q1)where do i set screen dimensions?
q2)how can i set the images position on screen without using the imageLoaded function because I need to display many images and dont want to create this imageLoaded for every image.
package
import flash.display.Sprite;
public class atest1 extends Sprite
import flash.display.Bitmap;
import flash.display.Loader;
import flash.events.Event;
import flash.net.URLRequest;
public function atest1()
var loader:Loader = new Loader;
loader.contentLoaderInfo.addEventListener(Event.COMPLETE, imageLoaded);
loader.load(new URLRequest("ladybug.png"));
//loader.x=200;
//loader.y=100;
private function imageLoaded(event:Event):void
var image:Bitmap = new Bitmap(event.target.content.bitmapData);
addChild(image);
//image.x=200;
//image.y=10;
var li:atest1= new atest1 ()
You can use a double loop and increase
x and y positions for every loader.
NOt sure wheat you mean
can you give me an exampe?
here is an example (with just one loop):
var array:Array=["url1","url2","url3"]; // u should fill that array somehow with more data...
var wid:Number=150;
var hei:Number=100;
var x_counter:int=0;
var y_counter:int=0;
var columns:int=4;
function loaderFunc():void{
for (var i:Number = 0; i < array.length; i++){
var thumb_url = array.toString();
var thumb_loader = new Loader();
thumb_loader.load(new URLRequest(thumb_url));
thumb_loader.x = (wid+10)*x_counter;
thumb_loader.y = (hei+10)*y_counter;
addChild(thumb_loader);
if (x_counter+1 < columns){
x_counter++;
} else {
x_counter = 0;
y_counter++;
An easier way is using paramters in the constructors but it doesnt work??
why does this code fail to load anything without an error?
package
import flash.text.*;
private var myy:int;
private var myx:int;
private var txt1:TextField = new TextField();
public function atest1(x:int,y:int)
myx=x;
myy=y;
loader.load(
txt1.text =
"Text1";
addChild(txt1);
image.x=myx;
image.y=myy;
addChild(image);
var
li:atest1= new atest1(10,200); //doesnt workCopy link to clipboard
Scene 1, Layer 'Layer 1', Frame 1, Line 1 1198: Attributes are not allowed on package definition.
Scene 1, Layer 'Layer 1', Frame 1, Line 2 1084: Syntax error: expecting identifier before mult.
Scene 1, Layer 'Layer 1', Frame 1, Line 4 1037: Packages cannot be nested.
Scene 1, Layer 'Layer 1', Frame 1, Line 6 1084: Syntax error: expecting identifier before mult.
Scene 1, Layer 'Layer 1', Frame 1, Line 9 1071: Syntax error: expected a definition keyword (such as function) after attribute *, not public.
Scene 1, Layer 'Layer 1', Frame 1, Line 9 1084: Syntax error: expecting rightbrace before leftbrace.
Scene 1, Layer 'Layer 1', Frame 1, Line 50 1071: Syntax error: expected a definition keyword (such as function) after attribute *, not private.
You will need again a loop if you wanna use more than one image (and calculate each time x and y positions)
I thought AS3 was OOP?
I cant pass paramters in constructors so I need to pass them when an imge is loaded .
If I need to load 3 images how do i do this in as3 without constructors????
var li:atest1= new atest1("img1");
var li:atest1= new atest1("img2");
var li:atest1= new atest1("img3");
it works.
You need to use:
var li:atest1= new atest1(10,200);
addChild(li);
no it doesnt work.
Here is my whole code and I get1 error with addchild
package
SWF(backgroundColor="blue", width="400",height="300")]
SWF(backgroundColor="0x00ff00", width="400",height="300")]
private var img1:String;
public function atest1(myimage:String)
img1=myimage;
myx=100;
myy=100;
loader.load(
new URLRequest(img1));
image.x=myx;
image.y=myy;
addChild(image);
var li:atest1= new atest1("ladybug.png");
var addChild(li);
it works.
Please download my example (fla+as) and test it.
I have flashbuilder and
my code has changed a little since then as you can see.
Could you try my current code where I want to load a file by passing the filename in the constructor?
Might be flashbuilder is no good.
i cant open fla files so could you paste it?
I did it before:
codes in fla file:
var aa:atest1=new atest1(33,44);
addChild(aa);
The .as file is in the Rar file and with Flashbuilder you can open it.
no no that is not the file that is old code and I get an error with addchild in flashbuilder
What I wanted to do is pass the string of the image to display
package
I suspect my flashbuilder isnt working so could some one try my code on the next post above and just load any image.
I spent hours on this and all I need is someone to verify if this does work.
Then I can look at my installation.
