Return querystring from Payment Processor
May 30, 2006 May 30, 2006
Hi, I'm struggling with something that doesn't make any senses. Hopefully,
someone has seen something similar before.
I'm decoding a return value from a payment processor (Protx). The value is
returned as an encoded value in a querystring. Here's a sample (I've
manually broke it, but it is actually one long string):
test.cfm?crypt=AxcOGx89dnl9cDcHUhM+HBQGGw4DInZlQzUHFkAULRo8DxZPKzs/XlkkDQBWA2s7IgIBHAst
P19ZOEIlVgkvACI3FywFKi4LA2dUQwJBHT8DNxcmDnMwAgZnVTJyVH9CYCcpVkd6eAIAeyYwcVRmKRVT
XStcfQ4DBWVWDhUzMy4lFwchBXN8BQJvQjJeCD4BJF5aQVN3bXdgBSclAVoKIxxDIi4+DQMQdzIAAVYUO
D01EBoDHnMGd2IVLDZ3QRsAIxcsAA4rGVNFIwgHDioKOxMrKitMDR0EZDMXBl8TdiIRNywnLwptcV8wEDJ
aA3ZfdlArPA8tPkRTBRASRxI4Uh8oSSwrGB0LexgoKQoxADUBV1w1W35yBH4dUikBMA==
It is decoded with this call:
Decoded = SimpleXor(base64Decode(strCrypt),EncryptionPassword);
If I MANUALLY copy and paste the crypt string, i.e. strCrypt =
"AxcOGx89dnl9cDcHUhM+HBQGGw4 etc, etc ";
and then run the Decoded function call above, the decode works correctly,
returning:
Status=OK&StatusDetail=Successfully Authorised
Transaction&VendorTxCode=51001&VPSTxId={4011AA34-0DF9-4346-BCB3-FE02D63E5332}&TxAuthNo=7349&Amount=5.99&AVSCV2=ALL
MATCH&AddressResult=MATCHED&PostCodeResult=MATCHED&CV2Result=MATCHED&GiftAid=0&3DSecureStatus=OK&CAVV=MNLZ9VKZQ43Z1092HK6Z2W
Of course, that isn't possible. If I use the obvious: strCrypt = URL.crypt;
the Decoded string becomes:
MAi?+?V1?=h+V??2?F???{??Kl??;?"?J�????'?H(zc?=???{?m?�;?To????A?5?+?'?k?u{??\<?Q&??mA-?#b/??F`??{?g?
I've tried lots of different combinations to get the string decoded
properly, but nothing works. What changes between the actual querystring as
viewed in the address bar of the browser and CF grabbing it? Can I do
anything to stop CF changing it? This is a standard querystring returned to
thousands of systems, so it has to be something in CF. The code used is
provided by Protx as standard.
Any help much appreciated.
Advanced techniques
631
Advisor ,
You didn't say what CF version you were using.
Anyway, use the URLDecode function. You may also need to specify the correct charset.
Advocate ,
My guess is that the + in the string is causing the problem. URL decoding changes the + to a space and I believe CF does the URL decoding for you automatically (depending on the version you are running). You may be able to simply replace all the spaces with +'s since spaces are not valid B64 encode characters. You may also have similar issues with the trailing = signs.
To confirm this, place a <!-- #string# --> in your code and view the page source (simply displaying it on the screen may hide some of the text, viewing in notepad is more reliable for this stuff). Do this for the URL parameter test and the cut & paste test and compare.
Hope this helps.
On a side note, XOR encryption/decryption is a VERY weak form of encryption and will not comply with any of the card association regs. Hopefully something stronger is being used in the production environment.
"MikerRoo" <webforumsuser@macromedia.com> wrote in message
news:e5i720$a0r$1@forums.macromedia.com...
> correct charset.
MX7 (7,0,1,116466)
This happens both on my development server and at the host (CrystalTech).
I've tried the URLDecode function, with UTF-8 and ISO-8859-1; neither makes
any difference, regrettably.
Any other ideas?
Cheers,
Advisor ,
You do not want to strip + or / -- those are vital base64 characters.
