1. Re: Configuration Error 5
berkay unal May 6, 2010 3:09 AM (in response to Alexandre_Monteiro)I am having the same problem on CS5 Master collection MAC.
Did you find any solution? -
2. Re: Configuration Error 5
Alexandre_Monteiro May 6, 2010 9:13 AM (in response to Alexandre_Monteiro)I did not find anything about it, but i got it to work by formating my pc and installing windows 7 x32... now everything works perfectly.
I tried to use adobe flash builder, illustrator cs4 and cs5, flash catalyst cs5 and none of them worked on windows 7 x64.
3. Re: Configuration Error 5
robin1232 May 17, 2010 10:46 AM (in response to Alexandre_Monteiro)Hi,
I was experiencing the same problem, but I found a fix (Mac only, might also work on Windows):
- go to /Library/Application Support/
- delete the Adobe directory (completely remove it!)
- reinstall flash
I had Photoshop too, and it gave an error too (but it still worked) and it didn't require a reinstall.
Flash somehow had everything backed up and all my preferences were still intact.
4. Re: Configuration Error 5
C. Agruss (Adobe)May 17, 2010 12:59 PM (in response to robin1232)
For the errors reported above, please see if you find any log files named "oobelib.log" or "amt3.log" if you look in your temp folder.
On Win, you can find the temp folder this way:
- open a command window, and type "set" to view the environment variables
- navigate to the folder defined by the envvar named TMP
On Mac, you'll generally find the temp folder here:
/private/tmp/
If you find one (or both) of those log files, zip them up and attach them to this thread. If you have any trouble attaching them, try sending them to me via private forum message instead.
-Chris
5. Re: Configuration Error 5
mbierman May 25, 2010 4:05 AM (in response to C. Agruss (Adobe))I have a similar problem. I had CS4 installed. I wanted to remove everything except DW, Device Central, and Extension Manager.I used the Uninstaller and removed what I could but the following are left behind and I can't figure out how to get rid of them:
- Adobe Drive CS4
- Adobe Flash Builder 4
- Adobe Flash CS4
- Adobe Illustrator CS4
- Adobe Photoshop CS4
- Adobe Soundbooth CS4
- Adobe Soundbooth Scores
Also, Flash CS4 won't run; which is ok, but I really want to delete all of these. I wanted to attach the file requested previously, but I don't see how to attach the files to this thread.
6. Re: Configuration Error 5
StephenHarris Jul 9, 2010 9:35 AM (in response to mbierman)I've installed the trial of eLarning Suite 2 on an i7 x64 box running Win7 (brand new install) and I get the error:5 when I try to run Captivate 5 from the suite. No trouble with Dw, Br, Psx64, Sb . . . I've unsintalled, reinstalled, uninstalled using the WinCS5Cleanupscript (although no trials were ever installed prior) - still get the same results. Please help.
7. Re: Configuration Error 5
C. Agruss (Adobe)Jul 9, 2010 1:35 PM (in response to StephenHarris)
One cause for this error can be permissions on the various Adobe folders. There's a KB article about that here:
http://kb2.adobe.com/cps/827/cpsid_82744.html
That solution doesn't work for everyone though, so if you still get this error after trying those suggestions, please zip and attach the amt3.log file from your temp folder.
-Chris
8. Re: Configuration Error 5
r_s_giri Sep 2, 2010 3:08 AM (in response to Alexandre_Monteiro)Hi
After installin the eclipse plug-in on abode flash builder 4, while launching the shortcut "Adobe Flash Builder 4 Plug-in Eclipse Launcher"
getting the error message as configuration erorr:5,
Could you please help me how to solve this.
Regards
R_s_giri
9. Re: Configuration Error 5
Alexandre_Monteiro Sep 2, 2010 5:38 AM (in response to r_s_giri)Hi,
Sorry, but I can't help you very much. I've never used the plug-in for
eclipse, I've always used the stand-alone version.
I got a similar error once, I never found the source of this but I
worked around by changing my windows from x64 to x32. In x32 every thing
worked great.
Good day,
Alexadre Monteiro.
10. Re: Configuration Error 5
C. Agruss (Adobe)Sep 2, 2010 8:47 AM (in response to r_s_giri)
Hi r_s_giri,
Are you on Mac or Win?
There's a general troubleshooting matrix by error number on this page:
http://kb2.adobe.com/cps/834/cpsid_83481.html
-Chris
11. Re: Configuration Error 5
r_s_giri Sep 3, 2010 2:22 AM (in response to C. Agruss (Adobe))I am installing on Windows Xp.
