25 Replies Latest reply: Sep 30, 2010 11:17 PM by Todd_Kopriva RSS
    Titles
    Jarliei Community Member
      File>New> Title>ok to name the title.
      what is the purpose of the frame with the centre markers in the "Title" window?
        • 1. Re: Titles
          Powered by Design Community Member
          Are you talking about the Safe Title Margin & Safe Action Margin lines ?
          GLenn
          • 2. Re: Titles
            I did not know that's what it is called, so I say yes.
            it seems as some kind of a template, but what for?
            I was able to exceed all it's parameters by movements of the handles, which make me think that it is not a template.
            • 3. Re: Titles
              Those are the safe zones when making you video for the TV
              TV's are not all the same size so these zones are there to make sure you keep your important stuff inside it so most people will be able to see it.
              If you ever watch something and the text goes off screen you know they went to far and that is why.
              If you are doing web content then you can turn it off and use the full screen.
              GLenn
              • 4. Re: Titles
                As a fun experiment I would take photoshop and draw those lines and place them in some test video to see how they showed up on my TV's.
                My Plasma HD TV showed almost all but my old TV cut away allot.
                GLenn
                • 5. Re: Titles
                  How did you get this spify looking 3D inner frame?
                  • 6. Re: Titles
                    re safe zones - ok, they are an indication rathsome kind of a template
                    er then a restrictive border?
                    • 7. Re: Titles
                      Garbled typing, sorry
                      re safe zone - ok, so they are an indication template rather then a restrictive border?
                      • 8. Re: Titles
                        yes, there just there for a reference so your video shows correctly.
                        the gray checker pattern is just what shows up when you uncheck the background.
                        If you click the little EYE with the video button it turns off the background and this will show.
                        If you dont like the lines showing you can turn them off by unchecking them.
                        Are you making videos for TV or for the internet ?
                        There there only for TV's
                        GLenn
                        • 9. Re: Titles
                          My old TV would not show anything outside the Action Safe line so if I put something there nobody would see it on a TV like my old one.
                          GLenn
                          • 10. Re: Titles
                            Ok, I got it.
                            yes I am editing it all for TV, these are family footage's shot over the last 45 years. I can not specify a TV system for viewing as my doughter have an old B&W CRT due to the fact that man kind have not resolved the issue of Landfills and as such she will not dispose of it. My middle son has the "latest" model CRT (colour thanks haven!) and he will keep it untill the TV will cark it so as to save on the green gas or something that are emited during TV manufacturing ( hmm?) my youngest son is still bending my ear for an advance on his inheritance so he can refurnish his household and buy a 60" plasma TV and I say bugger it all, I have a beutifull B&O plasma TV and enjoyeing every minute of it.
                            So I would not have a clue which TV system I should consider when I edit these footage. I just do it.
                            • 11. Re: Titles
                              and the spify frame?
                              • 12. Re: Titles
                                Since your going for TV then I would say just stay within the Title Safe Area and you will be fine.
                                ENjoy:  GLenn
                                • 13. Re: Titles
                                  what 3D frame ?
                                  are you talking about the checker pattern ?
                                  GLenn
                                  • 14. Re: Titles
                                    Bill Hunt CommunityMVP
                                    In PS, one can get those "Guides" by going to Image>New (Ctrl+N), and then choosing the NTSC 720 x 480 Standard w/ Guides (or other, depending on where one is located, and on the Project's Preset). Then, use the Pen Tool to create a Path over those Guides, and Stroke those Paths, with say the Pencil and 3 pixels. Use a bright color for the Stroke, so you can clearly see where the Guides are. I'd use red for one, and blue for the other. Save_As PSD and Import that into PrPro. Now, Export to the desired format/author a DVD, and display on the TV's. See where the Stroked Guides display.
                                    The outer is the Action Safe Area, and the inner is the Title Safe Area.
                                    These will become a little less relevant over time, as flat panel TV's replace CRT's. There still might be some overscan, but it will diminish over what it once was.
                                    Hunt
                                    • 15. Re: Titles
                                      Ann Bens CommunityMVP
                                      I think he means the two margins
                                      makes it look like its 3D. Does on mine too.
                                      But when you enlarge the screendump its gone.
                                      • 16. Re: Titles
                                        Yes, the thumbnail of GLenn's image DOES have an embossed look. The expanded view does not. Neat!!!!
                                        Hunt
                                        • 17. Re: Titles
                                          expeditionwest Community Member
                                          I'd certainly like an advance on that inheritence as well. My next project needs some serious funding.
                                          LOL
                                          expeditionwest
                                          • 18. Re: Titles
                                            You are talking to the wrong person....
                                            • 19. Re: Titles
                                              Ann / Bill
                                              thanks, so I guess I'll be wasting my time creating it. thanks again.
                                              • 20. Re: Titles
                                                Ann,
                                                re your post #15.
                                                Unlike post #1, the attached image does not respond.
                                                • 21. Re: Titles
                                                  Well, you could create a rectangular Shape, with no Fill and a small Stroke. Then, add a Drop Shadow to it.
                                                  [Edit]
                                                  No, the Drop Shadow did not do it. In PS, one could Emboss, but unless CS5's Titler has added some Styles, not sure how to do it in Titler. Will play around a bit, and see what I come up with.
                                                  Hunt
                                                  Message was edited by: Bill Hunt - Added [Edit]
                                                  • 22. Re: Titles
                                                    I'll try; I first thought it was a template, hence my question.
                                                    Talking of which, in addition to those furnished with PP, are there anywhere Title templates available for downloading?
                                                    • 23. Re: Titles
                                                      Bill,
                                                      re title templates.
                                                      PP has a great collection of spiffy titles which in style and design, are relevant to 2010.
                                                      But what about say movies shot in the 40’s? maybe a Movitone type Title?
                                                      The 50’s – maybe the Title should be relevant to say the then high world political tension?
                                                      The 70’s – Technology?
                                                      The 80’s - World economical stability?
                                                      The 90’s – beginning of the computer era?
                                                      The Naughty’s – WFC?
                                                      Or others.
                                                      Note that I did not mention the 60’s, as I was there I don’t remember it.
                                                      • 24. Re: Titles
                                                        There are probably sources of such Titles, but I do not know them.
                                                        Probably the easiest way to come by them is to create them. While Tilter is a powerful little program, Photoshop would be unlimited. The general designs could come from studying the ads of a particular era, or of a genre. As one reflects on the graphic arts of each era/genre, certain design elements will start to show up more often. Treatments will reflect that place in time.
                                                        If I run across a collection of PRTL (PrPro's Title Templates), I will share the links.
                                                        Good luck,
                                                        Hunt
