Someone please help!
I would like for my presenter presentation to play within my own website.
1) I have published my files locally to my desktop.
2) I have uploaded this folder to a space on my server hosted by hostgator.
Now that the files are there, how do I make the presentation play so that users can see this? I would like for users to click on a hyperlink that goes to the presentation.
I've tried using iframe but cannot get it to work. Which file should I call?
Detailed instructions would be VERY helpful!!!
First you create your Presenter project and then publish it for My Computer /
The on your website, create a sub directory off of your root web site:
http://www.yourwebsite.com/new_dicrectory
Then upload your project to the new subdirectory.
Point your browser to http://www.yourwebsite.com/new_directory and the index.htm file will load automatically and run your project from your web site.
It will also work if you point to http://www.yoursite.com/new_directory/index.htm.
Good luck.
With the files being a SWF format you shouldn't have any problems. I am thinking that it could be the server itself. It may be set up in a way to not allow streaming of files over a certain size to control bandwith useage. What is the prezo's file size?
When you click on the link to the prezo what do you get? Nothing? error message?
I was under the impression that the main file that you should link/point to is the "index.htm" file within the adobe presenter folder output.
There are several swf files located within the folder but I believe that index.htm should activate all these files to play the entire presentation.
When I click on the link that I created, it lands back on the homepage of my website.
Has anyone uploaded these files to their own server and made it work?
~P
Good luck.
Thank you Hollis Santee for answering this! Worked like a charm!
