Hi
We have a large number of projects and want a script that, when run from a topic (the user clicks some link), picks up the project name, in the same way for example that it can pick up the topic title by using the Javascript 'document.title' .
Peter B
To quickly get the project title, use top.document.title. This will only work if the entire skin is showing. When the skin is not showing, use show(); to open the skin.
Alternatively, the following (crude) function tries to retrieve the project title for you. It either returns the title or it returns false.
function GetProjectTitle() {
if(!isTopicOnly())
var Title = top.document.title;
else
if(gsStartPage.substr(0,4) == "file")
var Title = false;
else
Hi Peter
I'm thinking the only way you can accomplish this is by populating the HTML of each topic with a JavaScript variable containing the Project Name. Then you would be able to read that variable and use it later.
Unfortunately, I don't believe there is anything in RoboHelp that will really assist much with this. So likely it will mean visiting each topic to insert the variable. I suppose you might be able to accomplish it fairly easily using a Find and Replace tool.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 moments from now - $24.95! |
if(!isTopicOnly())
else
var Title = false;
else
try {
var sRelStartFile = _getRelativeFileName(document.location.href, gsStartPage);
try {
var oRequest = new XMLHttpRequest();
catch(e) {
var oRequest=new ActiveXObject("Microsoft.XMLHTTP");
oRequest.open("GET",sRelStartFile,false);
oRequest.send(null)
var Content=oRequest.responseText;
//Quickly split the text into arrays to get the title. No bothering with DOM.
var beginTitle = /<title>/g;
var endTitle = /<\/title>/g;
var Title = Content.split(beginTitle);
var Title = Title[1].split(endTitle);
var Title = Title[0];
catch(e)
var Title = false;
return Title;
The function tries to get the content of the startpage from the server. This only works when your help is placed on a server. This function allways returns false when you call the help from a local disk.
Greet,
Willam
Neat and easy!
top.document.title gives me the project name and document.title gives the topic title.
Peter
