4.0.2006.1212" UPTO_BIN_PRODUCT_VERSION="4.0.2006.1212" LINK_DATE="12/12/2006 17:52:15" UPTO_LINK_DATE="12/12/2006 17:52:15" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="libmmd.dll" SIZE="2887680" CHECKSUM="0x913067B3" BIN_FILE_VERSION="10.1.10.2" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="10.1" FILE_DESCRIPTION="Math Library for Intel(r) Compilers (thread-safe)" COMPANY_NAME="Intel Corporation" PRODUCT_NAME="Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler" FILE_VERSION="10.1.10.2" ORIGINAL_FILENAME="libmmd.dll" INTERNAL_NAME="libmmd.dll" LEGAL_COPYRIGHT="Copyright (c) 1985-2007 Intel Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x0" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="10.1.10.2" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="02/13/2008 03:26:53" UPTO_LINK_DATE="02/13/2008 03:26:53" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="LogSession.dll" SIZE="341808" CHECKSUM="0xBA28E0C9" BIN_FILE_VERSION="2.0.1.8" BIN_PRODUCT_VERSION="2.0.1.8" PRODUCT_VERSION="2, 0, 1, 8" FILE_DESCRIPTION="LogSession" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="LogSession" FILE_VERSION="2, 0, 1, 8" ORIGINAL_FILENAME="LogSession.dll" INTERNAL_NAME="LogSession" LEGAL_COPYRIGHT="Copyright 2007 Adobe Systems Incorporated and its licensors. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x62571" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.1.8" UPTO_BIN_PRODUCT_VERSION="2.0.1.8" LINK_DATE="09/08/2009 02:02:09" UPTO_LINK_DATE="09/08/2009 02:02:09" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="LogTransport2.exe" SIZE="268592" CHECKSUM="0x7DF7A2FF" BIN_FILE_VERSION="2.0.1.8" BIN_PRODUCT_VERSION="2.0.1.8" PRODUCT_VERSION="2, 0, 1, 8" FILE_DESCRIPTION="LogTransport Application" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME=" LogTransport Application" FILE_VERSION="2, 0, 1, 8" ORIGINAL_FILENAME="LogTransport.exe" INTERNAL_NAME="LogTransport" LEGAL_COPYRIGHT="Copyright 2007 Adobe Systems Incorporated and its licensors. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x45BF2" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.1.8" UPTO_BIN_PRODUCT_VERSION="2.0.1.8" LINK_DATE="09/09/2009 06:54:37" UPTO_LINK_DATE="09/09/2009 06:54:37" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="mc_dec_dv.dll" SIZE="270336" CHECKSUM="0x1748C67" BIN_FILE_VERSION="8.5.0.12323" BIN_PRODUCT_VERSION="8.5.0.12323" PRODUCT_VERSION="8.5.0.12323" FILE_DESCRIPTION="MainConcept DV+ Codec (b)" COMPANY_NAME="MainConcept GmbH" PRODUCT_NAME="MainConcept DV Codec (+) v.8.5.0.12323" FILE_VERSION="8.5.0.12323" ORIGINAL_FILENAME="mc_dvd_32.dll" INTERNAL_NAME="mc_dvd_32" LEGAL_COPYRIGHT="Copyright© MainConcept GmbH 2001-2009" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x3" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.5.0.12323" UPTO_BIN_PRODUCT_VERSION="8.5.0.12323" LINK_DATE="01/07/2010 08:42:30" UPTO_LINK_DATE="01/07/2010 08:42:30" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="mc_enc_avc.dll" SIZE="1286144" CHECKSUM="0x5EE41B62" BIN_FILE_VERSION="8.5.0.12323" BIN_PRODUCT_VERSION="8.5.0.12323" PRODUCT_VERSION="8.5.0" FILE_DESCRIPTION="AVC/H.264 Encoder" COMPANY_NAME="MainConcept GmbH" PRODUCT_NAME="MainConcept® AVC/H.264 Encoder" FILE_VERSION="8.5.0.12323 2009/11/09" ORIGINAL_FILENAME="mc_enc_avc.dll" INTERNAL_NAME="mc_enc_avc" LEGAL_COPYRIGHT="Copyright© 2009 MainConcept GmbH" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x10004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.5.0.12323" UPTO_BIN_PRODUCT_VERSION="8.5.0.12323" LINK_DATE="01/07/2010 08:30:13" UPTO_LINK_DATE="01/07/2010 08:30:13" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="mc_enc_dv.dll" SIZE="262144" CHECKSUM="0x4807AC1F" BIN_FILE_VERSION="8.5.0.12323" BIN_PRODUCT_VERSION="8.5.0.12323" PRODUCT_VERSION="8.5.0.12323" FILE_DESCRIPTION="MainConcept DV+ Codec (b)" COMPANY_NAME="MainConcept GmbH" PRODUCT_NAME="MainConcept DV Codec (+) v.8.5.0.12323" FILE_VERSION="8.5.0.12323" ORIGINAL_FILENAME="mc_dvd_32.dll" INTERNAL_NAME="mc_dvd_32" LEGAL_COPYRIGHT="Copyright© MainConcept GmbH 2001-2009" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x3" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.5.0.12323" UPTO_BIN_PRODUCT_VERSION="8.5.0.12323" LINK_DATE="01/07/2010 08:43:05" UPTO_LINK_DATE="01/07/2010 08:43:05" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="MPS.dll" SIZE="4704208" CHECKSUM="0xC7831428" BIN_FILE_VERSION="5.5.0.1" BIN_PRODUCT_VERSION="5.5.0.1" PRODUCT_VERSION="61.421463" FILE_DESCRIPTION="Modular Parsing System" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="MPS 2010/02/19-13:50:10" FILE_VERSION="5.5.0.1" ORIGINAL_FILENAME="MPS.dll" INTERNAL_NAME="MPS" LEGAL_COPYRIGHT="© 1996-2009 Adobe Systems Incorporated. All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x48B119" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.5.0.1" UPTO_BIN_PRODUCT_VERSION="5.5.0.1" LINK_DATE="03/20/2010 08:44:11" UPTO_LINK_DATE="03/20/2010 08:44:11" VER_LANGUAGE="English (United States) [0x800]" />
