Show 2 replies
1. Re: Unexpected color shift
Steve Fairbairn Oct 5, 2010 4:45 PM (in response to peterpica)This can be caused by saving a CMYK file with an embedded colour profile.
Some rips are sensitive to profiles and will produce a cast like you describe.
The general rule is to use embedded profiles only on RGB files (so that they can be correctly converted to CMYK).
I have seen this kind of thing happen several times – usually the cast is towards magenta but I've seen yellow too.
In my books CMYK files with colour profiles are a no-no.
2. Re: Unexpected color shift
peterpica Oct 5, 2010 6:12 PM (in response to Steve Fairbairn)Thanks Steve. I'm resubmitting the file, saved as you suggest (no profile)...
I'm also awaiting Partner's response to the problem as the job's on hold until resolution.
Regards.
