1. Re: How to get text on a path upside down?
P Spier Oct 7, 2010 6:27 AM (in response to Twinklewoo)You need to do two paths on top of each other and thread the text between them. You should see three handles for the text. The ones onthe end have in and out ports like a regular text frame and indicate the begining and end of where the text will be positioned. There's a third on inthe center that can be harder to spot. It looks like an inverted T and you can grab and drag it to the other side of the path to reverse the direction.
2. Re: How to get text on a path upside down?
BobLevine Oct 7, 2010 6:32 AM (in response to Twinklewoo)You'll need to use circles on top of each other.
You might find putting them on two different layers will make it easier to work with.
Bob
3. Re: How to get text on a path upside down?
[Jongware] Oct 7, 2010 6:39 AM (in response to Twinklewoo)I think all text is supposed to point the same way, for a single path ...
But it shouldn't be a problem. Copy the entire thing, delete half of the text; do the same on the copy (delete the other half, of course), and in the Text Path Options click "Flip".
(Ed.) Okay, Peter got it right: use the In and Out ports to thread the text strings into one.
4. Re: How to get text on a path upside down?
Twinklewoo Oct 7, 2010 6:44 AM (in response to Twinklewoo)Perfect! Problem solved - thanks so much for that - very much appreciated - much better now!!
em
5. Re: How to get text on a path upside down?
Harbs. Oct 7, 2010 6:58 AM (in response to BobLevine)Or create one circle and cut the path in the middle. That'll give you two perfect arcs...
Harbs
Innovations in Automation
