2010 MacBook Pro and Premiere Pro CS5
Sep 21, 2010 Sep 21, 2010
Wondering if my new MacBook Pro with NVIDIA GeForce GT 330M can handle video editing with Adobe Premiere Pro and After Effects.
Thanks in advance for your help.
28.7K
Read Harm on drive setup
http://forums.adobe.com/thread/662972?tstart=0
- click the embedded picture in Harm's message to enlarge to reading size
- you need AT LEAST 2 drives for video editing, 3 is better
- some HD formats work better with (require) RAID
Thank you for your response. Very helpful info. But this question is in regards to GPU compatibility.
Sorry if that was unclear. But, yes I do have a storage system in place for video editing. I use a DROBO with four 1TB drives for source material. This has worked well for editing in Final Cut Express. I am considering making the switch to Premiere Pro CS5 to edit HDSLR footage, as it can edit it natively without the need for transcoding. I don't see the NVIDIA GeForce GT 330M as a supported GPU and wondering if I can still take advantage of the Mercury Processing Engine.
Upon further investigation, there is a CUDA driver on the NVIDIA site that does support the GeForce GT 330M. Does anyone know if this is something I should install?
Many thanks
Certain GPUs are officially supported for hardware acceleration using the Mercury Playback Engine. This list does not include any mobile GPUs. There is a hack (do a search) to enable this capability on certain other unsupported GPUs, and some have reported success with a small number of mobile GPUs. However, the prerequisitie--official or otherwise--is that the GPU (not the system) have more than 768MB of memory. If your GPU has more memory than that, you might be able to use the hack, but I would be inclined to believe you don't have this much GPU memory with a Mac Book Pro.
Thanks Colin
My GPU only has 512 MB. So the dilemma now is -
1) Continue editing Nikon and Canon HDSLR footage with transcoding and thus some degradation via Final Cut Express?
or
2) Edit Nikon and Canon HDSLR footage natively with Premiere Pro CS5 for better looking output and suffer slower processing and rendering speeds?
Hmmmmmmm
Perhaps it will be best to wait and see what Apple's response will be to Premiere Pro CS5.
Well, the thing to keep in mind is that the Mercury Playback Engine is "on" at all times--it's just that having an approved and supported GPU accelerates certain functionality (effects, colorspace conversions, scaling). As far as raw, straightforward editing goes, that still relies primarily on the CPU, RAM and other hardware components. So, as long as your system is up to snuff, you should still have decent editing capability.
That said, H.264 (as is used by the HDSLRs) is pretty taxing on even a beefy system. My fairly recent Windows 7 build (desktop) crunches through several layers of HDSLR footage, even without hardware MPE. It's hard to say exactly what your experience would be with your MBP. I'm not positive, but I believe H.264 is available in the trial; you might download it and see how it works for your purposes.
Oct 03, 2010 Oct 03, 2010
Even with a fairly decent system, H264 is tough.  Yes technically it can be cut on Premiere, but to intercut h264 & Red footage on the same Red timeline, I have resorted to converting the h264 footage to Prores.  cuts like butter.
And Photofish, I would not recommend using that lousy FCP Express Apple intermediate codec.  You loose too much.
You can enable the hardware function of the mercury engine with the 330M in the new macbook pro's... Download CUDA for osx from nvidia, and gfxstatus (just google it, and set it to keep the nvidia chip active by default) then...
Open terminal
Now on the terminal type (adjust folders as needed)
/Applications/FOLDER\ FOR\ PREMIERE/PRO\ INSTALLATION\ Pro\ HERE/SOMETHING\ Premiere\ Pro\ CS5.app/Contents/GPUSniffer.app/Contents/MacOS/GPUSniffer
The "uppercased" words might be different for your instalation of CS5, find out yours, do not just simply copy and paste.