    <MATCHING_FILE NAME="NPSWF32.dll" SIZE="5541344" CHECKSUM="0x97FA11D3" BIN_FILE_VERSION="10.1.51.87" BIN_PRODUCT_VERSION="10.1.51.87" PRODUCT_VERSION="10,1,51,87" FILE_DESCRIPTION="Shockwave Flash 10.1 d51" COMPANY_NAME="Adobe Systems, Inc." PRODUCT_NAME="Shockwave Flash" FILE_VERSION="10,1,51,87" ORIGINAL_FILENAME="npswf32.dll" INTERNAL_NAME="Adobe Flash Player 10.1" LEGAL_COPYRIGHT="Adobe® Flash® Player. Copyright © 1996-2010 Adobe Systems Incorporated. All Rights Reserved. Adobe and Flash are either trademarks or registered trademarks in the United States and/or other countries." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x54B829" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="10.1.51.87" UPTO_BIN_PRODUCT_VERSION="10.1.51.87" LINK_DATE="02/13/2010 05:32:56" UPTO_LINK_DATE="02/13/2010 05:32:56" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="Plugin.dll" SIZE="49104" CHECKSUM="0xC28C4A23" BIN_FILE_VERSION="12.0.0.0" BIN_PRODUCT_VERSION="12.0.0.0" PRODUCT_VERSION="CS5" FILE_DESCRIPTION="Photoshop Plugin Utilities" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="Adobe Photoshop CS5" FILE_VERSION="12.0 (12.0x001)" ORIGINAL_FILENAME="Plugin.dll" INTERNAL_NAME="Plugin" LEGAL_COPYRIGHT="Copyright 2008 Adobe Systems Inc." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF2D5" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="12.0.0.0" UPTO_BIN_PRODUCT_VERSION="12.0.0.0" LINK_DATE="12/08/2009 18:23:40" UPTO_LINK_DATE="12/08/2009 18:23:40" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="PlugPlug.dll" SIZE="1118152" CHECKSUM="0x49FEFFE9" BIN_FILE_VERSION="2.0.0.746" BIN_PRODUCT_VERSION="2.0.0.746" PRODUCT_VERSION="2.0.0.746" FILE_DESCRIPTION="PlugPlug Standard Dll (32 bit)" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe(R) CSXS PlugPlug Standard Dll (32 bit)" FILE_VERSION="2.0.0.746" ORIGINAL_FILENAME="PlugPlug Standard Dll (32 bit)" INTERNAL_NAME="PlugPlug" LEGAL_COPYRIGHT="(C) 2009 Adobe Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1207A1" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.0.746" UPTO_BIN_PRODUCT_VERSION="2.0.0.746" LINK_DATE="03/25/2010 17:50:22" UPTO_LINK_DATE="03/25/2010 17:50:22" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="PotluckStd.dll" SIZE="230864" CHECKSUM="0xFF5743C3" BIN_FILE_VERSION="2.4.7.0" BIN_PRODUCT_VERSION="2.4.7.0" PRODUCT_VERSION="2.4.7" FILE_DESCRIPTION="Potluck2" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Potluck2" FILE_VERSION="2.4.7" INTERNAL_NAME="Potluck2" LEGAL_COPYRIGHT="Copyright 2008" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3B444" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.4.7.0" UPTO_BIN_PRODUCT_VERSION="2.4.7.0" LINK_DATE="01/21/2009 02:52:05" UPTO_LINK_DATE="01/21/2009 02:52:05" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="ppt2swf.dll" SIZE="6227920" CHECKSUM="0x9F0CE0CF" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="ppt2swf.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5F745B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:01:44" UPTO_LINK_DATE="05/21/2010 20:01:44" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="PRM.dll" SIZE="15312" CHECKSUM="0xA0A8B175" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5, 0, 0, 0" FILE_DESCRIPTION="Adobe Media Encoder Support Library" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="Adobe Media Encoder CS5" FILE_VERSION="5, 0, 0, 0" ORIGINAL_FILENAME="PRM.dll" LEGAL_COPYRIGHT="Copyright © 1991-2009 Adobe Systems, Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x9825" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="01/22/2010 16:01:18" UPTO_LINK_DATE="01/22/2010 16:01:18" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="PropertyInspector.dll" SIZE="2585600" CHECKSUM="0xD1517DB0" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="PropertyInspector.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x284644" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:01:32" UPTO_LINK_DATE="05/21/2010 20:01:32" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="QuickTimeGlue.dll" SIZE="35840" CHECKSUM="0x160AABDB" MODULE_TYPE="WIN32" PE_CHECKSUM="0xCDBB" LINKER_VERSION="0x0" LINK_DATE="01/29/2010 04:28:46" UPTO_LINK_DATE="01/29/2010 04:28:46" />
    <MATCHING_FILE NAME="ScCore.dll" SIZE="585992" CHECKSUM="0x41CDA730" BIN_FILE_VERSION="4.1.21.6863" BIN_PRODUCT_VERSION="4.1.21.6863" PRODUCT_VERSION="1.416121" FILE_DESCRIPTION="Scripting Components Core (32 bit)" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="ScCore 2009/12/17-03:06:41" FILE_VERSION="4.1.21.6863" ORIGINAL_FILENAME="AdobeScCore.dll" INTERNAL_NAME="AdobeScCore" LEGAL_COPYRIGHT="© 1998-2009 Adobe Systems Incorporated. All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x929C8" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.1.21.6863" UPTO_BIN_PRODUCT_VERSION="4.1.21.6863" LINK_DATE="12/17/2009 13:58:55" UPTO_LINK_DATE="12/17/2009 13:58:55" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="updaternotifications.dll" SIZE="584688" CHECKSUM="0x2A60903E" BIN_FILE_VERSION="1.0.0.68" BIN_PRODUCT_VERSION="1.0.0.68" PRODUCT_VERSION="1.0.0.68 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)" FILE_DESCRIPTION="Adobe Updater Notifications Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe Updater Notifications Library" FILE_VERSION="1\,0\,0\,68" ORIGINAL_FILENAME="Updaternotifications.dll" INTERNAL_NAME="UpdaterNotifications.dll" LEGAL_COPYRIGHT="Copyright 2009-10 Adobe Systems Incorporated. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x98ACD" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.68" UPTO_BIN_PRODUCT_VERSION="1.0.0.68" LINK_DATE="04/29/2010 06:34:17" UPTO_LINK_DATE="04/29/2010 06:34:17" VER_LANGUAGE="Language Neutral [0x4009]" />
