Conversion from RH7 to RH8 hangs on 1 of 5 projects - no err msg
Sep 28, 2010 Sep 28, 2010
I have successfully converted 4 of 5 RH7 projects. The one project that won't convert doesn't have anything special or different about it. It is not my most complex project nor my simplest.
Once the conversion starts the meter bar goes about 1/3 of the distance then RH8 locks up (stops responding). No error message is presented.
Pre conversion I removed the projects from RSC, removed read only attribute, and deleted .cpd.
I have tried the solution from this thread http://forums.adobe.com/message/2312324  (open the .hhp, selecting Noto the xpj prompt.) with no change in the result.
Obviously the problem is with the project, but I don't know what else to try. Is there a conversion log or some way to know what file is being converted when it locks up?
Specifics
OS = XP with all patches
RH = 8.0.2.208
Project location = C:\TW_Local\RoboHelpProjects  (not a networked folder )
Project history =Originally an MS Word file, converted to RH6, converted to RH7
Project zip size = 28MB
Thanks for any help or ideas.
John
309
You could check if the rhvariable.apj file is blank. If it is, copy one from a working project. Or see snippet 79 on Peter Grainge's site which contains code you can paste in. The problem manifested in RH6, but it's possible it's still an issue in RH8.
The rhvariable.apj looks fine. Contains tags for each variable in the project.
RoboHelp Documentation
Download Adobe RoboHelp
