Robo 8 - HTML Help - Navigation Options
Can somebody assist me in understanding from what dialog do you globally enable; synchronize the TOC with the topic in the right pane so that users see where they are in the structure (using the F1 command) when navigating the .chm file?
Download Help indicates; To synchronize the TOC automatically, click the pop-up menu and select Automatically. I'm having some difficulty locating this pop-up menu and Automatic selection item?
Initially, I thought synchronizing of the TOC with topics in the right pane defaults automatically after setting related hyperlinks throughout various topics (then generating) in project? Apparently not?
Any help with this question is greatly appreciated.
Thank you,
robert
Welcome to our community!
I just recorded a brief video. Hopefully it will help you out.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 moments from now - $24.95! |
Hello again
Sorry, but I just sort of assumed you were creating Microsoft HTML Help output (CHM format). The process is slightly different if you are using WebHelp or FlashHelp. And I'm not sure it even applies if your output type is AIR Help.
Please let me know if the first response nailed it or if I did the unthinkable by assuming.
Cheers... Rick
Yes - HTML Help output (.chm format).
Nailed it!
Outstanding!
Thanks Rick for the speedy response, visual resolution, and releated RH 8 refs.
Great job,
robert
