You didn't say what the output is but I am guessing it is
webhelp, otherwise you would not have those files. Do you have a
whole bunch of files that start wh*?
If you do, then you are looking at output.
The source files would have been on the PC of the author, at
least, they should have been. Possible that was wiped when they
left? If so, you will need to find backups of the source by search
across the whole network. I believe Google's desktop search will
only work on local drives. Copernic's desktop can be configured to
search across network drives.
If all else fails, you are into reverse engineering.
Click
here.
Let us know how you get on. Good luck.
