Whenever I try to print a report for anything in this area, index, glossary, images etc I always
get an error message "Adobe Robohelp 8 has encountered a problem and needs to close etc" and program closes. Anyone know how I can fix this.
Hi there
Perhaps try deleting the project .CPD file? I stand to be corrected on this, but I believe the .CPD is where the reporting information is obtained.
Close the project, find and annihilate the .CPD (or just rename it if you are hinky about blowing it away) then re-open your project and try again.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 moments from now - $24.95! |
I can't access anything under Tools/Reports. As soon as I click on anything in this area I get the robo has encountered a problem etc message.
I have tried deleting the .cpd but unfortunately this has not fixed the problem.
Try accessing the reports via the keyboard
ALT T > ALT R
Using the keyboard didn't work. This is the error message I receive
Hi there
Out of curiosity, where is your project located? Is it on a network drive? If so, try moving the project to your local C drive and see if the problem disappears.
Cheers... Rick
I have tried moving the project to C drive. Same result.
Try with the sample projects. Not hopeful this will change anything but we need to try it.