- Most of the times, for standard instalations, the following should work, but it will not hurt you to look the actual place where premiere was installed:
CODE
/Applications/Adobe\ Premiere\ Pro\ CS5/Adobe\ Premiere\ Pro\ CS5.app/Contents/GPUSniffer.app/Contents/MacOS/GPUSniffer
- You should get an output similar to this:
QUOTE
Texture memory: 0
Vendor string: NVIDIA Corporation
Renderer string: NVIDIA GeForce 330M OpenGL Engine
Version string: 2.1 NVIDIA-1.6.16
OpenGL version as determined by Extensionator...
OpenGL Version 2.0
Supports shaders!
Supports BGRA -> BGRA Shader
Supports VUYA Shader -> BGRA
Supports UYVY/YUYV ->BGRA Shader
Supports YUV 4:2:0 -> BGRA Shader
Testing for CUDA support...
Found 1 devices supporting CUDA.
CUDA Device # 0 properties -
CUDA device details:
Name: GeForce 330M Compute capability: 1.2
Total Video Memory: 512MB
CUDA driver version: 3020
CUDA Device # 0 supported.
Completed shader test!
Internal return value: 7
DO NOT CLOSE THE TERMINAL
ADD YOUR CARD TO THE LIST OF SUPPORTED CARDS.
On the terminal type:
CODE
sudo nano /Applications/Adobe\ Premiere\ Pro\ CS5/Adobe\ Premiere\ Pro\ CS5.app/Contents/cuda_supported_cards.txt
A new window appears, here, simply paste, at the end of the file, the name you copied earlier for your graphic card (GeForce 330M)
NOW
PRESS CTRL + X
ANSWER "Y" (stands for YES, I want to save the file)
Press enter until you get out of the editor.
NOW YOU ONLY HAVE TO FIRE UP YOUR PREMIERE AND CHOOSE YOUR HARDWARE ENABLED MERCURY ENGINE.
ENJOY.
(Btw this will work for any CUDA enabled card!!
Come on Adobe get your act together and just enable this by default! lol
Oct 05, 2010 Oct 05, 2010
Hey STUcs5,
First of all... thats a great post! I followed it very strictly but I still can't get Cuda to Operate with only 512mb on my video card. After looking at the output from GPU sniffer the only thing different to your output is the CUDA Driver version. Could this be the problem? Did you download CUDA driver version 3020 from the NIVIDIA website?
Its got me baffled why a CUDA enabled card is not compatable with CS5 regardless of how much V  RAM it has.
My GPU sniffer log is below. Any help would be fantastic.
OpenGL Version 2.0
Supports shaders!
Name: GeForce GT 330M Compute capability: 1.2
Total Video Memory: 511MB
CUDA driver version: 3010
CUDA Device # 0 not choosen because 765MB are required, and 511MB are
present.
Oct 06, 2010 Oct 06, 2010
Hi, i might have been misleading that wasn't my output, i just changed one i seen in a hack for sake of example, this is mines
Texture memory: 0
Renderer string:  NVIDIA GeForce GT 330M OpenGL Engine
Version string:   2.1 NVIDIA-1.6.18
OpenGL Version 2.0
Supports shaders!
EDIT: Are you using gfxcardstatus to force the MBP to use only the nvidia chip! http://codykrieger.com/gfxCardStatus/
It is strange as this is exactly the same as my output... could you run it again and tell me if this matches "Version string:   2.1 NVIDIA-1.6.18"
Also have you made sure you updated CUDA from the preference panel in osx system preferences...
Also there is a very up to date CUDA release here which is the developer release, basically a beta version here, you could try that, but try after you've made sure all your drivers are up to date first... http://developer.nvidia.com/object/cuda_3_2_toolkit_rc.html
I have 2 colleagues both with mid 2010 MBP's for on shoot rough editings both running the hack fine... Strange. let me know how you get on...
Message was edited by: StuCS5
Oct 07, 2010 Oct 07, 2010
Thanks again Stu,
its exactly the same = Version string:   2.1 NVIDIA-1.6.18
GFX cardstatus is running
the CUDA driver is the latest driver
I'm vexed. I might just undo a few things and start again to see if there is something majorly minor that I missed.
If I know its possible then there is no way I going to let it beat me!!
