1. Re: Unable to create PDF/A with PDF from InDesign
MichaelKazlow May 14, 2009 7:03 PM (in response to picarcyr)You should be using ID's PDF creation facility and be asking the question within that forum, since ID is not using Acrobat to create the pdf. Are you using the print to pdf to create the pdfs? Is so is the problem you are having unique to ID or can you do so from other apps?
2. Re: Unable to create PDF/A with PDF from InDesign
Ozzwoman9 May 15, 2009 6:43 AM (in response to picarcyr)This topic was already asked in the ID forum with no resolve (you really needed to reference that when you posted here):
3. Re: Unable to create PDF/A with PDF from InDesign
cramik Oct 14, 2010 4:52 AM (in response to Ozzwoman9)I realise this is an old thread but was wondering if anyone had actually found a solution to this problem yet.
We are experiencing the same problems. Generated an indesign PDF - tried to export to PDF/A1a but got the same errors, even with an almost empty page.
4. Re: Unable to create PDF/A with PDF from InDesign
~graffiti Oct 14, 2010 7:15 AM (in response to cramik)It may have been mentioned already but if you are "exporting" to PDF from InDesign, Acrobat is not involved so best to ask in the InDesign forum.
5. Re: Unable to create PDF/A with PDF from InDesign
cramik Oct 14, 2010 11:43 PM (in response to ~graffiti)Hi graffiti,
let me clarify my question. Indesign doesn't export to PDF/A1a.
Acrobat has to convert a tagged PDF 1.5 document generated by indesign to PDF/A1a.
If anyone could explain the errors to me:
- Structured PDF : Type entry in a structure element not "StructElem"
- Structured PDF : Type entry missing
...this would also be greatly appreciated so i can narrow my search.
Since you guys are the PDF experts and Acrobat does the conversion i believe this forum is the place to find answers.
(Also the problem has already been presented on the indesign-forum: http://forums.adobe.com/message/1959226#1959226 where the advise was to pose the question here)
6. Re: Unable to create PDF/A with PDF from InDesign
Bernd Alheit Oct 15, 2010 2:08 AM (in response to cramik)For questions about PDF language and specification use this forum:
http://forums.adobe.com/community/design_development/pdf_language_and_specifications
