Query Multiple Rows As Xml Exception
Avatar
Level 3
Hi all, I got a interesting exception when retrieving multiple rows from a DB2 database and returning the result as xml.
The app server is weblogic.
ALC-DSC-119-000: com.adobe.idp.dsc.util.InvalidCoercionException: Cannot coerce object
escape illegal characters: true of type: com.adobe.idp.dsc.jdbc.bean.XmlDocumentInfoBean to type: class com.adobe.idp.dsc.jdbc.bean.XmlDocumentInfoBean
Could there be some problem in the way i do the mapping in the activity output section?
Avatar
Former Community Member
1) What version of DB2?
2) What JDBC driver you are using?
3) What data types are in the table you are querying?
4) What data types are you mapping to in the query output?
Steve
Avatar
Level 3
Thanks for the prompt reply my replies below
 9.7
Version 3.57.82 db2jcc.jar
 varchar
 the query output is xml so in the xml document info editor I can't find any way to specify data types mapping
Avatar
Hmmm. The only thing that stands out is the driver. The officially supported DB2 driver is db2jcc.jar 3.50.152.
As a rule varchar's map pretty cleanly. When you say 'the query output is xml so in the xml document info editor I can't find any way to specify data types mapping', what element level data types are you mapping to in the xml document?
Steve
Avatar
Level 3
Do you happened to have a copy of the driver? IBM website shows the supported version but doesn't provide any download links to it
Avatar
It is distributed with ES2 in the folder C:\Adobe\Adobe LiveCycle ES2\lib\db\db2.
Steve
Avatar
Level 3
yeah I take back my thanks it still doesn't work I have attached a sample lca which I used to test and the weblogic log
The jar works with jboss just fine
Avatar
Non-employees can no longer attach files given the behaviour of hackers. Please send the .lca to stwalker.adobe@gmail.com.
Steve
