6 Replies Latest reply on Oct 1, 2010 12:04 PM by AntonyM6-sPksqC
    2 columns for credits
    AntonyM6-sPksqC
      Typically, the credits for a film/programme with be in 2 columns, with the role/job in a right-aligned left column and the person's name in a left-aligned right column.
      I know how to do this in Premiere.
      But to do it in After Effects I have to create the titles in Illustrator, then import the AI file, then animate it.
      This is sucha standard requirement, that surely by now there must be a way to do this within After Effects?
      Or if not, does anyone know why not?
        • 1. Re: 2 columns for credits
          Szalam Adobe Community Professional & MVP
          I've done it in AE.
          Make two text boxes, one aligned to the right and the other aligned to the left. Parent one to the other.
          • 2. Re: 2 columns for credits
            AntonyM6-sPksqC Level 1
            Sure you can do that in some cases. But notably not if you have different font sizes
            for the Role and the Actor, because then the boxes will get out of alignment.
            However it is still a "hack" rather than being properly implemented, as it is in Premiere.
            • 3. Re: 2 columns for credits
              Todd_Kopriva Level 8
              If you have a request for an additional feature in After Effects, please submit a feature request.
              You can animate and lay out text and graphics any way that you wish in After Effects. As a general philosophy, we tend to provide extreme flexibility and power rather than focusing on making a specific and narrow case a little easier. This tends to make After Effects very popular with professional motion graphics artists and compositors, who don't want to be constrained by narrowly designed and implemented features.
              • 4. Re: 2 columns for credits
                AlexCzet
                As Todd said, AE is not a "titling" program.
                You can do exactly what you want, but you may have to dig deeper than an out of the box solution.
                In this case you can just create your two layers of texts in precomps and align them the way you wish (make the precomp the Y scale of the entire title sequence) and then just animate in the main comp with Motion Blur
                HTH
                Alex
                • 5. Re: 2 columns for credits
                  bogiesan-gyyClL Level 3
                  After Effects is not a typogrpahical tool although it's got amazing text capabilities. Similarly, I would not use AE's video layers to do editing, I'd use an NLE.
                  Regardless of the perceived need to have AE do everything, the typical workflow for film credits is to have someone design the typography in an illustration application, hand the file to AE for the special effects, timing, and compositing in AE.
                  Typography tools form outfits like Boris can do dual column text elements using a gutter but the results are not necessarily what a filmmaker would want in a feature.
                  bogiesan
                  • 6. Re: 2 columns for credits
                    Hi Todd,
                    Thanks for the link to request a feature.
                    However, WRG your comment "we tend to provide extreme flexibility and power rather than focusing on making a specific and narrow case a little easier."
                    I don't think that supporting left and right aligned tabs in the text box counts as " a specific and narrow case" :-)
                    Antony