Regards
R.Seshagiri Rao
Workplace Packaging
Invesco Hyderabad
VOIP 7132148918
Direct +91 40 6604111 X1252
Mobile +91 9177791678
12. Re: Configuration Error 5
C. Agruss (Adobe)Sep 3, 2010 11:21 AM (in response to r_s_giri)
One possible cause of that error is that some core libraries didn't get installed successfully.
Try running this subinstaller on its own, and see if that helps:
C:\Program Files\Adobe\Adobe Flash Builder 4 Plug-in\install.support\AdobeFlashBuilderPluginSTIWrapperWin\Set-up.exe
-Chris
13. Re: Configuration Error 5
r_s_giri Sep 6, 2010 6:20 AM (in response to C. Agruss (Adobe))Hi Chris,
Thanks for reply.
I installed "Adobe Flash Builder 4 Plug-in" silently by keeping the file "installer.properties" in which I mentioned INSTALLER_UI=silent.
This was worked.
Now how to uninstall this plug-in silently? Please help me on this.
Regards
R.Seshagiri Rao
Workplace Packaging
Invesco Hyderabad
VOIP 7132148918
14. Re: Configuration Error 5
Chermayne Sep 8, 2010 1:59 AM (in response to Alexandre_Monteiro)i'm having the exact same problem ... thing is i've already used this trial a couple of times and i only have 10 days left . why is it suddenly not working ? i use windows vista if that matters .
15. Re: Configuration Error 5
C. Agruss (Adobe)Sep 8, 2010 2:04 PM (in response to r_s_giri)
Normally, if you install silently then the uninstaller will run silently too, automatically.
That can be confusing though if you double-click the uninstaller, because there will be no visual indication that anything is happening until the uninstall completes.
-Chris
16. Re: Configuration Error 5
C. Agruss (Adobe)Sep 8, 2010 2:09 PM (in response to Chermayne)
Chermayne, have you already tried using the troubleshooting matrix here?
If that doesn't help, please zip up those log files mentioned above, and we'll take a closer look.
-Chris
17. Re: Configuration Error 5
sweezy241 Sep 13, 2010 1:42 AM (in response to Alexandre_Monteiro)Good Moorning everybody,
I had the same probleme and i use FLEX Builder 4 on Window 7 64bit.
In order to remake it work i re-installed Flex Builder on the current intallation without disintalled this one and it work.
I hope it will work for u.
18. Re: Configuration Error 5
Bjørn Børresen Oct 19, 2010 11:38 PM (in response to Alexandre_Monteiro)Hi, I'm getting this one as well on Win7 (64bit).
I already have Flash Builder 4 installed (commercial license). Then I tried installing Flash Professional CS5 (trial) and got the "Configuration Error 5" when trying to run Flash after install. I uninstalled and ran the Adobe CS5 clear script. I did this twice, same error. I tried downloading Adobe Creative Suite Master Collection instead, same result with that one.
I verified the permissions for both the Adobe PCD folder and the SLStore folder, to no avail.
Any other hints?
19. Re: Configuration Error 5
C. Agruss (Adobe)Oct 20, 2010 1:15 PM (in response to Bjørn Børresen)
Hi Bjorn,
The best way to isolate the error you're seeing is to capture the log files described in this KB article:
If you zip up those logs and send them, we should be able to spot the specific problem.
-Chris
20. Re: Configuration Error 5
Bjørn Børresen Oct 20, 2010 10:39 PM (in response to C. Agruss (Adobe))Chris, here are the log files I found:
http://dev2.bybjorn.com/cs5logs.zip
Thanks for looking into this.
21. Re: Configuration Error 5
C. Agruss (Adobe)Oct 21, 2010 1:43 PM (in response to Bjørn Børresen)
Thanks for sending those logs Bjorn.
I looked through those logs, and there are a lot of errors evident, so those should provide the right clues for identifying a solution. I'm sending these logs over to my colleagues on the Flash Pro and Licensing teams, for help with diagnosis, and will report back soon.
-Chris
22. Re: Configuration Error 5
C. Agruss (Adobe)Oct 21, 2010 5:07 PM (in response to C. Agruss (Adobe))
Hi Bjorn,
Our licensing engineer replied with this info:
"Either there is no pcd.db, or they can't read it, or the data from the installer is not there. Can you ask for the pcd.db file?"