    <MATCHING_FILE NAME="VeelaUpgrader.dll" SIZE="838608" CHECKSUM="0x622E522D" BIN_FILE_VERSION="5.0.1.607" BIN_PRODUCT_VERSION="5.0.1.607" PRODUCT_VERSION="5.0.1.607" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.1.607" ORIGINAL_FILENAME="VeelaUpgrader.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xD8ED9" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.1.607" UPTO_BIN_PRODUCT_VERSION="5.0.1.607" LINK_DATE="07/29/2010 10:51:10" UPTO_LINK_DATE="07/29/2010 10:51:10" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="vt_eng.dll" SIZE="643072" CHECKSUM="0xFFFCE209" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="07/09/2009 06:44:58" UPTO_LINK_DATE="07/09/2009 06:44:58" />
    <MATCHING_FILE NAME="WebKit.dll" SIZE="4284896" CHECKSUM="0xF1C44C7C" MODULE_TYPE="WIN32" PE_CHECKSUM="0x425ABF" LINKER_VERSION="0x0" LINK_DATE="02/19/2010 23:48:25" UPTO_LINK_DATE="02/19/2010 23:48:25" />
    <MATCHING_FILE NAME="WHook.dll" SIZE="14336" CHECKSUM="0xB62CC1A1" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="WHook.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x4FC3" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:48:51" UPTO_LINK_DATE="05/21/2010 19:48:51" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="WRServices.dll" SIZE="1202896" CHECKSUM="0x799DF95" BIN_FILE_VERSION="4.0.0.1" BIN_PRODUCT_VERSION="4.0.0.1" PRODUCT_VERSION="Build 0.11423" FILE_DESCRIPTION="WRServices Engine" COMPANY_NAME="WinSoft S.A." PRODUCT_NAME="WRServices Thursday January 21 2010 12:13:3" FILE_VERSION="4.0.0.1000" ORIGINAL_FILENAME="WRServices.dll" INTERNAL_NAME="WRServices" LEGAL_COPYRIGHT="(c) 1993 - 2008 WinSoft S.A., (c) 2007 Adobe Systems, Inc." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1264A2" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.0.0.1" UPTO_BIN_PRODUCT_VERSION="4.0.0.1" LINK_DATE="01/21/2010 20:16:26" UPTO_LINK_DATE="01/21/2010 20:16:26" VER_LANGUAGE="English (United States) [0x800]" />
    <MATCHING_FILE NAME="xerces-c_2_6.dll" SIZE="1818064" CHECKSUM="0x6F5794F8" BIN_FILE_VERSION="2.5.0.0" BIN_PRODUCT_VERSION="2.5.0.0" PRODUCT_VERSION="2, 6, 0" FILE_DESCRIPTION="Shared Library for Xerces-C Version 2.6.0" COMPANY_NAME="Apache Software Foundation" PRODUCT_NAME="Xerces-C Version 2.6.0" FILE_VERSION="2, 6, 0" ORIGINAL_FILENAME="xerces-c_2_6.dll" INTERNAL_NAME="xerces-c_2_6.dll" LEGAL_COPYRIGHT="Copyright © Apache Software Foundation 2000 subject to licensing terms" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1BBE49" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.5.0.0" UPTO_BIN_PRODUCT_VERSION="2.5.0.0" LINK_DATE="01/21/2009 02:51:41" UPTO_LINK_DATE="01/21/2009 02:51:41" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="AirApps\AdobeAIRInstaller.exe" SIZE="15849560" CHECKSUM="0xA241A2B4" BIN_FILE_VERSION="1.5.3.9130" BIN_PRODUCT_VERSION="1.5.3.9130" PRODUCT_VERSION="1.5.3" FILE_DESCRIPTION="Adobe AIR Installer" COMPANY_NAME="Adobe Systems Inc." PRODUCT_NAME="Adobe AIR 1.5.3" FILE_VERSION="1.5.3.9130" ORIGINAL_FILENAME="Adobe AIR Installer.exe" INTERNAL_NAME="Adobe AIR Installer.exe" LEGAL_COPYRIGHT="Copyright 2009, Adobe Systems Inc." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF2385D" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.5.3.9130" UPTO_BIN_PRODUCT_VERSION="1.5.3.9130" LINK_DATE="02/01/2010 10:45:30" UPTO_LINK_DATE="02/01/2010 10:45:30" />
    <MATCHING_FILE NAME="as_templates\CPAS3Template.dll" SIZE="94160" CHECKSUM="0x359B13DC" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPAS3Template.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1A5F4" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 20:17:40" UPTO_LINK_DATE="05/21/2010 20:17:40" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="ExecutablePublish\FakeFlash.exe" SIZE="4065232" CHECKSUM="0xDD498B81" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="5.0.0.0" FILE_DESCRIPTION="Flash Player" PRODUCT_NAME="Adobe Captivate" FILE_VERSION="1.0.0.1" ORIGINAL_FILENAME="FlashPlayer.exe" INTERNAL_NAME="FlashPlayer" LEGAL_COPYRIGHT="Copyright (C) 2002-2008 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3E7BE7" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="02/25/2010 15:37:02" UPTO_LINK_DATE="02/25/2010 15:37:02" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="HLC\HLC.dll" SIZE="167376" CHECKSUM="0x476C1D9" BIN_FILE_VERSION="5.0.0.1" BIN_PRODUCT_VERSION="5.0.0.1" PRODUCT_VERSION="5, 0, 0, 1" FILE_DESCRIPTION="Adobe Captivate HLC Library" PRODUCT_NAME="HLC Dynamic Link Library" FILE_VERSION="5, 0, 0, 1" ORIGINAL_FILENAME="HLC.dll" INTERNAL_NAME="HLC" LEGAL_COPYRIGHT="© 2010 Adobe Systems Incorporated.
