6 Replies Latest reply: Oct 14, 2010 11:52 AM by Pete Marshall RSS
    Filter Rating Between Stars
    anssikumpula Community Member
      Filtering between two star values is missing and needed.
      At the moment filtering supports only:
      - more than
      - less than
      - equals
      What would be needed would be:
      - between
      Nikon ViewNX 2 and Capture NX 2 have these.
      Had Lightroom 1 but started using Nikon software because of color rendering. Now that Lightroom 3 has great camera profiles for color rendering it is worth a second try. Still finding some color shades, like orange, red and yellow, to be a struggle with Nikon NEFs, though.
        • 1. Re: Filter Rating Between Stars
          Pete Marshall Community Member
          More than two and less than four, gives you three....
          • 2. Re: Filter Rating Between Stars
            areohbee Community Member
            A tool so you can use NX2 in conjunction with Lightroom.
            Personally, I like to pop into NX2 from Lightroom from time to time, for a raw conversion - mostly for comparison and to give me ideas. More often than not, I take what I learned in NX2 back to Lightroom... Sometimes I'll keep the NX2 result if there's longitudinal CA that was corrected by NX2, or I just like what I saw...
            I often finish a photo with NX2 since it has such a great distraction removal brush and u-points...
            Rob
            • 3. Re: Filter Rating Between Stars
              Dorin Nicolaescu-Musteață Community Member
              Smart collections have this.
              • 4. Re: Filter Rating Between Stars
                Thanks, but this is not working since it looks from the whole library. And adding another string to limit smart collection to just some folders or collections are not convenient since changing to another folder has to be done editing the smart collection.
                Filters top of the Library Grid view would let me focus only on pictures I want to look at but there I can't select "is in range" like with Smart Collections. Is there really this difference between Grid view Ratings Filter and Smart Collection Rating filter?
                • 5. Re: Filter Rating Between Stars
                  So how does that differ from "Rating is equal from three"...
                  I would find it useful to have "Is in range of" as it is within Smart Collections:
                  • 6. Re: Filter Rating Between Stars
                    You asked
                    Filtering between two star values is missing and needed. At the moment filtering supports only: - more than - less than - equals What would be needed would be: - between
                    LR does filter between..that is all I was pointing out.
                    But aparently you actually want something else...I'm not clear what it is even from your subsequent posts, hopefully LR engineers will be!. You can filter between star values in LR using smart collections.
