I've done this many times in the past with prior versions (opening two instances of Captivate) but I'm having issues figuring out the process in Captivate 5 for Mac. I don't think I'm able to open multiple instances with 5, but I feel certain there is a way to do this that I'm just not seeing. A nudge in the right direction would be much appreciated. I'm working on an iMac i7 (snow leopard) at work and a macBookPro i7 at home.
Thanks much,
susanne
Hi there,
Follow these steps to launch second instance of Captivate:
1. Open the 'Terminal'
2. Type the commands shown in the image below:
This should launch the second instance of Captivate 5 on MAC.
-Manish
blogs.adobe.com/Captivate
Hello,
I'm not on Mac but on PC, but I often do recordings of Captivate 5 with another instance of CP5. Some captions will not be correct (sometimes it shows as 'Click on the top-level window' and will have to be edited, but otherwise this works great. Since I'm on Win I can also capture CP5 with CP4 but prefer working with CP5 and accept the little bit of extra editing.
Lilybiri
Can you document the process you are using to record Captivate 5 with 5? I have Captivate 4 on P.C.s and I have done it many times. I've got the eLearning suite2 (with 5) on laptop and desktop Mac only. I really need to use the Mac if it is at all possible, but it doesn't work the way that it has in the past so I do need some help.
Hi there,
-Manish
