Locked
Flash Bulder+MySQL,PHP - Channel disconnected before an acknowledgement was received
Sep 27, 2010 Sep 27, 2010
Hi, I tried some basics with Flash Builder and PHP MySQL. I walked throught this tutorial http://www.flashrealtime.com/flash-builder-4-and-php-data-services/ but when I added a function btnSearch_clickHandler and launched the project in browser to test it, it gave me this error:
I don't know why is this happening. I followed the tutorial step by step. The only difference is that I use Windows 7 with WAMP and Tomas uses MacOS with MAMP
I uploaded my project http://www.mediafire.com/file/6ri44igt1hbssrf/phpConnect.zip , can someone take a look at it please? Thanks
6.1K
New Here , Jul 13, 2011 Jul 13, 2011
Even if you are using Wamp it's the same, I want to remind you that you have to use port 3306 during the connection setup inside your Flex IDE.20110713-i19-281kb.jpg
Message was edited by Aldo Marsilio www.flashbackstage.com
Message was edited by: aldo marsilio
Adobe Employee ,
What does it tell when you use the Test operation to call the same operation in Flash Builder?
Sunil
Test operation - Service: EmployeesService; Operation: getAllEmployees
InvocationTargetException:There was an error while  invoking the operation. Check your operation inputs or server code and try  invoking the operation again.
Reason:
Warning:  mysqli_connect() expects parameter 5 to be long, string given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  44
Warning: mysqli_error() expects parameter 1 to be  mysqli, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  259
Warning: mysqli_prepare() expects parameter 1 to be  mysqli, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  60
Warning: mysqli_stmt_execute() expects parameter 1 to  be mysqli_stmt, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  64
Warning: mysqli_stmt_bind_result() expects parameter 1  to be mysqli_stmt, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  69
Warning: mysqli_stmt_fetch() expects parameter 1 to be  mysqli_stmt, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  71
Warning: mysqli_stmt_free_result() expects parameter 1  to be mysqli_stmt, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  77
Warning: mysqli_close() expects parameter 1 to be  mysqli, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  78
    /0/onResult˙˙˙˙ � Uflex.messaging.messages.AcknowledgeMessage correlationId clientId destination messageId timestamp timeToLive headers  body IC8EF4525-730F-BAB2-DBAB-83FBBE072AC9 I65CC210E-A04D-CC48-4ADA-000037765A55  I06052A08-C992-9588-1B12-00005079FAB8  128561039300
And the PHP file is like this:
<?php
*  README for sample service
*  This generated sample service contains functions that illustrate typical service operations.
*  Use these functions as a starting point for creating your own service implementation. Modify the
*  function signatures, references to the database, and implementation according to your needs.
*  Delete the functions that you do not use.
*  Save your changes and return to Flash Builder. In Flash Builder Data/Services View, refresh
*  the service. Then drag service operations onto user interface components in Design View. For
*  example, drag the getAllItems() operation onto a DataGrid.
*  This code is for prototyping only.
*  Authenticate the user prior to allowing them to call these methods. You can find more
*  information at http://www.adobe.com/go/flex_security
class EmployeesService {
    var $username = "root";
    var $password = "";
    var $server = "localhost";
    var $port = "";
    var $databasename = "test";
    var $tablename = "employees";
    var $connection;
     * The constructor initializes the connection to database. Everytime a request is
     * received by Zend AMF, an instance of the service class is created and then the
     * requested method is invoked.
    public function __construct() {
          $this->connection = mysqli_connect(
                                  $this->server,
                                  $this->username,
                                  $this->password,
                                  $this->databasename,
                                  $this->port
        $this->throwExceptionOnError($this->connection);
     * Returns all the rows from the table.
     * Add authroization or any logical checks for secure access to your data
     * @return array
    public function getAllEmployees($q) {
    $sql = "SELECT * FROM $this->tablename WHERE first_name LIKE '%$q%' OR last_name LIKE '%$q%' OR email_address LIKE '%$q%'";
    $stmt = mysqli_prepare($this->connection,$sql);
    $this->throwExceptionOnError();
    mysqli_stmt_execute($stmt);
    $rows = array();
    mysqli_stmt_bind_result($stmt, $row->emp_no, $row->birth_date, $row->first_name, $row->last_name, $row->gender, $row->hire_date, $row->phone_no, $row->email_address, $row->job_title);
    while (mysqli_stmt_fetch($stmt)) {
      $rows[] = $row;
      $row = new stdClass();
    mysqli_stmt_free_result($stmt);
    mysqli_close($this->connection);
    return $rows;
     * Returns the item corresponding to the value specified for the primary key.
