I am not a coder so studied this page for how to add a bcc to the form's submit button:
http://acrobatusers.com/tutorials/modifying-livecycle-designer-form-submit-button
I added the bcc only (not the rest of the code -- that was generated in Livecycle) below (see red text) as per the information provided in the above link.
<event activity="click">
<submit format="xml" target="mailto:louise.bachman@ucr.edu?subject=Final CONACYT Narrative Report&bcc=andrea.kaus@ucr.edu" textEncoding="UTF-8"/>
</event>
It's not working. I actually need to add two bcc addresses. A disclaimer: The first address: mailto:louise.bachman@ucr.edu, was generated in the design preview. That worked fine. I added the bcc code under the xml tab. However, again, not being a coder, if someone could please tell me how to properly add the bcc addresses.
Thank you.
Total Likes
I've worked on this some more, but LiveCycle won't let me save the document. This is the code:
<submit format="xml" target="mailto:david.kropf@ucr.edu?subject=Final CONACYT Narrative Report&bcc=andrea.kaus@ucr.edu&bcc=martha.ponce@ucr.edu" textEncoding="UTF-8"/>
</event>
This is the error message I get:
Total Likes
There shoudl ony be one mailto command in the string and the addresses shoudl be separated by a comma. The string shoudl be like this:
<submit format="xml" target="mailto:david.kropf@ucr.edu?subject=Final CONACYT Narrative Report&bcc=andrea.kaus@ucr.edu,martha.ponce@ucr.edu" textEncoding="UTF-8"/>
</event>
Hope that helps
Paul
Total Likes
