Hello,
I’m looking for a way to import a powerpoint presentation already recorded with presenter 7 into captivate. My goal is to produce a single file (like .flv) of my presentation. I didn’t understand why there is no way to do that easily between presenter and captivate. I have captivate 3 or 5. Do you have an idea to import my presentation without doing that by hand, I mean, add the powerpoint presentation into captivate, add each recorded sound, and video if necessary.
Thanks in advance for your help.
Hello and welcome to the forum,
Why not create the SWF with Presenter and insert it in Captivate (Insert Animation)? Beware however: this will only be possible with Captivate 3 because Captivate 5 is AS3 only, while Presenter 7 is still AS2 only.
If you want to work with Captivate 5, what I could understand, why not import the PPT immediately in Captivate instead of using the intermediate Presenter?
Lilybiri
Hello and thanks for your help,
Why I don’t use directly captivate, it’s because I need to convert as video some presentations that already exist.
I didn’t really understand when you said “create an swf with presenter”. When you publish a video into a folder with presenter, you have a lot of swf which correspond to each slides with other stuff. Audio files are also separate. If you know a way to have all combine in only one file with presenter, I'm interest too.
Regards.
