I have the same rectangle at the top and bottom of a presentation as a classification banner. When I add text to the rectangle using right-click | Add Text, the text looks aligned exactly as I wish, centered on both the x- and y-axis. However, once previewed or published, the text appears to be aligned at the top of the rectangle. Does anyone else have this issue? Should I just lay a transparent caption over the shape, instead of using Add Text?
Oh, sorry, I was talking about CP5-issue.
In CP4 I always used a transparent text caption on top of a shape, did not like the functionality of the Text in shape there for different reasons (alignment being one of them), especially that it will not nicely flow in a shape (oval, polygon).
Lilybiri
Hello,
Did you perhaps insert a variable in the Text? This is a known issue, that alignment is going awry then, not only in shapes but also in Text Captions. If you use a Transparent Text Caption you can indeed rearrange.
Lilybiri
Nope, no variables here. I think I'll have to move to transparent captions for the time being. Thanks, Lilybiri.
Do you think Adobe might patch Cp4 for this and other known issues? Or must we upgrade to Cp5 to reap any new benefits?
Thanks again.
Hi there
Well, I'll put it this way. I wouldn't hold my breath waiting for a Captivate 4 patch.
It's a lot more likely to see a Captivate 5 patch emerge.
Cheers... Rick
Helpful and Handy Links Begin learning Captivate 5 moments from now! $29.95 Captivate Wish Form/Bug Reporting Form |
Thanks, as always, Rick. I think I'll just have to find some way to fudge it into the right position; I'm sure I'll come up with something. Going to Cp5, unfortunately, is not an option. I like the Cp3/Cp4 interface better, anyway.
Lilybiri