He's asking to look at this particular database file, so if you could zip it up and post it alongside your logs, that would help. You should find that here:
c:\Program Files (x86)\Common Files\Adobe\Adobe PCD\pcd.db
-Chris
23. Re: Configuration Error 5
Bjørn Børresen Oct 21, 2010 11:46 PM (in response to C. Agruss (Adobe)) -
24. Re: Configuration Error 5
C. Agruss (Adobe)Oct 22, 2010 8:58 AM (in response to Bjørn Børresen)
Thanks Bjorn - I've forwarded your pcd.db file to our licensing team for diagnosis, and will keep you posted.
-Chris
25. Re: Configuration Error 5
C. Agruss (Adobe)Oct 22, 2010 6:19 PM (in response to C. Agruss (Adobe))
Hi Bjorn,
Our inside man took a look at that db file, and only found one product installed (Flash Builder), so if you thought that Flash Pro CS5 was also installed, there's something wrong there.
Are you sure you re-installed Flash Pro successfully after uninstalling it earlier?
-Chris
26. Re: Configuration Error 5
Bjørn Børresen Oct 23, 2010 3:18 AM (in response to C. Agruss (Adobe))Here's a screenshot of my start bar when searching for "flash": http://imgur.com/7u6KG.jpg
If I click the "Adobe Flash Professional CS5" icon there, it will give me the error message in the title of this topic, like this: http://imgur.com/4gypU.jpg
So I'm sure it is installed, yes.. but it doesn't work. Are there anything else I can try here? I know the last resolution is to reinstall Win7, but I'm pretty hesitant to go there as it will cost me a days worth of work.
27. Re: Configuration Error 5
C. Agruss (Adobe)Oct 25, 2010 9:10 AM (in response to Bjørn Børresen)
@Bjorn,
Reading back to your original message, I see that you already tried uninstalling/reinstalling Flash Pro more than once, sometimes on its own, and sometimes with the CS5 Suite Trial. My hunch is that something about the Suite Trial installation was conflicting with the individual Flash Pro Trial installation (or vice versa).
Since Flash Pro was still not showing up as installed in the Product Configuration Database (pcd) you sent last week, you could give it one more try:
- uninstall Flash Pro CS5, using the Uninstall control panel
- reboot, and make sure Flash Pro CS5 is no longer present in your Program Files folder
- run the CS5 Clean tool, and if Flash Pro CS5 is still showing, use the tool to remove it
- install the Flash Pro CS5 trial on its own (not from one of the CS5 Suite trials).
If you still get an error trying to launch Flash Pro after re-installing as described above, please send me your install log. You should find the install log under \Program Files (x86)\Common Files\Adobe\Installers\, if needed.
-Chris
28. Re: Configuration Error 5
Bjørn Børresen Oct 26, 2010 4:06 AM (in response to C. Agruss (Adobe))Ok, uninstalled, rebooted, cs5 clean, rebooted, installed Flash CS5 only, same problem.
Here are all logs in the \Program Files (x86)\Common Files\Adobe\Installers\ folder in addition to the "Adobe CS5 Cleaner Tool.log" file:
http://dev2.bybjorn.com/adobe_logs.zip
Thank you for your continued support on this.
29. Re: Configuration Error 5
Bjørn Børresen Oct 26, 2010 4:16 AM (in response to Bjørn Børresen)Thinking that maybe my Flash Builder 4 installation was causing the problems I tried to uninstall it - just to get this error: http://imgur.com/xCNRL.png
Tried to reboot, uninstall again, but still got the error. It says to use the CS5 Clean Tool - but that can't be used to remove Flash Builder, AFAIK ..
30. Re: Configuration Error 5
C. Agruss (Adobe)Oct 26, 2010 10:41 AM (in response to Bjørn Børresen)
Hi Bjorn,
Yes, you can use the CS5 Clean tool for removing FB4.
Reading back through this thread, another thing I noticed from your original post is that you're using an educational license. Normally that's fine, but I've seen a few cases where invalid SNs were distributed for Edu, so another thing we could check is whether your FB4 SN is valid. If you send it to me via a private forum message, I can make sure they gave you a good one.
I looked through the latest install logs you posted, and Flash Pro CS5 is reporting a fully successful installation, with nary a warning or error. Perhaps post your latest amt3.log as well, so I can see if it's still failing in the same place, or if it's shifted at all as a result of your changes.
I'm about stumped now, but will run it by the Flash Pro team to see if they've encountered anything like this before.
-Chris
31. Re: Configuration Error 5
Bjørn Børresen Oct 26, 2010 10:50 AM (in response to C. Agruss (Adobe))Here's the latest amt3.log: http://dev2.bybjorn.com/amt3.zip
I'm not using an edu license .. the FB4 license is a commercial one, and I'm trying to install a trial of Flash Pro (ie no SN). I'll send you the FB4 SN in a message .. FB4 is working fine though ...
