Show 8 replies
1. Re: Is it possible to access the preflight methods from the SDK?
Bernd Alheit Oct 12, 2010 12:57 AM (in response to joeln3)You can create and use Preflight Droplets.
2. Re: Is it possible to access the preflight methods from the SDK?
joeln3 Oct 12, 2010 1:07 AM (in response to Bernd Alheit)Ok but I don't think that it's possible to create and use the Preflight Dropletsvia the SDK. Which methods can I use?
Thanks in advance,
Joe
3. Re: Is it possible to access the preflight methods from the SDK?
Bernd Alheit Oct 12, 2010 2:55 AM (in response to joeln3) -
4. Re: Is it possible to access the preflight methods from the SDK?
joeln3 Oct 12, 2010 2:56 AM (in response to Bernd Alheit)Using a plug-in (Adobe Acrobat SDK).
5. Re: Is it possible to access the preflight methods from the SDK?
Bernd Alheit Oct 12, 2010 3:03 AM (in response to joeln3)In a plug-in you can use the AVCommand API set.
6. Re: Is it possible to access the preflight methods from the SDK?
lrosenth Oct 12, 2010 3:07 AM (in response to joeln3)You can access Preflight either via AVCommands or via JavaScript
Leonard
7. Re: Is it possible to access the preflight methods from the SDK?
joeln3 Oct 12, 2010 4:15 AM (in response to lrosenth)Ok thanks. So this is like a simulation of a left-click in the Preflight menu. Is it possible to hide the Acrobat UI during the process?
8. Re: Is it possible to access the preflight methods from the SDK?
lrosenth Oct 12, 2010 6:07 AM (in response to joeln3)Use OS calls to hide/minimize Acrobat.