All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2C34E" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.1" UPTO_BIN_PRODUCT_VERSION="5.0.0.1" LINK_DATE="03/01/2010 10:18:29" UPTO_LINK_DATE="03/01/2010 10:18:29" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JVM\bin\awt.dll" SIZE="1339493" CHECKSUM="0xDF21B5B5" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="awt.dll" INTERNAL_NAME="awt" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1510C4" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:05" UPTO_LINK_DATE="09/07/2006 23:06:05" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JVM\bin\axbridge.dll" SIZE="94321" CHECKSUM="0x5BC35DFB" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="ActiveX Bridge for JavaBeans(TM)" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="axbridge.dll" INTERNAL_NAME="ActiveX Bridge for JavaBeans(TM)" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x17B82" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:51:18" UPTO_LINK_DATE="09/07/2006 22:51:18" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JVM\bin\cmm.dll" SIZE="192613" CHECKSUM="0x7A13C65F" BIN_FILE_VERSION="1.1.0.0" BIN_PRODUCT_VERSION="1.1.0.0" PRODUCT_VERSION="1.1.0" FILE_DESCRIPTION="KODAK DIGITAL SCIENCE Java CMM" COMPANY_NAME="Eastman Kodak Company" PRODUCT_NAME="KODAK DIGITAL SCIENCE Java CMM" FILE_VERSION="1.1.0" ORIGINAL_FILENAME="cmm.dll" INTERNAL_NAME="cmm" LEGAL_COPYRIGHT="Eastman Kodak Company 1997" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2F829" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.1.0.0" UPTO_BIN_PRODUCT_VERSION="1.1.0.0" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JVM\bin\dcpr.dll" SIZE="143462" CHECKSUM="0x246E1B98" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="dcpr.dll" INTERNAL_NAME="dcpr" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2D191" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\deploy.dll" SIZE="69632" CHECKSUM="0x700186B3" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) Deployment Library" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="deploy.dll" INTERNAL_NAME="Java(TM) Deployment Library" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1492B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\dt_shmem.dll" SIZE="32872" CHECKSUM="0x6968A64D" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="dt_shmem.dll" INTERNAL_NAME="dt_shmem" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x176C0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\dt_socket.dll" SIZE="28778" CHECKSUM="0x84D180D4" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="dt_socket.dll" INTERNAL_NAME="dt_socket" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF117" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\eula.dll" SIZE="61545" CHECKSUM="0xE9927472" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="EULA" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="eula.dll" INTERNAL_NAME="EULA" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x172DF" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JVM\bin\fontmanager.dll" SIZE="258166" CHECKSUM="0x1274DBF3" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="fontmanager.dll" INTERNAL_NAME="fontmanager" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x442A1" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\hpi.dll" SIZE="32878" CHECKSUM="0x73C1312C" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="hpi.dll" INTERNAL_NAME="hpi" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x107EE" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\hprof.dll" SIZE="122983" CHECKSUM="0xEC39C0B" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="hprof.dll" INTERNAL_NAME="hprof" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x23DAB" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\instrument.dll" SIZE="57466" CHECKSUM="0x883CA566" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="instrument.dll" INTERNAL_NAME="instrument" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x10CB1" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\ioser12.dll" SIZE="28802" CHECKSUM="0xAD2EB248" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="ioser12.dll" INTERNAL_NAME="ioser12" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xEE33" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\j2pkcs11.dll" SIZE="69768" CHECKSUM="0xC85E5932" BIN_FILE_VERSION="1.5.0.0" BIN_PRODUCT_VERSION="1.5.0.0" PRODUCT_VERSION="1.5.0.0" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0" FILE_VERSION="1.5.0.0" ORIGINAL_FILENAME="j2pkcs11.dll" INTERNAL_NAME="j2pkcs11" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1AD81" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.5.0.0" UPTO_BIN_PRODUCT_VERSION="1.5.0.0" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\jaas_nt.dll" SIZE="24698" CHECKSUM="0xCD7A90E" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jaas_nt.dll" INTERNAL_NAME="jaas_nt" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x13B3A" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\java.dll" SIZE="118890" CHECKSUM="0x3C339B6F" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="java.dll" INTERNAL_NAME="java" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x24C53" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\java.exe" SIZE="49248" CHECKSUM="0xFA61D8B4" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="java.exe" INTERNAL_NAME="java" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 21:14:36" UPTO_LINK_DATE="09/07/2006 21:14:36" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\javacpl.exe" SIZE="45171" CHECKSUM="0xFEDD854D" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) Control Panel" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="javacpl.exe" INTERNAL_NAME="Java(TM) Control Panel" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:48:06" UPTO_LINK_DATE="09/07/2006 22:48:06" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JVM\bin\javaw.exe" SIZE="53346" CHECKSUM="0x42775B6F" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="javaw.exe" INTERNAL_NAME="javaw" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 21:14:46" UPTO_LINK_DATE="09/07/2006 21:14:46" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\JavaWebStart.dll" SIZE="147456" CHECKSUM="0xB7413D6C" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="1.5.0.0" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) Web Start ActiveX Control" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="JavaWebStart.dll" INTERNAL_NAME="Java(TM) Web Start ActiveX Control" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x27D0C" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="1.5.0.0" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JVM\bin\javaws.exe" SIZE="127078" CHECKSUM="0x1A417F05" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) Web Start Launcher" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="javaws.exe" INTERNAL_NAME="Java(TM) Web Start Launcher" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:38:23" UPTO_LINK_DATE="09/07/2006 