When I try and run FlexPMD from the command line or through Maven Site I get the following exception:
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(Unknown Source)
com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(Unknown Source)
Exception in thread "main" java.lang.StringIndexOutOfBoundsException: String index out of range: -15
at java.lang.String.substring(Unknown Source)
at com.adobe.ac.pmd.nodes.impl.MetaDataNode.compute(MetaDataNode.java:72)
at com.adobe.ac.pmd.nodes.impl.NodeFactory.createMetaData(NodeFactory.java:48)
at com.adobe.ac.pmd.nodes.impl.AbstractNode.computeMetaDataList(AbstractNode.java:59)
at com.adobe.ac.pmd.nodes.impl.FunctionNode.compute(FunctionNode.java:145)
at com.adobe.ac.pmd.nodes.impl.ClassNode.detectFunction(ClassNode.java:414)
at com.adobe.ac.pmd.nodes.impl.ClassNode.computeClassContent(ClassNode.java:366)
at com.adobe.ac.pmd.nodes.impl.ClassNode.compute(ClassNode.java:129)
at com.adobe.ac.pmd.nodes.impl.PackageNode.compute(PackageNode.java:86)
at com.adobe.ac.pmd.nodes.impl.NodeFactory.createPackage(NodeFactory.java:57)
at com.adobe.ac.pmd.files.FileSetUtils.computeAsts(FileSetUtils.java:136)
at com.adobe.ac.pmd.FlexPmdViolations.computeAsts(FlexPmdViolations.java:123)
at com.adobe.ac.pmd.FlexPmdViolations.computeViolations(FlexPmdViolations.java:102)
at com.adobe.ac.pmd.engines.AbstractFlexPmdEngine.computeViolations(AbstractFlexPmdEngine.java:161)
at com.adobe.ac.pmd.engines.AbstractFlexPmdEngine.executeReport(AbstractFlexPmdEngine.java:138)
at com.adobe.ac.pmd.commandline.FlexPMD.startFlexPMD(FlexPMD.java:119)
at com.adobe.ac.pmd.commandline.FlexPMD.main(FlexPMD.java:70)
When I run through eclipse on a small set of code it works fine. However if I try running on the whole project it never seems to finish after an hour. I am using version 1.2 on a Windows 7 box.
Here is the offending class that causes the issue:
package com.zcorum.truvizion.vo
public class MacAddress
[RemoteClass(alias="com.zcorum.enterprise.common.MacAddress"]);
public function MacAddress() {
try putting the RemoteClass tag on the class not on the constructor
Tried that and it still fails. The only way I could get it to work was to remove the RemoteClass completely. On a side note, I am getting out of memory when I run the plugin in Maven with MVN site. Suggestions?
It looks like a bug.
Could you create a ticket on JIRA?
https://bugs.adobe.com/jira/browse/FLEXPMD
About the out-of-memory error, you may need to increase the memory of your Java heap.
Can you try to remove the ';' at the end of the metadata?
Unfortunately I have removed the file and have not had time to test it. However, it seems the ']' and ')' are out of order
on the metadata. This may be causing the error.
