Locked
Force flash builder 4 plugin localization
Sep 28, 2010 Sep 28, 2010
Hello there,
I've successfully installed the flash builder 4 plugin in a Spring Tool Suite IDE. The IDE is localized in english, but the text content related to flash builder appears in french, as my operating system is localized in french (I didn't choose that ). Could someone please tell me if there is a conventional way to set up the english localization ?
Thanks for your help.
Installation and activation
603
Eclipse/java will default to the system locale settings, but you can override that by using two lines such as these at the top of your eclipse.ini file:
-nl
en_US
-Chris
Sep 29, 2010 Sep 29, 2010
Hello,
Thank you for your answer. I've solved the issue yesterday by adding the option -Duser.language=en to my eclipse.ini file. Do you think I should change to your configuration ?
Yann
The alternate argument you used should be fine too - no need to change it if it's working the way you want now.
-Chris