Also, the sample URL "test.cfm?crypt=AxcOGx89dnl9cDcHUhM+HBQGGw4DInZlQzUHFkAULRo8DxZPKzs/XlkkDQBWA2s7IgIBHAst
aA3ZfdlArPA8tPkRTBRASRxI4Uh8oSSwrGB0LexgoKQoxADUBV1w1W35yBH4dUikBMA=="
is not valid.
Are you taking the Protx return value and then calling a template with it?
If so, you need to use URLEncodedFormat() like so:
<CFSET decodeURL = "test.cfm?crypt=" & URLEncodedFormat (ProtxReturnValue)>
With CF7 you do not need to URL decode in test.cfm.
Finally, SimpleXor and base64Decode are not coldfusion functions. You would use BitXor and BinaryDecode.
May 31, 2006 May 31, 2006
news:e5iocd$7$1@forums.macromedia.com...
OK.
> IgIBHAst
> O
> DJ
> is not valid.
No, that's because I put in some hard returns; this is the working URL.crypt
(if I copy if from the address bar):
AxcOGx89dnl9cDcHUhM+HBQGGw4DInZlQzUHFkAULRo8DxZPKzs/XlkkDQBWA2s7IgIBHAstP19ZOEIlVgkvACI3FywFKi4LA2dUQwJBHT8DNxcmDnMwAgZnVTJyVH9CYCcpVkd6eAIAeyYwcVRmKRVTXStcfQ4DBWVWDhUzMy4lFwchBXN8BQJvQjJeCD4BJF5aQVN3bXdgBSclAVoKIxxDIi4+DQMQdzIAAVYUOD01EBoDHnMGd2IVLDZ3QRsAIxcsAA4rGVNFIwgHDioKOxMrKitMDR0EZDMXBl8TdiIRNywnLwptcV8wEDJaA3ZfdlArPA8tPkRTBRASRxI4Uh8oSSwrGB0LexgoKQoxADUBV1w1W35yBH4dUikBMA==
The crypt string above is being returned to my page by Protx. I have no
control over it; they provide functions to decode the string into valid
fields. If I manually paste in the above string, it works. If I use
URL.crypt, it doesn't. The problem therefore is that something is happening,
presumably only with CFMX7, to the qs before it is passed to the routine.
> <b><CFSET decodeURL = "test.cfm?crypt=" & URLEncodedFormat
> (ProtxReturnValue)></b>
That fails with an error: The parameter 1 of function ToBinary, which is now
"AxcOGx89dnl9cDcHUhM%20HBQGGw4DInZlQzUHFkAULRo8DxZPKzs%2FXlkkDQBWA2s7IgIBHAstP19ZOEIlVgkvACI3FywFKi4LA2dUQwJBHT8DNxcmDnMwAgZnVTJyVH9CYCcpVkd6eAIAeyYwcVRmKRVTXStcfQ4DBWVWDhUzMy4lFwchBXN8BQJvQjJeCD4BJF5aQVN3bXdgBSclAVoKIxxDIi4%20DQMQdzIAAVYUOD01EBoDHnMGd2IVLDZ3QRsAIxcsAA4rGVNFIwgHDioKOxMrKitMDR0EZDMXBl8TdiIRNywnLwptcV8wEDJaA3ZfdlArPA8tPkRTBRASRxI4Uh8oSSwrGB0LexgoKQoxADUBV1w1W35yBH4dUikBMA%3D%3D"
must be a Base-64 encoded string.
> would
No, they are functions provided by Protx. I've tried the native functions,
but they fail (BitXor in particular as that needs two integer values; the
password is a string).
Here's the simpleXor function:
function simpleXor(InString, Key) {
// Initialise key array
KeyList = ArrayNew(1);
// Initialise output variable
output = "";
// Convert $Key into array of ASCII values
// ColdFusion arrays are indexed at 1, not 0. Smart!
for(i = 1; i LTE Len(Key); i=i+1){
KeyList = Asc(Mid(Key, i, 1));
for(i = 0; i LTE Len(InString)-1; i=i+1){
// Get ASCII code from string, get ASCII code from key (loop through with
MOD), XOR the two
result = (bitXor((Asc(Mid(InString, i+1, 1))), (KeyList[(i MOD
Len(Key))+1])));
// Horrible hack to avoid problem with chr(0)
// If result is 0...
if (result eq 0){
// ...add the null character to output
output = output & urldecode("%00");
} else {
// ...add the specified character to output
output = output & Chr(result);
// Return the result
return output;
For completeness, here's the base64Decode function also:
function base64Decode(scrambled) {
output = "";
// Fix plus to space conversion issue
scrambled = Replace(scrambled," ","+");
// Do decoding
output = toString(toBinary(scrambled));
// output = ToString(BinaryDecode(scrambled,"Base64"));
return output;
"Steve Sommers" <steve@shift4.com> wrote in message
news:e5i79q$a8d$1@forums.macromedia.com...