32. Re: Configuration Error 5
C. Agruss (Adobe)Oct 26, 2010 11:15 AM (in response to Bjørn Børresen)
Oh, right. I was confusing Alexandre's original posting with yours - sorry. Since FB4 is still working fine, I won't worry about that.
Looking at the new amt3.log you posted, it's showing the same error with the pcd that you started with. I thought of something we haven't tried though - sometimes Win Virtualization will kick in and interfere, even though we disable it. When that happens, you can wind up with a mismatched shadow copy of the pcd in your virtual store.
Here's how to check that:
See if there's a folder like this in your virtual store:
C:\Users\yourUserName\AppData\Local\VirtualStore\Program Files (x86)\Common Files\Adobe\Adobe PCD
If so, delete that folder, and then try launching Flash Pro CS5 again.
-Chris
33. Re: Configuration Error 5
Bjørn Børresen Oct 26, 2010 11:36 AM (in response to C. Agruss (Adobe))My C:\Users\bjorn\AppData\Local\VirtualStore folder is empty ..
34. Re: Configuration Error 5
C. Agruss (Adobe)Oct 26, 2010 11:43 AM (in response to Bjørn Børresen)
I'll ask a colleague on the Flash Pro team to take a look at your logs, to see if any of this looks familiar.
-Chris
35. Re: Configuration Error 5
Bjørn Børresen Oct 26, 2010 11:57 AM (in response to C. Agruss (Adobe))Thanks, yeah sorry I guess I posted this in the wrong forums. This was just the first thread that showed up when googling the error.
36. Re: Configuration Error 5
C. Agruss (Adobe)Oct 26, 2010 2:30 PM (in response to Bjørn Børresen)
No worries - when we find the solution, it will probably be useful for both products.
I just heard back from the licensing team, after further experiments with the pcd.db file you posted last week, and here's what they recommend:
"My observation is that the pcd.db shared by the user is corrupt and in a bad state.
I replaced this PCD on my machine and ran the CS5 Flash Pro installer and it failed to
make any entries into it. I then ran a simple SQL insert query in the domain_data table
and that failed too.
Given this and the fact that the user appears to have only Flash Builder on his machine
We can ask the user to do the following
- uninstall FB (de-select the deactivate option as FB is already activated)
- delete the pcd.db (Not the cache )
- Re-Install FB and Flash Pro CS5"
---From your most recent posts, I think you've already uninstalled everything except Flash Pro, so for step 1 you'll probably want to uninstall that instead, along with any other Adobe apps you may have on that machine now.Let us know how it goes,-Chris -
37. Re: Configuration Error 5
Bjørn Børresen Oct 26, 2010 2:45 PM (in response to C. Agruss (Adobe))Ok, so I uninstalled all Adobe software on my computer except FB4 .. I'm not able to uninstall FB .. it still gives me the error I posted in an earlier message http://imgur.com/xCNRL.png
I tried to run the CS5 Clean tool, but I don't see any choice to uninstall FB in it, so the closest I get is CS5 -> Clean All. Done that but it makes no difference .. FB is still installed, and clicking uninstall won't work.
I guess I could go through all the Adobe folders and delete them manually but it seems kinda hacky.
38. Re: Configuration Error 5
C. Agruss (Adobe)Oct 26, 2010 3:03 PM (in response to Bjørn Børresen)
My hunch is that the corrupt PCD is what was preventing successful uninstallation too, so it's a bit of a Catch-22.
Since you've already run "Clean All" from the CS5 tool, that should be good enough. You can manually delete the FB4 folder after that, so you'll be ready for a fresh start after removing the PCD.
-Chris
39. Re: Configuration Error 5
Bjørn Børresen Oct 27, 2010 1:40 AM (in response to C. Agruss (Adobe))IT WORKS! :-)
Here is what I did to fix this:
* Uninstalled every Adobe software on my computer in the Control Panel (everything; Adobe Acrobat, AIR, Flash, etc.). Flash Builder could not be uninstalled though (got an error telling me to use the CS5 Cleaner Tool)
* Used the CS5 Clean Tool and selected "Clean All" http://www.adobe.com/support/contact/cs5clean.html
* Using cygwin I deleted the following folders:
- C:\Program Files (x86)\Adobe\
- C:\Program Files (x86)\Common Files\Adobe
- C:\Users\<myusername>\AppData\Local\Adobe
* Rebooted
* Installed CS5 Master Collection Trial. Was able to input my existing FB SN there, so I'm running FB commercial and Flash Pro trial which was what I wanted.
Thanks a lot to Chris & his colleagues for walking me through this :-)
