SOLVED
connection problem with sharepoint livecycle
Avatar
Level 4
Good morning
We write this email because we have problems relating to 'LiveCycleES2 integration with Sharepoint.
Both applications were installed on a 'single virtual machine running Windows Server 2008.
As a basis for the installation we have followed the following pdf
http://www.scribd.com/doc/38462381/Adobe-Connector-Forms-Share-Point-Install-Config
(view link)
in all its configurations, the problem arose
during the creation of services through the workbench as shown in this video: http://vimeo.com/9378807.
The process created is to fill out a form and then stored as a document. Pdf sharepoint static.
In creating the service, we stopped in the part for sharepoint or in connection with the component CreateDocument.
All  'component's internal process described above is the card properties in  the document library and information site where in site URL should load  the various sites created on sharepoint and all sub-sites which you can  not see.
Thanks for the 'attention, waiting for reply.
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
Some more queries on the behavior:-
  1. I can see you specified some Document Library in the field. Is this a case that earlier things were working but stopped in between?
  2. What you can try out is specify the SiteURL by yourself, in the format as http://serverName/SiteName (something similar that you use to access Sharepoint server through browser). Once done with that, invoke the process and let us know the error you get.
  3. You are trying out things with SharePoint 2007 or Sharepoint 2010?
  4. What is the IIS Authentication mode selected? That setting is available at Central Administration > Application Management > Authentication Providers > Edit Authentication in Sharepoint 2007. Can you attach a snapshot of LoginSettings in workbench along with the Authentication mode selected in Sharepoint for the website you are trying to access.
  5. Also, can you please attach the server and workbench logs? Are you using Jboss turnkey?  Default server logs directory in that case is <jboss\server\lc_turnkey\log> and that for workbench is C:\Documents and Settings\<Profile>\Workbench ES2\.metadata
Avatar
We'll need some more information from you in this regard like where exactly are you stuck at. What is the exception are you getting?
Can you elaborate a little on the statement:-
Avatar
Level 4
as  you can see from the site when I click the button, I see all the sites  and in SharePoint sites, which unfortunately does not happen
Avatar
Correct answer by
Avatar
Level 4
1 I can see you specified some Document Library in the field. Is this a case that earlier things were working but stopped in between?
I created a site in sharepoint, I can not see through the workbench
2010-09-30 16:17:35,765 ERROR [com.adobe.livecycle.crc.sharepoint.utils.Transliterator] org.apache.axis2.AxisFault: Transport error: 401 Error: Unauthorized
    at org.apache.axis2.transport.http.HTTPSender.handleResponse(HTTPSender.java:296)
    at org.apache.axis2.transport.http.HTTPSender.sendViaPost(HTTPSender.java:190)
    at org.apache.axis2.transport.http.HTTPSender.send(HTTPSender.java:75)
    at org.apache.axis2.transport.http.CommonsHTTPTransportSender.writeMessageWithCommons(CommonsHTTPTransportSender.java:371)
    at org.apache.axis2.transport.http.CommonsHTTPTransportSender.invoke(CommonsHTTPTransportSender.java:209)
    at org.apache.axis2.engine.AxisEngine.send(AxisEngine.java:448)
    at org.apache.axis2.description.OutInAxisOperationClient.send(OutInAxisOperation.java:401)
    at org.apache.axis2.description.OutInAxisOperationClient.executeImpl(OutInAxisOperation.java:228)
    at org.apache.axis2.client.OperationClient.execute(OperationClient.java:163)
    at com.microsoft.schemas.sharepoint.soap.AuthenticationStub.Mode(AuthenticationStub.java:317)
    at com.adobe.livecycle.crc.sharepoint.session.SessionProvider.isAuthenticationModeForms(SessionProvider.java:121)
    at com.adobe.livecycle.crc.sharepoint.session.SessionProvider.authenticateStub(SessionProvider.java:68)
    at com.adobe.livecycle.crc.sharepoint.utils.SharePointInteractionUtils2007.getImmediateDocumentLibrariesWithinASite(SharePointInteractionUtils2007.java:122)
    at com.adobe.livecycle.crc.sharepoint.utils.SharePointInteractionUtils2007.getImmediateDocumentLibrariesWithinASite(SharePointInteractionUtils2007.java:61)
    at com.adobe.livecycle.crc.sharepoint.utils.SharePointHelperUtils2007.updateDocumentLibraryDataCache(SharePointHelperUtils2007.java:504)
    at com.adobe.livecycle.crc.sharepoint.MSSharePointCRCServiceImpl.getAllDocumentLibrariesList(MSSharePointCRCServiceImpl.java:1645)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.java:118)
    at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor.java:140)
    at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptorChainImpl.java:60)
    at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.intercept(DocumentPassivationInterceptor.java:53)
    at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(TransactionInterceptor.java:74)
    at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTransactionCMTAdapterBean.java:357)
    at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doSupports(EjbTransactionCMTAdapterBean.java:227)
    at sun.reflect.GeneratedMethodAccessor777.invoke(Unknown Source)
    at org.jboss.invocation.Invocation.performCall(Invocation.java:359)
    at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionContainer.java:237)
    at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:158)
    at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstanceInterceptor.java:169)
    at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:63)
    at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:121)
    at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:378)
    at org.jboss.ejb.plugins.TxInterceptorCMT.invoke(TxInterceptorCMT.java:181)
    at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:168)
    at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
    at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor.java:138)
    at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:648)
    at org.jboss.ejb.Container.invoke(Container.java:960)
    at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:430)
    at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:103)
    at $Proxy384.doSupports(Unknown Source)
    at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvider.java:104)
    at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInterceptor.java:72)
    at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStrategyInterceptor.java:55)
    at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateInterceptor.java:37)
    at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterceptor.java:188)
    at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
    at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:121)
    at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:129)
    at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.invoke(AbstractMessageReceiver.java:329)
    at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invokeCall(SoapSdkEndpoint.java:139)
    at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invoke(SoapSdkEndpoint.java:81)
    at sun.reflect.GeneratedMethodAccessor887.invoke(Unknown Source)
    at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
    at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
    at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
    at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
    at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
    at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
    at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
    at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
    at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
    at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
    at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
    at com.adobe.idp.dsc.provider.impl.soap.axis.InvocationFilter.doFilter(InvocationFilter.java:43)
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
    at com.adobe.idp.um.auth.filter.CSRFFilter.doFilter(CSRFFilter.java:41)
    at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
    at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:230)
    at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
    at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:179)
    at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:84)
    at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
    at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:104)
    at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:157)
    at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
    at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:241)
    at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
    at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:580)
    at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
    at java.lang.Thread.run(Unknown Source)
from what I understand is a permission problem, but I am the administrator I have all the permissions to work
