If you are going to be dealing with a large amount of
submissions, DO NOT insert 'to be approved' submissions into the
same table with 'live' submissions. If you do, when you run your
queries, you have to run against submissions that are 'not
approved' and code for their existence, which can slow down your
processing.
Create another table, ex. pending_approval, to hold new
submissions waiting for approval, including a column called
'approved' to pending_approval. Set default value of column
'approved' to -1.
Review records in pending_approval, update column 'approved'
either 0 or 1, 0 = not approved, 1 = approved. Run another query to
insert approved=1 records from pending_approval into your 'live'
table. Check approved records have inserted successfully, then
delete records (using same query or separate query) from
pending_approval where approved > -1.
