I recently re-installed CF Builder as a plugin to FB4 on a Mac. Before doing that, I completely uninstalled the standalone, including all preferences and hidden files.Things were working just fine for over a week until today. First I got a couple of strange Java errors right after trying to stop a debug session. So I restarted FB4 and continued working. Then up popped the Adobe Updater saying it had "Update 1" for CF Builder ready to install. I thought I already installed it but wasn't sure so I said ok. Big mistake. After it finished the install, I rebooted FB4 and now every file tab that had a CF page open has a big red square and an error that says it can't find the right editor.
What do I do now? Can I back out the update? Is there a setting I need to change?
Dana
ColdFusion Builder requires you to start with -clean option after updater is run as plugin.Do you want to try this once.
As you are saying FB is standalone and CF Builder is installed as plugin please try launching the Flash Builder as
FB Home>./Adobe\ Flash\ Builder\ 4.app/Contents/MacOS/Adobe\ Flash\ Builder\ 4 -clean
Krishna
I sent your message to the installer contact on the CF Builder team to see if he's familiar with it, or has a workaround. I'll keep you posted as I learn more.
Meanwhile, I found these KB articles that might help:
CF Builder Update 1 issues:
http://kb2.adobe.com/cps/846/cpsid_84607.html
FB 4.0.1 issues (see the entries about CF Builder):
http://kb2.adobe.com/cps/840/cpsid_84098.html
-Chris
Krishna
Thanks, that worked!