22:38:23" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\java_crw_demo.dll" SIZE="32881" CHECKSUM="0x10146607" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="java_crw_demo.dll" INTERNAL_NAME="java_crw_demo" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x15121" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\jawt.dll" SIZE="24679" CHECKSUM="0x4B519BEC" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jawt.dll" INTERNAL_NAME="jawt" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x130DD" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\JdbcOdbc.dll" SIZE="53365" CHECKSUM="0x995B7807" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="JdbcOdbc.dll" INTERNAL_NAME="JdbcOdbc" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x14329" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\jdwp.dll" SIZE="200800" CHECKSUM="0xB11149FD" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jdwp.dll" INTERNAL_NAME="jdwp" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3225A" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\jpeg.dll" SIZE="127079" CHECKSUM="0xA4D3E4C3" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jpeg.dll" INTERNAL_NAME="jpeg" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2D9F1" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\jpicom32.dll" SIZE="86129" CHECKSUM="0xD3430683" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) Plug-in COM Library" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jpicom32.dll" INTERNAL_NAME="Java(TM) Plug-in COM Library" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x22034" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JVM\bin\jpiexp32.dll" SIZE="98417" CHECKSUM="0xFC4D755B" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) Plug-in for Internet Explorer" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jpiexpl32.dll" INTERNAL_NAME="Java(TM) Plug-in for Internet Explorer" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1CE73" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JVM\bin\jpinscp.dll" SIZE="86127" CHECKSUM="0x632553BF" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jpinscp.dll" INTERNAL_NAME="Java(TM) Plug-in Netscape Core Library" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1C495" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\jpioji.dll" SIZE="49266" CHECKSUM="0x98611FD" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jpioji.dll" INTERNAL_NAME="Java(TM) Plug-in OJI Library" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x186E4" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\jpishare.dll" SIZE="77937" CHECKSUM="0x21BE2B69" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) Plug-in Share Library" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jpishare.dll" INTERNAL_NAME="Java(TM) Plug-in Share Library" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1D8BE" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JVM\bin\jsound.dll" SIZE="147567" CHECKSUM="0x6C869F2A" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jsound.dll" INTERNAL_NAME="jsound" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x32A0A" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\jsoundds.dll" SIZE="32883" CHECKSUM="0x5978B3DB" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jsoundds.dll" INTERNAL_NAME="jsoundds" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x84FF" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\jucheck.exe" SIZE="241775" CHECKSUM="0x1953E4D8" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) Update Checker" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jucheck.exe" INTERNAL_NAME="Java(TM) Update Checker" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:42:59" UPTO_LINK_DATE="09/07/2006 22:42:59" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JVM\bin\jusched.exe" SIZE="49263" CHECKSUM="0x9F95B06C" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jusched.exe" INTERNAL_NAME="Java(TM) Update Scheduler" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:43:16" UPTO_LINK_DATE="09/07/2006 22:43:16" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\keytool.exe" SIZE="53368" CHECKSUM="0xF122C1BE" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="keytool.exe" INTERNAL_NAME="keytool" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 21:33:06" UPTO_LINK_DATE="09/07/2006 21:33:06" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\kinit.exe" SIZE="53364" CHECKSUM="0x62518154" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="kinit.exe" INTERNAL_NAME="kinit" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 21:33:54" UPTO_LINK_DATE="09/07/2006 21:33:54" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\klist.exe" SIZE="53364" CHECKSUM="0x62518154" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="klist.exe" INTERNAL_NAME="klist" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 21:34:03" UPTO_LINK_DATE="09/07/2006 21:34:03" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\ktab.exe" SIZE="53362" CHECKSUM="0x62518154" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="ktab.exe" INTERNAL_NAME="ktab" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 21:34:12" UPTO_LINK_DATE="09/07/2006 21:34:12" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\management.dll" SIZE="32897" CHECKSUM="0x2329125A" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="management.dll" INTERNAL_NAME="management" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1233F" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\net.dll" SIZE="77926" CHECKSUM="0x92D4172C" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="net.dll" INTERNAL_NAME="net" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1AD93" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\nio.dll" SIZE="36967" CHECKSUM="0xD210D466" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="nio.dll" INTERNAL_NAME="nio" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x16F21" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\NPJava11.dll" SIZE="69743" CHECKSUM="0x7B4C1FEA" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java Plug-in 1.5.0_09 for Netscape Navigator (DLL Helper)" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="NPJava11.dll" INTERNAL_NAME="Java(TM) Plug-in" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x133B7" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JVM\bin\NPJava12.dll" SIZE="69743" CHECKSUM="0x234CA07C" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java Plug-in 1.5.0_09 for Netscape Navigator (DLL Helper)" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="NPJava12.dll" INTERNAL_NAME="Java(TM) Plug-in" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x166EF" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JVM\bin\NPJava13.dll" SIZE="69743" CHECKSUM="0xE4D2025" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java Plug-in 1.5.0_09 for Netscape Navigator (DLL Helper)" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="NPJava13.dll" INTERNAL_NAME="Java(TM) Plug-in" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1490B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JVM\bin\NPJava14.dll" SIZE="69743" CHECKSUM="0x74CC59B1" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java Plug-in 1.5.0_09 for Netscape Navigator (DLL