> changes the + to a space and I beleive CF does the URL decoding for you
> to
> simply replace all the spaces with +'s sing spaces are not valid B64
> encode
> viewing
> in notepade is more reliable for this stuff). Do this for the URL
> parameter
> Hope this helps.
> encryption
> something
Thanks for the reply.
This is the base64 function:
output = "";
// Do decoding
return output;
I've already got a test page outputting various options:
<cfscript>
crypt1 =
"AxcOGx89dnl9cDcHUhM+HBQGGw4DInZlQzUHFkAULRo8DxZPKzs/XlkkDQBWA2s7IgIBHAstP19ZOEIlVgkvACI3FywFKi4LA2dUQwJBHT8DNxcmDnMwAgZnVTJyVH9CYCcpVkd6eAIAeyYwcVRmKRVTXStcfQ4DBWVWDhUzMy4lFwchBXN8BQJvQjJeCD4BJF5aQVN3bXdgBSclAVoKIxxDIi4+DQMQdzIAAVYUOD01EBoDHnMGd2IVLDZ3QRsAIxcsAA4rGVNFIwgHDioKOxMrKitMDR0EZDMXBl8TdiIRNywnLwptcV8wEDJaA3ZfdlArPA8tPkRTBRASRxI4Uh8oSSwrGB0LexgoKQoxADUBV1w1W35yBH4dUikBMA==";
crypt2 = "AxcOGx89dnl9cDcHUhM
crypt3 = URLDecode(URL.crypt,"ISO-8859-1");
crypt4 = CGI.QUERY_STRING;
crypt5 = URL.crypt;
// ** Decode the crypt field that was sent back to us **
Decoded1 = SimpleXor(base64Decode(crypt1),EncryptionPassword);
Decoded2 = SimpleXor(base64Decode(crypt2),EncryptionPassword);
Decoded3 = SimpleXor(base64Decode(crypt3),EncryptionPassword);
Decoded4 = SimpleXor(base64Decode(crypt4),EncryptionPassword);
Decoded5 = SimpleXor(base64Decode(URL.crypt),EncryptionPassword);
</cfscript>
<body>
<h3>Crypt1</h3>
<p><cfoutput>#Decoded1#</cfoutput></p>
<h3>Crypt2</h3>
<p><cfoutput>#Decoded2#</cfoutput></p>
<h3>Crypt3</h3>
<p><cfoutput>#Decoded3#</cfoutput></p>
<h3>CGI</h3>
<p><cfoutput>#CGI.QUERY_STRING#</cfoutput></p>
<h3>Crypt4</h3>
<p><cfoutput>#Decoded4#</cfoutput></p>
<h3>Crypt5</h3>
<p><cfoutput>#Decoded5#</cfoutput></p>
So you think I should do a replace on = as well?
Any other ideas?
> encryption
> something
This is actually the only method available with the payment processor.
However, the credit card details are not obtained until the user is on the
Protx site and are never passed in the URL variables.
Advocate ,
Assuming that crypt1 and crypt2 are your cut & paste and URL examples -- then simply replacing the spaces with + signs should work: crypt2=Replace(crypt2," ","+","ALL")
news:e5imfv$r9f$1@forums.macromedia.com...
Got that in the base64Decode function:
output = "";
// Do decoding
return output;
... but, my Replace function call was missing a crucial "ALL" !!! With that
in place, it works perfectly. Thanks for that; can't believe I missed it,
but something so simple could bugger it up so completely!
Thanks again <g>.
Advocate ,
Thanks again <g>.
Yeah, that bites me now and then as well as many others who have posted issues on this forum. I really think defaulting the scope to "ONE" was a design flaw since almost every language other than ColdFusion only has an "ALL" version of the replace function.
Glad it worked.
Documentation
