1. Re: Why is "Export Video" greyed out? I need to export an AVI (PP2.0)
Bill Hunt Oct 11, 2010 2:53 PM (in response to dstack1014)I am not sure that I am following the problem. From the screen-cap, it appears that Export>MS DV-AVI is available.
Are you saying that the Video tab (to the left) is not active, or is there something simple that I am just missing?
Good luck,
Hunt
2. Re: Why is "Export Video" greyed out? I need to export an AVI (PP2.0)
JSS1138 Oct 11, 2010 11:05 PM (in response to dstack1014)The Video option is grayed out because you can't have a DV export without video. It's always included, no way to shut it off.
3. Re: Why is "Export Video" greyed out? I need to export an AVI (PP2.0)
dstack1014 Oct 12, 2010 6:46 AM (in response to JSS1138)Problem solved. In the past, I have actually had Video mistakenly uncheck and rendered out AVI's that were audio only. (I only work with DV AVI's, although it's entirely possible a setting got switched to the non-DV.) So this time I simply panicked when I saw it grayed out and don't ever remember it being like that. Hunt, you are right that even though it was grayed out, it was still checked, so I did a test movie and the video IS there. I'm a bit embarrassed that I didn't try this sooner. I simply panicked. Thanks guys!
4. Re: Why is "Export Video" greyed out? I need to export an AVI (PP2.0)
Bill Hunt Oct 12, 2010 9:46 AM (in response to dstack1014)Most of us have felt some "panic" at one time or another.
Glad that you got it sorted, and good luck,
Hunt