3. You are trying out things with SharePoint 2007 or Sharepoint 2010??
SharePoint 2007
I did not understand
yes, using Jboss turnkey
log  workbench today:
!SESSION 2010-09-30 10:01:42.703 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_07
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
Framework arguments:  #Product Runtime Configuration File
Command-line arguments:  -os win32 -ws win32 -arch x86 #Product Runtime Configuration File
!ENTRY com.adobe.ide.singlesignon 1 1 2010-09-30 10:01:45.279
!MESSAGE LiveCycle Workbench ES version '9.0.0'
!ENTRY com.adobe.ide.singlesignon 1 1 2010-09-30 10:02:15.252
!MESSAGE User 's.administrator' logged in to server '192.168.12.101' (hostname: '192.168.12.101')
!SESSION 2010-09-30 14:21:17.188 -----------------------------------------------
!ENTRY com.adobe.ide.singlesignon 1 1 2010-09-30 14:21:19.832
!ENTRY com.adobe.ide.singlesignon 1 1 2010-09-30 14:21:36.734
!SESSION 2010-09-30 16:16:29.818 -----------------------------------------------
!ENTRY com.adobe.ide.singlesignon 1 1 2010-09-30 16:16:32.559
!ENTRY com.adobe.ide.singlesignon 1 1 2010-09-30 16:16:51.761
!ENTRY org.eclipse.ui 4 0 2010-09-30 16:17:35.905
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: null argument:
    at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:86)
    at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:74)
    at org.eclipse.jface.viewers.StructuredViewer.assertElementsNotNull(StructuredViewer.java:578)
    at org.eclipse.jface.viewers.StructuredViewer.getRawChildren(StructuredViewer.java:938)
    at org.eclipse.jface.viewers.ColumnViewer.getRawChildren(ColumnViewer.java:703)
    at org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren(AbstractTreeViewer.java:1330)
    at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeViewer.java:385)
    at org.eclipse.jface.viewers.AbstractTreeViewer.getFilteredChildren(AbstractTreeViewer.java:636)
    at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildren(AbstractTreeViewer.java:602)
    at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer.java:799)
    at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
    at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:776)
    at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:634)
    at org.eclipse.jface.viewers.AbstractTreeViewer.internalInitializeTree(AbstractTreeViewer.java:1490)
    at org.eclipse.jface.viewers.TreeViewer.internalInitializeTree(TreeViewer.java:823)
    at org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractTreeViewer.java:1474)
    at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1365)
    at org.eclipse.jface.viewers.TreeViewer.preservingSelection(TreeViewer.java:397)
    at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1328)
    at org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(AbstractTreeViewer.java:1467)
    at org.eclipse.jface.viewers.ContentViewer.setInput(ContentViewer.java:251)
    at org.eclipse.jface.viewers.StructuredViewer.setInput(StructuredViewer.java:1603)
    at com.adobe.livecycle.crc.sharepoint.editor.type.MSSharePointDocumentLibraryPickerDialog.createRepositoryComposite(MSSharePointDocumentLibraryPickerDialog.java:93)
    at com.adobe.livecycle.crc.sharepoint.editor.type.common.MSSharePointItemPickerDialog.createDialogArea(MSSharePointItemPickerDialog.java:124)
    at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java:760)
    at org.eclipse.jface.window.Window.create(Window.java:431)
    at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
    at org.eclipse.jface.window.Window.open(Window.java:790)
    at com.adobe.livecycle.crc.sharepoint.editor.type.common.MSSharePointItemPickerDialog.open(MSSharePointItemPickerDialog.java:98)
    at com.adobe.livecycle.crc.sharepoint.editor.common.MSSharePointItemPathEditorEclipseUIComponent$2.widgetSelected(MSSharePointItemPathEditorEclipseUIComponent.java:207)
    at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:228)
    at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
    at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3823)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3422)
    at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2382)
    at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
    at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2198)
    at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
    at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:288)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:488)
    at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
    at com.adobe.lcide.rcp.Application.start(Unknown Source)
    at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:193)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
    at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Avatar
Error indicates an authentication failure which actually makes my 4th point very valid.
1.
In SharePoint Configuration Manager, you can configure the Authentication type  and Authentication mode SharePoint site should use. These could be either of Forms, Windows or Web Single Sign on and  Windows Authentication or  Basic Authentication. See snapshot for details:-
2. Also I would ask you to double check the hint section of Username field in workbench. Specifically are you  following this:-
3. What is the site that you trying to connect to ? Is it on the default 80 port or some other? Also can you paste in your hostname/username/domain settings here?
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