     * Add authorization or any logical checks for secure access to your data
     * @return stdClass
    public function getEmployeesByID($itemID) {
        $stmt = mysqli_prepare($this->connection, "SELECT * FROM $this->tablename where emp_no=?");
        mysqli_stmt_bind_param($stmt, 'i', $itemID);
        if(mysqli_stmt_fetch($stmt)) {
          $row->birth_date = new DateTime($row->birth_date);
          $row->hire_date = new DateTime($row->hire_date);
          return $row;
        } else {
          return null;
     * @return stdClass
    public function createEmployees($item) {
        $stmt = mysqli_prepare($this->connection, "INSERT INTO $this->tablename (birth_date, first_name, last_name, gender, hire_date, phone_no, email_address, job_title) VALUES (?, ?, ?, ?, ?, ?, ?, ?)");
        mysqli_stmt_bind_param($stmt, 'ssssssss', $item->birth_date->toString('YYYY-MM-dd HH:mm:ss'), $item->first_name, $item->last_name, $item->gender, $item->hire_date->toString('YYYY-MM-dd HH:mm:ss'), $item->phone_no, $item->email_address, $item->job_title);
        $autoid = mysqli_stmt_insert_id($stmt);
        return $autoid;
     * Updates the passed item in the table.
     * @param stdClass $item
     * @return void
    public function updateEmployees($item) {
        $stmt = mysqli_prepare($this->connection, "UPDATE $this->tablename SET birth_date=?, first_name=?, last_name=?, gender=?, hire_date=?, phone_no=?, email_address=?, job_title=? WHERE emp_no=?");
        mysqli_stmt_bind_param($stmt, 'ssssssssi', $item->birth_date->toString('YYYY-MM-dd HH:mm:ss'), $item->first_name, $item->last_name, $item->gender, $item->hire_date->toString('YYYY-MM-dd HH:mm:ss'), $item->phone_no, $item->email_address, $item->job_title, $item->emp_no);
     * Deletes the item corresponding to the passed primary key value from
     * the table.
     * @return void
    public function deleteEmployees($itemID) {
        $stmt = mysqli_prepare($this->connection, "DELETE FROM $this->tablename WHERE emp_no = ?");
     * Returns the number of rows in the table.
    public function count() {
        $stmt = mysqli_prepare($this->connection, "SELECT COUNT(*) AS COUNT FROM $this->tablename");
        mysqli_stmt_bind_result($stmt, $rec_count);
        mysqli_stmt_fetch($stmt);
        return $rec_count;
     * Returns $numItems rows starting from the $startIndex row from the
     * table.
     * @return array
    public function getEmployees_paged($startIndex, $numItems) {
        $stmt = mysqli_prepare($this->connection, "SELECT * FROM $this->tablename LIMIT ?, ?");
        mysqli_stmt_bind_param($stmt, 'ii', $startIndex, $numItems);
        $rows = array();
          $rows[] = $row;
        return $rows;
     * Utility function to throw an exception if an error occurs
     * while running a mysql command.
    private function throwExceptionOnError($link = null) {
        if($link == null) {
            $link = $this->connection;
        if(mysqli_error($link)) {
            $msg = mysqli_errno($link) . ": " . mysqli_error($link);
            throw new Exception('MySQL Error - '. $msg);
Adobe Employee ,
Sep 28, 2010 Sep 28, 2010
So, looks like there are errors when passing parameters, can you check your code are just hardcode the parameters for time being to check whether everything is working fine.
-Sunil
Oct 03, 2010 Oct 03, 2010
Ok, I tried to not to change the generated PHP code and launch function getAllEmployeesResult.token = employeesService.getAllEmployees(); instead of getAllEmployeesResult.token = employeesService.getAllEmployees(txtSearch.text);
still the same error
Adobe Employee ,
Oct 04, 2010 Oct 04, 2010
What is the error when you try to run it from Test operation from the Data/Services panel?
Reason:
Warning: mysqli_error() expects parameter 1 to be  mysqli, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  258
Warning: mysqli_prepare() expects parameter 1 to be  mysqli, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  58
Warning: mysqli_stmt_execute() expects parameter 1 to  be mysqli_stmt, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  61
Warning: mysqli_stmt_bind_result() expects parameter 1  to be mysqli_stmt, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  66
Warning: mysqli_stmt_fetch() expects parameter 1 to be  mysqli_stmt, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  68
Warning: mysqli_stmt_free_result() expects parameter 1  to be mysqli_stmt, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  76
Warning: mysqli_close() expects parameter 1 to be  mysqli, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  77
    /0/onResult˙˙˙˙ � Uflex.messaging.messages.AcknowledgeMessage correlationId clientId destination messageId timestamp timeToLive headers  body I22F739C2-7008-D1FF-4C6F-C37EF031B6F4 I37DE091D-AC33-2488-4A61-00002154B7E3  I204A7F21-8C87-90C9-E2B3-0000211F7CC6  128622908400
Feb 09, 2011 Feb 09, 2011
i know this is an old post but in case someone stumbles onto it with the same problem, having just started with Flex, and using Xampp I had the same problem, but once I specified the port to mysql as 3306 - this problem stopped.
Hope it helps.