WILL
Guest
Oct 14, 2010 Oct 14, 2010
Hack is not working on my MBP either. Is this because of the VRAM requirements? Is there a MBP user out there with a 330 M and less than 1GB of VRAM successfully running this hack?
Angus
With insufficient VRAM, the hack will not work. On PC the minimum is around 896 MB, unless the UI is severly reduced. Don't know about the minimum requirements for the MAC.
Adobe Employee ,
If you want a particular video card to be supported, make a feature request. You can file a feature request here: http://www.adobe.com/go/wish. More on how to give feedback: http://bit.ly/93d6NF
By the way, if you want to make a feature request, the MacBook Pro's video card is usually the GeForce GT 330M, not the GeForce 330M—mine is.
Unfortunately the Drobo is only good for backups. For editing it is too slow.
If you have a CUDA card with at least 890+ MB VRAM, you can try the hack. Search here for the many posts on it.
Don't think you need the hack. My 2010 Macbook Pro edits HDSLR footage just fine without GPU acceleration of the MPE.
Guest
Anyone other than Death Cab For Stuie have this working on a Macbook Pro?
Angus
Oct 15, 2010 Oct 15, 2010
This is strange as i refuse to believe i'm the only one (apart from my two friends i know of) that has this working...
Guest
Stu,
Did you use the hack before the 5.02 update or after? Not sure if it matters. I have been trying with the latest updates installed.
Here is my sniffer log.
Texture memory: 0
OpenGL Version 2.0
Supports shaders!
      Total Video Memory: 255MB
CUDA Device # 0 not choosen because 765MB are required, and 255MB are present.
I did it before, and checked it was still on afterwards... The hack should work on any card with CUDA enabled (i cant say how performance will be affected with less than the recommended VRAM... Let me go through the process i did everything again as i have now noticed my original post is a little wrong...
Make sure your mac is all upto date driver wise.. Just run Software update
Download CUDA drivers from nVidia http://www.nvidia.co.uk/object/macosx-cuda-3.1.17-driver-uk.html
Download, install and run gfxCardStatus and force your mac to use only the nvidia chip.. http://codykrieger.com/gfxCardStatus/
Check CUDA is installed by looking in system preferences...
Then check gpusniffer...
Open terminal...
Now on the terminal type (adjust folders as needed)...
CODE
You should get an output similar to this: Here is my output...
Texture memory: 0
OpenGL Version 2.0
Supports shaders!
(Regardless of output try the next part anyways...)
TO ADD YOUR CARD TO THE LIST OF SUPPORTED CARDS.
CODE
Insert your card at the end of the listed cards... Your cards name is shown in the gpusniffer output.. i.e for Mid 2010 MBP as shown above "GeForce GT 330M" (i left the GT part out in my original post)
Press CTRL + X
Answer "Y" (stands for YES, I want to save the file)
Then that's it... Thats the hack, Hardware Mercury Engine should be enabled... Judging by the gpusniffer outputs that say 'device not chosen' all i can think is are you forcing the nvidia chipset with gfxstatus?
Hope that is a little clearer (remember CUDA, Gfxcardstatus forcing nvidia, add card to supported list, save, job done...)
Let me know how you get on...
Stuart
Guest
Oct 17, 2010 Oct 17, 2010
Still not working. Any other suggestions? Appreciate all the help thus far.
Angus
Thanks for the tip, Stuart. Tried the hack and it works great on my mid-2010 Macbook Pro.
Glad it is working for someone else!
Angus i'm a little stumped, let me look into it, i think google might have to be our friend here... It could well be the lack of vram...
Nov 19, 2010 Nov 19, 2010
Hi, StuCS5:
Your posts for the CS5 mods are great.  I really appreciate the detail you've added.
I'm thinking of buying a MBP to use Adobe Premiere CS5 and After Effects.  Could I get the Tech Specs for the portable you have it running on?  Any recommedations for a new purchaser wanting to buy the "best" MacBook Pro for CS5?  screen size/resolution. RAM, etc.
Thanks!!