Helper)" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="NPJava14.dll" INTERNAL_NAME="Java(TM) Plug-in" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1E7EB" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JVM\bin\NPJava32.dll" SIZE="69743" CHECKSUM="0x624E22F8" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java Plug-in 1.5.0_09 for Netscape Navigator (DLL Helper)" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="NPJava32.dll" INTERNAL_NAME="Java(TM) Plug-in" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x206E4" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JVM\bin\NPJPI150_09.dll" SIZE="69746" CHECKSUM="0x7B49F343" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java Plug-in 1.5.0_09 for Netscape Navigator (DLL Helper)" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="NPJPI&quot;150_09&quot;.dll" INTERNAL_NAME="Java(TM) Plug-in" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x20796" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JVM\bin\NPOJI610.dll" SIZE="69743" CHECKSUM="0xF64F2987" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java Plug-in 1.5.0_09 for Netscape Navigator (DLL Helper)" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="NPOJI610.dll" INTERNAL_NAME="Java(TM) Virtual Machine for Netscape and Mozilla" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1BB6B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JVM\bin\orbd.exe" SIZE="53383" CHECKSUM="0x55E23BA1" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="orbd.exe" INTERNAL_NAME="orbd" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:03:31" UPTO_LINK_DATE="09/07/2006 22:03:31" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\pack200.exe" SIZE="53376" CHECKSUM="0xC7AC3BDE" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="pack200.exe" INTERNAL_NAME="pack200" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:04:46" UPTO_LINK_DATE="09/07/2006 22:04:46" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\policytool.exe" SIZE="53374" CHECKSUM="0xC8E041BF" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="policytool.exe" INTERNAL_NAME="policytool" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 21:33:44" UPTO_LINK_DATE="09/07/2006 21:33:44" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\RegUtils.dll" SIZE="143473" CHECKSUM="0x7148B389" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="RegUtils.dll" INTERNAL_NAME="RegUtils" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x325C1" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\rmi.dll" SIZE="24677" CHECKSUM="0x82CE3442" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="rmi.dll" INTERNAL_NAME="rmi" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x14389" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\rmid.exe" SIZE="53362" CHECKSUM="0xC922C1BE" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="rmid.exe" INTERNAL_NAME="rmid" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 21:56:12" UPTO_LINK_DATE="09/07/2006 21:56:12" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\rmiregistry.exe" SIZE="53374" CHECKSUM="0xC8E041BF" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="rmiregistry.exe" INTERNAL_NAME="rmiregistry" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 21:55:53" UPTO_LINK_DATE="09/07/2006 21:55:53" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\servertool.exe" SIZE="53395" CHECKSUM="0x8CC0CFD8" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="servertool.exe" INTERNAL_NAME="servertool" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:03:40" UPTO_LINK_DATE="09/07/2006 22:03:40" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\ssv.dll" SIZE="434279" CHECKSUM="0x4E83B310" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="ssv.dll" INTERNAL_NAME="ssv" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x7191B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="JVM\bin\tnameserv.exe" SIZE="53392" CHECKSUM="0x3B8540BB" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="tnameserv.exe" INTERNAL_NAME="tnameserv" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:03:12" UPTO_LINK_DATE="09/07/2006 22:03:12" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\unicows.dll" SIZE="245400" CHECKSUM="0x226D997F" BIN_FILE_VERSION="1.0.4011.0" BIN_PRODUCT_VERSION="1.0.4011.0" PRODUCT_VERSION="1.0.4011.0" FILE_DESCRIPTION="Microsoft Layer for Unicode on Win9x Systems (MSLU)" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft (R) Windows (R) 95, Windows (R) 98, and Windows (R) Millennium Operating Systems" FILE_VERSION="1.0.4011.0" ORIGINAL_FILENAME="UnicoWS.dll" INTERNAL_NAME="Godot.dll" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x41644" LINKER_VERSION="0x60000" UPTO_BIN_FILE_VERSION="1.0.4011.0" UPTO_BIN_PRODUCT_VERSION="1.0.4011.0" LINK_DATE="03/10/2003 22:59:25" UPTO_LINK_DATE="03/10/2003 22:59:25" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\unpack.dll" SIZE="61566" CHECKSUM="0x536847B7" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="unpack.dll" INTERNAL_NAME="unpack" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x16FBE" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:09" UPTO_LINK_DATE="09/07/2006 23:06:09" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\unpack200.exe" SIZE="127101" CHECKSUM="0x2D7B0B" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="unpack.dll" INTERNAL_NAME="unpack" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:04:20" UPTO_LINK_DATE="09/07/2006 22:04:20" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\verify.dll" SIZE="49252" CHECKSUM="0x7A01B3FB" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="verify.dll" INTERNAL_NAME="verify" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1072C" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:09" UPTO_LINK_DATE="09/07/2006 23:06:09" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\w2k_lsa_auth.dll" SIZE="24692" CHECKSUM="0x874B9E58" BIN_FILE_VERSION="1.5.0.0" BIN_PRODUCT_VERSION="1.5.0.0" PRODUCT_VERSION="1.5.0_07.0" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0_07" FILE_VERSION="1.5.0_07.0" ORIGINAL_FILENAME="w2k_lsa_auth.dll" INTERNAL_NAME="w2k_lsa_auth" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x12A25" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.5.0.0" UPTO_BIN_PRODUCT_VERSION="1.5.0.0" LINK_DATE="09/07/2006 23:06:09" UPTO_LINK_DATE="09/07/2006 23:06:09" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\zip.dll" SIZE="61547" CHECKSUM="0xA4FB5883" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="zip.dll" INTERNAL_NAME="zip" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x15878" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:09" UPTO_LINK_DATE="09/07/2006 23:06:09" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="JVM\bin\client\jvm.dll" SIZE="1613945" CHECKSUM="0x69A9A0B2" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java HotSpot(TM) Client VM" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jvm.dll" INTERNAL_NAME="jvm" LEGAL_COPYRIGHT="Copyright © 2005" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1974E1" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:09" UPTO_LINK_DATE="09/07/2006 23:06:09" VER_LANGUAGE="Language Neutral [0x0]" />
