Error Coldfusion Report Builder Arabic Text and Query Output
Guest
Oct 06, 2010 Oct 06, 2010
Anyone has an idea on how to work with cfr with arabic text and query output...
in my query output the arabic text is working fine but when i run the cfr the arabic text got an error the text is REVERSED.
any help?
Builder
1.5K
Enthusiast ,
works for me: http://www.sustainablegis.com/unicode/testCFR.pdf
what db? unicode? right font? identity-h?
never seen cf/cfdocument/etc reverse BIDI text, unless it was already reversed
in the first place.
Guest
im using oracle db...
coldfusion report builder 8.
i dont know why is the arabic text is reversed please help!!!
even if i write an arabic text and then i run the cfr the text is also reversed
here's the reversed text
Enthusiast ,
is there a public example of the report as plain html and cfr/pdf i can see to
compare? failing that can you make an example CFR & attach it here so i can see
what it's doing?
Guest
please see the attached image... for sample reversed arabic text...
the arabic text is reversed...
Enthusiast ,
that's not going to help. please re-read last post.
Enthusiast ,
http://forums.adobe.com/servlet/JiveServlet/showImage/43683/arab.jpg
simple test of the forums replying, please ignore.
Guest
Oct 07, 2010 Oct 07, 2010
hi paul got any solutions? ill tried also the report in pdf but the arabic text appears in (?) please help....
Enthusiast ,
if you're seeing "?" then its clearly an encoding problem.
as far as the report goes, unless i can see the actual report & output vs plain
cf/html output there's nothing much i can do but guess.
Guest
hi paul thanks for the reply... for more info about my program here's some details...
its a simple webform with a select query... i want to print the webform using the coldfusion report builder 8.0.. im using oracle 10g database...
if i choose the cfr output into excel, html and doc the arabic text and arabic query output is correct and appearing... but once i choose pdf or flashpaper the arabic text is not working...
in flashpaper the arabic text is reversed and in pdf the arabic text is in "?"
i want to have the output in pdf or flashpaper... any got idea?
thank you so much...
Enthusiast ,
Oct 08, 2010 Oct 08, 2010
sorry but that really doesn't tell me anything that i didn't already know.
please re-read what i posted & answer those questions.
Documentation
