4 Replies Latest reply: Oct 14, 2010 4:58 PM by peterpica RSS
    'False Leading' Causing Crashes in CS5
    peterpica Community Member
      I've determined that frequent crashes in InD CS5 while exporting to PDF have been caused by my varying the leading in lengthy 3-column newsletter articles. In order to achieve 'blocked off' columns, I was varying the leading in the columns -- My default style was 10/13, but in order to accomplish even columns, I had to vary the leading from a minimum of 12.8 to a max of 13.2 (due to many pix, pull quotes, etc. throughout the columns). I had the same results (crashes) using the 'vertically justify' menu bar command.
      I'd like to report this as a bug as I can repeat the problem at will. Is there an official 'bug reporting' email address or website where I can submit?
      Thanks.