    <MATCHING_FILE NAME="Microsoft.VC80.DebugCRT\msvcm80d.dll" SIZE="1015808" CHECKSUM="0x4753EC37" BIN_FILE_VERSION="8.0.50727.762" BIN_PRODUCT_VERSION="8.0.50727.762" PRODUCT_VERSION="8.00.50727.762" FILE_DESCRIPTION="Microsoft® C Runtime Library" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Visual Studio® 2005" FILE_VERSION="8.00.50727.762" ORIGINAL_FILENAME="MSVCM80D.DLL" INTERNAL_NAME="MSVCM80D.DLL" LEGAL_COPYRIGHT="© Microsoft Corporation.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFEFD5" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.50727.762" UPTO_BIN_PRODUCT_VERSION="8.0.50727.762" LINK_DATE="12/02/2006 06:52:14" UPTO_LINK_DATE="12/02/2006 06:52:14" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="Microsoft.VC80.DebugCRT\msvcp80d.dll" SIZE="1036288" CHECKSUM="0x4FB8414E" BIN_FILE_VERSION="8.0.50727.762" BIN_PRODUCT_VERSION="8.0.50727.762" PRODUCT_VERSION="8.00.50727.762" FILE_DESCRIPTION="Microsoft® C++ Runtime Library" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Visual Studio® 2005" FILE_VERSION="8.00.50727.762" ORIGINAL_FILENAME="MSVCP80D.DLL" INTERNAL_NAME="MSVCP80D.DLL" LEGAL_COPYRIGHT="© Microsoft Corporation.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x104491" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.50727.762" UPTO_BIN_PRODUCT_VERSION="8.0.50727.762" LINK_DATE="12/02/2006 06:52:51" UPTO_LINK_DATE="12/02/2006 06:52:51" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="Microsoft.VC80.DebugCRT\msvcr80d.dll" SIZE="1175552" CHECKSUM="0xADEB8523" BIN_FILE_VERSION="8.0.50727.762" BIN_PRODUCT_VERSION="8.0.50727.762" PRODUCT_VERSION="8.00.50727.762" FILE_DESCRIPTION="Microsoft® C Runtime Library" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Visual Studio® 2005" FILE_VERSION="8.00.50727.762" ORIGINAL_FILENAME="MSVCR80D.DLL" INTERNAL_NAME="MSVCR80D.DLL" LEGAL_COPYRIGHT="© Microsoft Corporation.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x12E0C9" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.50727.762" UPTO_BIN_PRODUCT_VERSION="8.0.50727.762" LINK_DATE="12/02/2006 06:50:26" UPTO_LINK_DATE="12/02/2006 06:50:26" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="Microsoft.VC80.DebugMFC\mfc80d.dll" SIZE="2404352" CHECKSUM="0xB5D5C1F5" BIN_FILE_VERSION="8.0.50727.762" BIN_PRODUCT_VERSION="8.0.50727.762" PRODUCT_VERSION="8.00.50727.762" FILE_DESCRIPTION="MFCDLL Shared Library - Debug Version" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Visual Studio® 2005" FILE_VERSION="8.00.50727.762" ORIGINAL_FILENAME="MFC80D.DLL" INTERNAL_NAME="MFC80D.DLL" LEGAL_COPYRIGHT="© Microsoft Corporation.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2598F1" LINKER_VERSION="0x80000" UPTO_BIN_FILE_VERSION="8.0.50727.762" UPTO_BIN_PRODUCT_VERSION="8.0.50727.762" LINK_DATE="12/02/2006 08:05:12" UPTO_LINK_DATE="12/02/2006 08:05:12" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="Microsoft.VC80.DebugMFC\mfc80ud.dll" SIZE="2406912" CHECKSUM="0x563BF969" BIN_FILE_VERSION="8.0.50727.762" BIN_PRODUCT_VERSION="8.0.50727.762" PRODUCT_VERSION="8.00.50727.762" FILE_DESCRIPTION="MFCDLL Shared Library - Debug Version" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Visual Studio® 2005" FILE_VERSION="8.00.50727.762" ORIGINAL_FILENAME="MFC80UD.DLL" INTERNAL_NAME="MFC80UD.DLL" LEGAL_COPYRIGHT="© Microsoft Corporation.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2569E5" LINKER_VERSION="0x80000" UPTO_BIN_FILE_VERSION="8.0.50727.762" UPTO_BIN_PRODUCT_VERSION="8.0.50727.762" LINK_DATE="12/02/2006 08:06:49" UPTO_LINK_DATE="12/02/2006 08:06:49" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="Microsoft.VC80.DebugMFC\mfcm80d.dll" SIZE="114688" CHECKSUM="0x7BEBE154" BIN_FILE_VERSION="8.0.50727.762" BIN_PRODUCT_VERSION="8.0.50727.762" PRODUCT_VERSION="8.00.50727.762" FILE_DESCRIPTION="MFC Managed Library - Debug Version" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Visual Studio® 2005" FILE_VERSION="8.00.50727.762" ORIGINAL_FILENAME="MFCM80D.DLL" INTERNAL_NAME="MFCM80D.DLL" LEGAL_COPYRIGHT="© Microsoft Corporation.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1C80B" LINKER_VERSION="0x80000" UPTO_BIN_FILE_VERSION="8.0.50727.762" UPTO_BIN_PRODUCT_VERSION="8.0.50727.762" LINK_DATE="12/02/2006 08:09:11" UPTO_LINK_DATE="12/02/2006 08:09:11" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="Microsoft.VC80.DebugMFC\mfcm80ud.dll" SIZE="102400" CHECKSUM="0xF65DA344" BIN_FILE_VERSION="8.0.50727.762" BIN_PRODUCT_VERSION="8.0.50727.762" PRODUCT_VERSION="8.00.50727.762" FILE_DESCRIPTION="MFC Managed Library - Debug Version" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Visual Studio® 2005" FILE_VERSION="8.00.50727.762" ORIGINAL_FILENAME="MFCM80UD.DLL" INTERNAL_NAME="MFCM80UD.DLL" LEGAL_COPYRIGHT="© Microsoft Corporation.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1F6DE" LINKER_VERSION="0x80000" UPTO_BIN_FILE_VERSION="8.0.50727.762" UPTO_BIN_PRODUCT_VERSION="8.0.50727.762" LINK_DATE="12/02/2006 08:09:27" UPTO_LINK_DATE="12/02/2006 08:09:27" VER_LANGUAGE="English (United States) [0x409]" />
    <MATCHING_FILE NAME="SWF_Components\AlternateReporting\AlternateReporting.exe" SIZE="12288" CHECKSUM="0x2D610552" MODULE_TYPE="WIN32" PE_CHECKSUM="0x7B28" LINKER_VERSION="0x0" LINK_DATE="07/21/2009 19:22:14" UPTO_LINK_DATE="07/21/2009 19:22:14" />
    <MATCHING_FILE NAME="swf_templates\CPSwf9Template.dll" SIZE="3817936" CHECKSUM="0x3D2AB480" BIN_FILE_VERSION="5.0.0.596" BIN_PRODUCT_VERSION="5.0.0.596" PRODUCT_VERSION="5.0.0.596" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.0.596" ORIGINAL_FILENAME="CPSwf9Template.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3B12E8" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.596" UPTO_BIN_PRODUCT_VERSION="5.0.0.596" LINK_DATE="05/21/2010 19:55:56" UPTO_LINK_DATE="05/21/2010 19:55:56" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
<EXE NAME="MSVCR90.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
    <MATCHING_FILE NAME="msvcr90.dll" SIZE="653120" CHECKSUM="0x16090A79" BIN_FILE_VERSION="9.0.30729.4137" BIN_PRODUCT_VERSION="9.0.30729.4137" PRODUCT_VERSION="9.00.30729.4137" FILE_DESCRIPTION="Microsoft® C Runtime Library" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Visual Studio® 2008" FILE_VERSION="9.00.30729.4137" ORIGINAL_FILENAME="MSVCR90.DLL" INTERNAL_NAME="MSVCR90.DLL" LEGAL_COPYRIGHT="© Microsoft Corporation.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xA761F" LINKER_VERSION="0x90000" UPTO_BIN_FILE_VERSION="9.0.30729.4137" UPTO_BIN_PRODUCT_VERSION="9.0.30729.4137" LINK_DATE="06/26/2009 20:51:49" UPTO_LINK_DATE="06/26/2009 20:51:49" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
<EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
    <MATCHING_FILE NAME="kernel32.dll" SIZE="989696" CHECKSUM="0x2D998938" BIN_FILE_VERSION="5.1.2600.5781" BIN_PRODUCT_VERSION="5.1.2600.5781" PRODUCT_VERSION="5.1.2600.5781" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="5.1.2600.5781 (xpsp_sp3_gdr.090321-1317)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFE572" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.5781" UPTO_BIN_PRODUCT_VERSION="5.1.2600.5781" LINK_DATE="03/21/2009 14:06:58" UPTO_LINK_DATE="03/21/2009 14:06:58" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
</DATABASE>
Sep 26, 2010 Sep 26, 2010
Hi BlueShift,
Thanks for sharing the txt file. Unfortunately it does not contain any pointer to the crash other than dll names & versions.
