1. Re: A Print Bug -- PSE9 -- Print NN Copies Of Each Image
hatstead Oct 16, 2010 7:59 AM (in response to Dennis Smith)Check on the printer manufacturer's web site for updated drivers. There have been several reports where this is necessary for PSEv.8.and PSEv.9. Some printers that function with other applications turn out not to be supported for recent iterations of the program.
A work-around, if you can not get it to work via Elements and your printer, is to use WORD. Avery template 53265 will put out 2 5x7" from your paper stock.
2. Re: A Print Bug -- PSE9 -- Print NN Copies Of Each Image
Dennis Smith Oct 16, 2010 9:18 AM (in response to hatstead)My drivers are the latest -- but its all my printers (2 printers, 4 pseudo-printers - e.g. pdf printers).
When you set the NN Copies in PSE9 it sets the copies in the printer driver which is
just wrong. In the one case where copies is not supported in the printer driver you cannot
set NN Copies to other than 1 in PSE9.
Using Word would not give me access to colour profiles etc.
Thanks for the suggestions anyway
3. Re: A Print Bug -- PSE9 -- Print NN Copies Of Each Image
hatstead Oct 16, 2010 11:47 AM (in response to Dennis Smith)I have PSEv.8, and it allows me to print 2 5x7" on one page - letter size - from within the program
Here is a print screen of the dialog:
Editor, File>print and it takes one to picture package in Organizer.
4. Re: A Print Bug -- PSE9 -- Print NN Copies Of Each Image
Dennis Smith Oct 16, 2010 12:25 PM (in response to hatstead)Worked in 5 and 7 too -- I presumed it worked in 8 as I had not heard anything in the year it was out there.
Might be nice if Adobe kicked out a Beta version so that a few customers could test it and find
these things before wasting a year with issues!
5. Re: A Print Bug -- PSE9 -- Print NN Copies Of Each Image
juergen_d Oct 16, 2010 12:31 PM (in response to Dennis Smith) -
6. Re: A Print Bug -- PSE9 -- Print NN Copies Of Each Image
Dennis Smith Oct 16, 2010 12:55 PM (in response to juergen_d)Interesting solution. In fact this will work for 90% of my cases, but
its a "workaround" for what I still consider a bug.
What if I wanted a custom size (5x6 say) and wanted 2 of them on a page.
That is what the "Copies of Each Image" should be for. Note its not
"Copies of each Page" which is what the implementation appears to do,
it says "Copies of Each Image". Set that to 2 and it tries to print 2 pages,
that is still wrong.
But thank you for that workaround for my common case of wanting
multple 5x7 copies (Usually for family couples)!!!
7. Re: A Print Bug -- PSE9 -- Print NN Copies Of Each Image
juergen_d Oct 16, 2010 1:24 PM (in response to Dennis Smith)What if I wanted a custom size (5x6 say) and wanted 2 of them on a page.
You'd have to start out in the Editor and crop and size the image to 5 high and 6 wide. Then go to the print dialog and choose picture package. That will get you to the Organizer's print dialog, where you can use the exact same settings as for the 5x7, only uncheck Crop to Fit.
Juergen
8. Re: A Print Bug -- PSE9 -- Print NN Copies Of Each Image
saurabh288 Oct 24, 2010 6:24 AM (in response to juergen_d)This option was earlier present in PSE7, where you could use each photo n times and print it on a single page.
9. Re: A Print Bug -- PSE9 -- Print NN Copies Of Each Image
Dennis Smith Oct 24, 2010 4:21 PM (in response to saurabh288)saurabh288 wrote:
Hm -- the option is the same "Print NN Copies of Each Image" -- and it does not do that,
it prints "NN" Copies of each page -- which makes no sense.
This is a bug -- sorry!