The crash message dialog snapshots that you posted in the beginning of this thread show your system details as Windows NT build 5.1. I think it should display Windows XP with installed Service Pack number. I think XP SP3 is the ideal combi. Please check if you have the latest service packs installed.
Can you please run one more test? Start new recording in "Full motion" mode. End the recording after few seconds. Ideally a project with a single slide should get created with an FMR swf attached to it. Let us know what happened.
Cheers
Siva
Sep 27, 2010 Sep 27, 2010
I noticed where it said it was and NT build.I'm not sure why.
Here is a screenshot from the computer with the system specs.
I tried the full motion record test and got the same runtime error when I ended the recording after a couple of seconds. The program then crashed with the same information you saw in the .txt. file. Thanks for looking at this.
I'm having this problem as well, running Captivate 5 on Windows XP SP3. As soon as I try to record (in any mode, even just leaving it run for one snapshot) I get a crash almost immediately. It also occurs if you start a blank project, then insert a recording slide, within a few moments it crashes with similar looking messages.
That seems to describe exactly what I've been experiencing. Thanks for adding your voice to the mix. By any chance are you running older versions of Captivate on your system as well?
>>> And1000 <forums@adobe.com> 9/27/2010 1:52 PM >>>
I did have Captivate 4 installed (as part of Tech Comm Suite version 2), but updated to Captivate 5 (as part of Tech Comm Suite version 2.5).
Oct 03, 2010 Oct 03, 2010
I am having the same issue with the trial version of Captivate 5 whic
h I just downloaded and installed. It either crashes or will do the following - I can open Cap 5, click
on Blank Project, set screen res and the minute I click on the record bu
tton everything disappears! All I can see is m
y desktop background image! all icons have disappeared. The taskbar
at the bottom of the screen will not respond.
The Alt/Tab wont bring up the other open applications.
The only way I can get out of this is to Crtl/Alt/Del and select is to Logoff or Shutdown.
If I click Task Manager nothing happens.
My system matches the minimum requirements to run Cap 5.
I have a HP Compaq nw9440 laptop. Ducore processor.
Windows xp
I do have Captivate 3 also installed on the computer and have never had issues
with that version.
Any help suggestions welcomed.
cheers
Gerry
Guest
Oct 04, 2010 Oct 04, 2010
@gerry_mcat and And1000:
will it be possible for you to install Captivate 5 on a machine that does not have any earlier version of captivate and try this workflow of recording.
-Manish
blogs.adobe.com/captivate
I have installed it on another system that has not had Captivate installed previously (that is using a virtual desktop set up, the user has full administrative rights) and the crash continues to occur. I have installed it locally on a laptop (that had Captivate 4 installed) and it is working OK, but this is only a short term solution.
Enthusiast ,
Hello There,
Can we do a connect session to see the issue? Please mail me to viswanat@adobe.com so that we can proceed further on how to do the connect session.
Vish
I have continued to investigate the issue I have been having. I came across a suggestion by someone that I should 'Clear the Cache' which is found under Edit>>Preferences (button located under Project Cache path). I did this and it seems to have fixed the issue of all objects disappearing from my screen and just displaying my desktop minus all icons. I have been using Captivate 5 over the last 2 days and this issue has not appeared. I have however have another releated issue where Cap 5 crashes when recording.. this is happening when I am recording and have the 'Automatic Panning' option selected... It will start OK and after about 20-30 secs of recording the application crashes.     I have yet to try recording with 'Manual Panning' I will do and see how I get on.
cheers
Gerry
Guest
Hi Gerry,
Could you try this:
1. Go to preferences dialog at Recording: FMR
2. In the Working Folder, set 'C:\Test' - basically set the temp folder in your root directory.
Now try your workflow : Automatic Recording + Panning.
Do let us know the results.
- Manish
Oct 05, 2010 Oct 05, 2010
Hi Manish
Thank you so much for your advice! I have done what you selected below and that seems to have solved the issue! Thanks for your time with this issue.
Cheers
Gerry
Gerry McAteer
Training Technologist - HCLC
Tel: +61 08 9428 5248
144 Stirling Street Perth Western Australia 6000
Guest
Glad to hear that...
Others may also try this:
Manish
blogs.adobe.com/Captivate
PS - if you believe above steps solved your issue, please mark the post appropriately so that others can be equally benefitted.
Help resources
